TO 3.1.5 problem
Hoi,
Hoe zit de code in elkaar als je iemand killed dat je automatisch links boven ziet:
"naam" killed you with AK-47 and has 45%
ik weet #w = weapon
#h = health
#t = teammate
#l = location
PS: als bijvraag:
ook als ik reload-
Delete=s_kReload ??/ xteamsay #h #l
Dat die mijn health en location doorgeeft.
  • Nibbles
  • Laatst online: 16-04 12:46
Nibbles
just nibb it
Het is een TOST feature en zal dus alleen op TOST servers werken (zo goed als elke server).
Check de readme van TOST voor een uitgebreide beschrijving van alle commands die mogelijk zijn.
xSay / xTeamSay
=> like Say/TeamSay, but capable of executing macros:
## - print #
#W - players weapon
#T - players target name
#N - players name
#L - players location (if defined by the mapper !)
#H - players health
#B - players buddies (all people of the same team within 1500 units)
To use those commands you have to edit your USER.ini (AoT MOD = TOUser.ini). THIS is NO Tutorial on how to bind keys.
Some Examples:
"xteamsay I dropped a #W" ---> "(Teamsay)i dropped a Glock23".YOu can use this in combination with the drop weapon command.
"xteamsay (#L) Cleared!" ---> (Teamsay)Lower Bridge Cleared!
"I got your back, #T!" ----> "I got your back, Player! (#T will be replaced by the name of the player you are pointing to)
"xsay you have been killed by #N" ---> "You have been killed by 'playername'". THis is useful in times you change your nick and you dont want to change your Taunts for example.
"xteamsay I need some backup, i only got #H Health left!" ---> "(Teamsay)I need some backup, i only got 35 Health left!"
"xteamsay Cover me, #B!" ----> "(Teamsay)Cover me, Playerx, Playery, Playerz and Playerxyz!"
This example List is not complete and only shows a few of the things you are now able to do. I'd suggest combining the xsay/xteamsay commands with some other commands, for example the speech commands.
Je moet dus je binds aanpassen van TeamSay naar het commando xTeamSay. Dan gebruik je die codes als #H.
Als je je health + locatie door wil geven als je reload (wat ik persoonlijk erg irritant en nutteloos vind), kan je de regel gebruiken die je zelf al gaf, maar je splitst de commando's met de pipe "|". Het commando gaat er dus als volgt uit zien:
Delete=s_kReload | xteamsay #h #l
Nogmaals, keybinds bij het reloaden zijn zo goed als nutteloos omdat er door newbies e.d. toch niet op gelet wordt, of ze maken er geen gebruik van het feit dat jij meldt dat je reload. Goede spelers horen sowieso wel dat je reload, en zien het aan je bewegingen. Daar komt nog bij dat je als je samen in een vuurgevecht zit toch niet de tijd hebt om te gaan lezen wat er allemaal gezegd wordt.
Die "1337e" binds zoals
~~-=|?// CoVeR mE i'M R3LoaDInG my AK47 at TErrorist Spawn wItH 35 HeAlTh PoInTs \\¿|=-~~
zijn al helemaal niet te lezen, en zorgen dus alleen maar voor ergernis tijdens het spelen :P
Thx man.
Precies wat ik nodig had.
Bedankt
[/\] Clan member
tR's Clan member
