het is stil rond ppstats
  • cinnamon
ppstats blijft nu al eventjes op dezelfde versie zitten
geen wensen, codeklopper geen tijd of is de behoefte aan grafiekjes afgenomen
wrom?
  • Witlof
  • Laatst online: 16-10 18:32
Heb jij nog wensen, ideeën of aanvullingen op de huidige ppstats-versie :? Andere waarschijnlijk niet :)
  • [eNeRGy]
  • Laatst online: 24-04-2025
Ik heb er wat aan gewerkt en moet nog steeds 1 dingetje afmaken en dan is ie voor mij af en gaat de source naar stappel_ toe.
Mijn changelog:
- Changed !DOCTYPE to a better one (without URI to a .dtd), this solves some problems in a couple of browsers.
- Changed font-size in em, this for making it possible to resize in browser.
- Changed style-sheet, more is defined from it (better accessibility).
- Changed charset to ISO-8859-15 (was ISO-8859-1) so there is a better support for modern characters (like the euro).
- Changed spaces in html output into tab, this gives a nicer output and no increase in download size.
- Changed html source into one which would be more conform XHTML:
- Elements must nest properly;
- Element and attribute names must be in lower case;
- Attribute values must always be quoted;
- Attribute-value pairs must be written in full (<td nowrap> must be <td nowrap="nowrap">);
- Empty elements must either have an end tag or the start tag must end with />.
- Changed menu structure into unordered lists instead of non-breaking spaces, this gives better accessibilty.
- Removed some obsolete tags (<center>).
- PNG output had now a tranparent background and the date on the bottom are now completely visible (I guess you need at least GD 2.0).
- The Y-ax labels won't be unreadable anymore (1.4+e etc.) they are forced to draw like integers.
- Discovered a missing setting in the .ini (ShowSearch) which enables/disables search forms in the menu, added it to the .ini.
- Headers in the menu are centered again and the non-breaking spaces are removed.
- Replaced '&' -> '&', '<' -> '<' and '>' -> '>' at several locations.
- Added id's to input objects besides the name attribute, this is for future compatibility.
- Added a little space between the right-side of the menu and the rest of the page to give it a better look.
- Put some extra indenting to the sourcecode for better readability.
- Raised the number of ports read out of the proxy .ini from 4 to 9.
- When the OS is non-windows 'uname -rs' will give nicer infomation.
- Added an option in the .ini to change between the am/pm notation and a 24:00 clock on the 'By Hour' page.
- Removed 'GMT' on the 'By Date', 'By Week', 'By Month', 'By Year' and 'By Day of Week' page as it is not very usefull.
- Removed 'GMT' also at the day history on the executive hostname page.
- Changed 'Windows 95/98/NT' into 'Windows 9x/NT' so Windows ME/2k/XP/ect.. are also covered.
- Added support for the '.aero', '.biz', '.coop', '.info', '.museum', '.name', '.ac', '.gg', '.je', '.ps' and '.vu' TLD's as these are valid, but were not present yet.
- Removed the '.cs', '.fx', '.gb', '.nt', '.su' and '.ze' TLD's because these are not valid TLD's.
- Added '.arpa', '.gg', '.je', '.mg', '.mh', '.ml', '.mm', '.mn', '.mo', '.mp', '.ms', '.mv', '.mw', '.mz', '.nc', '.nf', '.nr', '.pg', '.pm', '.pn', '.pr', '.ps', '.pw', '.re', '.sc', '.sd', '.sh', '.sj', '.sl', 'sm', '.sn', '.so', '.sr', '.st', '.sv', '.tj', '.tv' and '.vu' flag images. Remains only the flag of East Timor, but that country has no flag at the moment as it is under command by the UN forces)
- Added 'Sinix' OS logo.
- Changed comment on the write_emailsbyhost function as it said 'write all hostnames being used by a give email address' while the name of the function already is suggesting the other way round.
- Fixed typo in '.ini' at the format options: 'GB' -> 'GD'.
- Added option in the '.ini' to enable transparency in PNG if GD version is <2.0.
- Changed some CPU names after looking into the perproxy documentation bij distributed.net: 'm68k' -> '68k', 'StrongARM' -> 'ARM', 'm88k' -> '88k'.
- Removed the 'DEScracker' CPU because it is not listed (anymore).
- Removed the 'DEScracker' OS because it is not listed (anymore).
- Fixed Stanley's email adres in the 'display_verion' function: 'bifoot.com' -> 'bigfoot.com'.
- Added Michaël's credits.
- Chaged copyright so it also covering 2002.
- Changed download targets to 7.2.
  • stappel_
  • Laatst online: 30-08 17:27
sssst. waarom moeten jullie altijd met dit komen als het fout gaat. vorige week donderdag is de scsi disk van de webserver gecrashed. de site is dus tijdelijk even dood. (en natuurlijk is net de garantie van de disk verlopen op 31/12/2001 :( )
Ubero: #2, Euler: #1, GOT: #1, Des: #1, Zeta: #1, Eon: #3, OGR-24: #3, OGR-25: #7,
LM: #7, AP: #5, DF: #19, D2OL: #37, SOB: #50, TSC: #63, RC5: #96
  • Witlof
[eNeRGy]: Is het alleen maar een beetje gefatsoneerd mbt de code of is er nog iets mbt de stats zelf veranderd afgezien van vlaggen en OS'sen die toegevoegd zijn.
  • cinnamon
Op maandag 08 juli 2002 08:50 schreef stappel_ het volgende:
sorrie?
  • [eNeRGy]
Op maandag 08 juli 2002 09:12 schreef Witlof het volgende:
Ik heb er geen stats bij geprogrammeerd, ik heb vooral geprobeerd de kwaliteit van ppstats te verhogen door betere code te laten outputten (en heb dus elke regel html herschreven)
[edit]
PS. Al vind ik transparante png's enzo een hele verbetering hoor :P)
PS. 2 http://energy.keyserver.org/rc5 en http://energy.keyserver.org/rc5hist draaien mijn aangepaste versie
  • [eNeRGy]
Op maandag 08 juli 2002 10:46 schreef cinnamon het volgende:
sorrie?
Dat is niet persoonlijk bedoeld (denk ik) hoor :)
  • [eNeRGy]
[disclaimer]ja, dit had in 1 berichtje kunnen staan :P[/disclaimer]
Als je een backup hebt wil ik wel als mirror dienen.
  • ThaDude
  • Laatst online: 00:18
ThaDude
Hang Loose
Hey die transparante png's zijn wreed!
dus dikke verbetering :)
We're machines just like everything else in nature. (gasloos sinds 01-10-2020, WP: SW75YAA/ERSD-VM2D, DJG WPS 300, 18 hp CPC, 11,1 kWp
  • cinnamon
Op maandag 08 juli 2002 22:55 schreef ThaDude het volgende:
je had de achtergrondkleur van de png ook al aan kunnen passen door in de code het volgende stukje aan te passen
set terminal png kleurtje kleurtje kleurtje enz
Op maandag 08 juli 2002 08:43 schreef [eNeRGy] het volgende:
is het niet handig om dit naar ppstats.keyserver.org te laten wijzen?
wel netjes gemaakt, ik wil ook heb
meer euuh
<a href="mailto:michael.nl">Micha&euml;l Hompus</a>
jij wil geen mail he
  • stappel_
Op donderdag 11 juli 2002 07:18 schreef cinnamon het volgende:
quote]Op maandag 08 juli 2002 22:55 schreef ThaDude het volgende:
je moest eens weten wat voor shit ik binnen krijg. Ik krijg zelfs mailtjes alsof ik de beheerder ben van de site van Dutchman en of ik dan bepaalde dingen wil, toevoegen aan search engines, extra veel server requests, etc. en alle virussen weten je dan ook te vinden.
  • _DPC_Scorpion
  • Laatst online: 07-09 23:46
lol Stappel maar in het verleden heb ik je wel eens kunnen mailen en zo je nieuwste ppstats testen en de bug eruit halen... :)
zo jij krijgt weer virusjes Stanley 8-)
  • Mobster
  • Laatst online: 07-06-2016
Mobster
Los Alcoholicos
Op donderdag 11 juli 2002 11:06 schreef _DPC_Scorpion het volgende:
En moet verion dan geen version zijn of moet ik me gewoon niet met dit soort veel te technische dingetjes bemoeien? ;)
Toch maar eens een andere sig bedenken :P
  • [eNeRGy]
Op donderdag 11 juli 2002 11:35 schreef Mobster het volgende:
Dit gaat duidelijk boven je pet ;)
  • Mobster
Mobster
Los Alcoholicos
Op donderdag 11 juli 2002 20:10 schreef [eNeRGy] het volgende:
:X Ik wist het wel |:( ;)
* Mobster zal nu :X en :z. Bijna vakantie
  • NightBird
  • Laatst online: 23:43
NightBird
DPC-Crew Coding
[eNeRGy] ? :)
WatHoorJeWaar · Asobakken
Eerdere projecten: Leading Courses · Brandstof-zoeker.nl · Voertuig-zoeker.nl
  • DukeBox
Ik ken geen scsi schijven met garantie < 3 jaar.
  • stappel_
Op woensdag 17 juli 2002 21:54 schreef DukeBox het volgende:
mei 97 productie datum. het was een WD trouwens.
  • cinnamon
Op maandag 08 juli 2002 10:58 schreef [eNeRGy] het volgende:
PS. 2 [url="http://energy.keyserver.org/rc5"]http://energy.keyserver.org/rc5[/url] en [url="http://energy.keyserver.org/rc5hist"]http://energy.keyserver.org/rc5hist[/url] draaien mijn aangepaste versie
is die 7.2 al ergens vandaan te halen?
  • NightBird
NightBird
DPC-Crew Coding
Op zaterdag 20 juli 2002 10:53 schreef cinnamon het volgende:
is die 7.2 al ergens vandaan de halen?
Of de laatste stappel-versie ?
Directory Listing Denied
This Virtual Directory does not allow contents to be listed.
@ [url="http://ppstats.keyserver.org"]http://ppstats.keyserver.org[/url]
