ik krijg mijn wacom pentablet niet aan de gang onder linux. de cursor beweegt simpelweg niet. Hier is (veel) informatie:
dit zegt dmesg:
stuk uit Xfree86.0.log
ik heb de volgende modules geladen:
- hid
- wacom
als ik /dev/input/event0 cat en dan de pen beweeg of een knopje indruk, zie ik wel rommel op mijn scherm komen.
versies:
kernel 2.4.18 met usb ondersteuning
slackware 8.0
xfree86 versie 4.1.0
29
30
31
32
33
34
35
| Section "Module"
Load "graphireUSB_drv.o"
EndSection
Section "InputDevice"
Identifier "gstylus"
Driver "graphireusb"
Option "Device" "/dev/input/event0"
Option "Mode" "Absolute"
Option "Type" "gstylus"
Option "Suppress" "30"
EndSection
Identifier "geraser"
Option "Type" "geraser"
EndSection
Identifier "gmouse"
Option "Type" "gmouse"
EndSection
Section "ServerLayout"
InputDevice "gstylus" "AlwaysCore"
InputDevice "geraser" "AlwaysCore"
InputDevice "gmouse" "AlwaysCore"
EndSection |
dit zegt dmesg:
| usb.c: registered new driver hub uhci.c: USB Universal Host Controller Interface driver v1.1 PCI: Found IRQ 11 for device 00:04.2 PCI: Sharing IRQ 11 with 00:04.3 PCI: Sharing IRQ 11 with 00:0a.0 uhci.c: USB UHCI at I/O 0xd400, IRQ 11 usb.c: new USB bus registered, assigned bus number 1 hub.c: USB hub found hub.c: 2 ports detected PCI: Found IRQ 11 for device 00:04.3 PCI: Sharing IRQ 11 with 00:04.2 PCI: Sharing IRQ 11 with 00:0a.0 uhci.c: USB UHCI at I/O 0xd000, IRQ 11 usb.c: new USB bus registered, assigned bus number 2 hub.c: USB hub found hub.c: 2 ports detected hub.c: USB new device connect on bus1/2, assigned device number 2 usb.c: USB device 2 (vend/prod 0x56a/0x11) is not claimed by any active driver. Adding Swap: 530136k swap-space (priority -1) usb.c: registered new driver hid input0: USB HID v1.00 Mouse [WACOM ET-0405A-UV2.0-1] on usb1:2.0 hid-core.c: v1.8 Andreas Gal, Vojtech Pavlik <vojtech@suse.cz> hid-core.c: USB HID support drivers usb.c: registered new driver wacom |
| (**) Option "AlwaysCore" (**) gstylus: always reports core events (**) gstylus event device is /dev/input/event0 (**) gstylus is in absolute mode (**) Option "Suppress" "30" (**) GraphireUSB: suppress value is 136399822 30 (**) Option "AlwaysCore" (**) geraser: always reports core events (**) geraser event device is /dev/input/event0 (**) geraser is in absolute mode (**) Option "Suppress" "30" (**) GraphireUSB: suppress value is 136399822 30 (**) Option "AlwaysCore" (**) gmouse: always reports core events (**) gmouse event device is /dev/input/event0 (**) gmouse is in absolute mode (**) Option "Suppress" "30" (**) GraphireUSB: suppress value is 136399822 30 (II) XINPUT: Adding extended input device "gmouse" (type: Graphire Mouse) (II) XINPUT: Adding extended input device "geraser" (type: Graphire Eraser) (II) XINPUT: Adding extended input device "gstylus" (type: Graphire Stylus) (II) XINPUT: Adding extended input device "Mouse1" (type: MOUSE) (**) Option "Device" "/dev/input/event0" (==) GraphireUSB tablet top X=0 top Y=0 bottom X=10206 bottom Y=7422 (==) GraphireUSB tablet top X=0 top Y=0 bottom X=10206 bottom Y=7422 (==) GraphireUSB tablet top X=0 top Y=0 bottom X=10206 bottom Y=7422 |
- hid
- wacom
versies:
slackware 8.0
nope
