via proxy inloggen op irc (quakenet) 2e poging
  • 101 views sinds 30-01-2008
Firewall
mIRC can connect to an IRC Server through a Socks4, Socks5, or Proxy firewall.
The main purpose of this option is to allow access to IRC through a firewall at work, or more rarely through a network set up at home. The majority of home users should keep this option turned off.
Hostname
The address of your firewall server, can be either a named address or an IP address.
User ID
Can be the account or user name on your system. For most people this will be the User ID portion of their email address (the text before the @ sign).
Password
The password required to access the firewall.
Note: If you are connecting via a proxy, and you enter a password, mIRC only supports http proxy 'basic' authorization.
Port
This is usually 1080 for Socks firewalls.
Initiate DCCs through firewall
mIRC uses a passive protocol to establish DCC connections when a client is behind a Socks5 firewall.
This will not work with older versions of mIRC or other IRC clients because no standard exists. You can find out more about the protocol here.
Note: Socks4 and Proxy are limited in functionality, and only allow IRC server connections.
The /firewall command
This command allows you to change the above firewall settings.
/firewall [-cmN[+|-]d] [on|off] <server> <port> <userid> <password>
The -c switch clears the userid and password values.
The -mN switch set the connection type, where N is 4 or 5 for Socks4 or Socks5, or p for proxy.
The +|-d switch turns dccs through a firewall on or off.
Heb dat verhaal doorgelezen.. ff voor de duidelijkheid, ik wil via een proxy (port 8080) op irc komen.
Zodat andere bij mijn nickname, het ip van de proxy zien en niet die in mij geval, van chello.
Ik heb dus bij Connect>firewall ingesteld:
protocol: proxy
hostname: hostname van de proxy
port: 8080
Als ik connect naar de irc server connect ie nog steeds met mijn eigen ip.. ?
Dus wat doe ik fout
Dit kan niet met een proxy server bij mijn weten.
Gelukkig leg je het nu wat beter uit dan de vorige keer.
Dit kan je wel met een bouncer doen, dan moet je zorgen dat je ergens een bouncer kan draaien en via dat kan connecten naar de irc server.
Enne als de volgende keer een topic van je op slot gaat kan je het beste even contact op nemen met de mod inplaats van zelf een nieuwe openen.
  • Len
  • Laatst online: 20-09 12:47
Len
Leeg
Quakenet is niet happy met bouncers en proxy's.
Lees hun MotD maar.
*** - **[ Disclaimer ]***********************************************
*** - IRC is a free media, the operators of this network take no
*** - responsibility whatsoever for opinions expressed or actions
*** - taken by users.
*** - By connecting to this server you give us the right to
*** - probe your machine for open proxies/wingates.
*** - **[ Rules ]****************************************************
*** - http://www.quakenet.org/rules
*** - This network may NOT be used for:
*** - * Flooding (including flood/clonebots).
*** - * Distribution of copyrighted material (eg, warez, mp3,
*** - movies) or pornography.
*** - * Channels dedicated to cheats designed to cause unfair
*** - advantage in multiplayer games.
*** - * Clones. Please contact info@quakenet.org if you require
*** - more than five clients (LAN parties, bots, etc).
*** - * Attempts to takeover existing channels or network services.
*** - * Racism and/or Nazism.
*** - * Spamming and/or advertising.
*** - * Hacking (including Virus/Trojan distribution).
*** - Continued use of this server indicates acceptance of these
*** - conditions.
Je moet dus een proxy hebben waar niet meer dan 5 mensen op zitten die ook op QNet zitten. De poort 8080 wordt al gescand en als die open staat dan word je niet toe gelaten.
suc6 met zoeken
Free Tibet
  • MM-
  • Laatst online: 30-11-2023
MM-
Je kan ook makkelijk met meer dan 5 erop hoor, moet je gewoon ff aanvragen.
Proxy van je ISP werkt niet.
je moet een SSL/H proxy hebben ofzo :)
die zitten meestal op poort .... mag ik dat zeggen ?
  • Exirion
  • Laatst online: 09:38
Exirion
Gadgetfetisjist
User is al een tijdje gebanned, dus deze kan dicht.
