Raku
berekeningen per seconde
---- Dit gaat over een eccp-108, maar dat zal wel zelfde id zijn --------
8. What are the iterations in "iterations per second"?
To compute points [s]P # [t]Q with random s and t we do not pick new s and t values every time. Computing [s]P # [t]Q from scratch every time would be too slow. Instead we change s and t a bit each time.
For instance if we are at a random point R = [s]P # [t]Q, then we can jump to [2s]P # [2t]Q with a single elliptic operation: R # R.
Instead of just doubling though, we multiply by one of 7 different constants at each step. The choice is made using a pseudo-random hash function. Also, each point is actually a representative of a orbit and the hash function is chosen to be the same for all points in a orbit.
If you run the ecdl2K-108 program and it reports something like 123456 iterations per second, that means that it is jumping from point to point by doing these steps 123456 times every second.
Clearly it would be impossible to send all the points back to base to check for a match between two points. That is why we have distinguished points.
[off topic]
Handig he die edit knopjes
[/off topic]
En ja, dat bestaat al hoor... ik heb in ieder geval ColdFusion, Goingin en NeoTweaker er al mee gezien in #DPC...
[/off topic]
maar bestaat het wel als script? en waar kan ik dat vinden?
Raku
| eccp {
if (%eccplogfile == $null) { set %eccplogfile $shortfn($sfile(d:\,Choose the eccinfo file in your ECCp dir,OK)) }
if (%eccplogfile == $null) { echo $chan Failure | halt }
set %eccpdp $read(%eccplogfile,1)
set %eccplogfile2 $left(%eccplogfile,$calc($len(%eccplogfile)-7)) $+ dplist
set %eccpbuff $lines(%eccplogfile2)
if (%eccpbuff == $null) { set %eccpbuff 0 }
if (%eccpdp == $null) { sey %eccpdp 0 }
say 4[Eccp] Ik heb in totaal 4[ $+ %eccpdp $+ ] koeien laten slachten en er staan 4[ $+ %eccpbuff $+ ] klaar om 'geholpen' te worden.
Maar die geeft alleen het totaal aantal gedane dp's en het aantal dp's in de buffer aan. De topicstarter vraagt waar eccp het aantal its/sec opslaat. Maar goed heel simpel: dat wordt nergens opgeslagen
Dat scriptje van NG hierboven gaf is alles wat je eruit kunt halen naar mijn weten.
_______________-=Team ColdFusion=-_______________
#2 DPAD - #2 OGR27 - #2 F@H - #3 R@H - #5 RC5 - #6 SoB - #10 WCG
||| #1 ECCp109 - #1 ECC2-109 - #1 OGR24 - #1 D2OL P1|||
ik dacht dat ie hem wel ergens in de .exe tijdelijk opsloeg.... nou jah....
Raku
Zet dit:
in je Eccp109.ini, dan krijg je een timing.txt met deze inhoud:EXT_TIMING=1
Heeft me ook een tijd gekost om na te zoeken, maar na wat google kwam ik het tegen.current average speed : 1281408.0 its/sec
max average speed : 1357380.9 its/sec
Fun while it lasted: World Community Grid!
subteam: anderen niet lezen. (He, ik zei, niet lezen suffie) | scorpion: of je effe contact wil opnemen met icq#132899400 of via kowisse@hotmail.com 'k ben je mail gegevens kwijt na mijn pc-crash, en het forum bestaat niet meerOp maandag 01 juli 2002 21:39 schreef scorpionv het volgende:
Waar kan je die vinden want bij mij wil het eccp mirc script nooit werkenOp maandag 01 juli 2002 20:59 schreef scsi-freak het volgende:
moo.dll
[edit]
Ik heb hem al af (zonder moo.dll)
Het foutje wat in het script zat wat ik al had was iets waar ik zelf niet op was gekomen omdat ik hem al kant en klaar had gekregen maar nu doet hij het dus ik ben weer
Taal fouten inbegrepen ;)
Skywindow plan je astro foto sessie
http://www.influenced.net/moodll.phpOp maandag 01 juli 2002 22:09 schreef klaasbram het volgende:
maar het eccp script maakt geen gebruik van moodll hoor
moo.dll is idd voor system info. Heeft niks met je koei te makenOp maandag 01 juli 2002 22:10 schreef NG het volgende:
Ik had al eerder zo'n script gemaakt (volgens mij heeft NG die net gepost)
Ik zal die 's aanpassen om ook its/sec weer te geven
Please guys, I'm trying to troll here.
If I failed to offend you in this post, please leave a message. I will address you in next post.
Kijk, dat is nog eens een mooie opmerking, we zien de aangepaste mirc-eccp wel verschijnenOp dinsdag 02 juli 2002 14:22 schreef GeniusDex het volgende:
Ok, hij's af
Je kunt hem hier downloaden. Unzippen, laden en klaar
[edit]
Ik moet er nog ff bij zeggen dat ik alleen zeker weet dat hij hier met timing.txt werkt. Voor de rest: vind je bugs, meld het ff
[edit]
