als ik op mijn debian bak apt-get install sendmail doe dan krijg ik de volgende melding
Ik kan hier niet over vind op tweakers en als ik met google zoekt vind ik alleen info in het spaans denk ik, dus dat begrijp ik niet
Is hier iemand die mij hier mee kan helpen
ik ben root en er draaid nergens anders 'n apt-get
29
30
31
32
| Area51:/var/cache/apt/archives# apt-get install sendmail Reading Package Lists... Done Building Dependency Tree... Done The following extra packages will be installed: m4 The following NEW packages will be installed: m4 sendmail 0 packages upgraded, 2 newly installed, 0 to remove and 1 not upgraded. Need to get 1025kB of archives. After unpacking 2619kB will be used. Do you want to continue? [Y/n] y Get:1 http://ftp.nl.debian.org stable/main m4 1.4-10 [105kB] Get:2 http://ftp.nl.debian.org stable/main sendmail 8.9.3-23 [921kB] Fetched 1025kB in 42s (24.0kB/s) Selecting previously deselected package m4. (Reading database ... 18123 files and directories currently installed.) Unpacking m4 (from .../archives/m4_1.4-10_i386.deb) ... Selecting previously deselected package sendmail. Unpacking sendmail (from .../sendmail_8.9.3-23_i386.deb) ... Setting up m4 (1.4-10) ... install-info: failed to lock dir for editing! No such file or directory dpkg: error processing m4 (--configure): subprocess post-installation script returned error exit status 2 dpkg: dependency problems prevent configuration of sendmail: sendmail depends on m4; however: Package m4 is not configured yet. dpkg: error processing sendmail (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: m4 sendmail E: Sub-process /usr/bin/dpkg returned an error code (1) Area51:/var/cache/apt/archives# |
specs : http://specs.tweak.to/7435
