Vnc hidden onder xp
  • 37 views sinds 30-01-2008
  • Cougar
  • Laatst online: 28-05 16:46
Ik heb de search gebruik en kan niet tot een goed antwoord komen onder bijv deze topics:
[topic=525074/1/25]
[topic=310951/1/25]
Mijn topic zegt het eigelijk al ik wil het 'hidden' laten draaien in ons netwerk thuis. Iemand een oplossing (onder windows xp :) )
  • Koffie
  • Laatst online: 19-08 22:47
Koffie
Koffiebierbrouwer
Braaimeneer
Je geeft het zelf al aan:
VNC FAQ:
Q46 Can I get rid of the taskbar icon created by WinVNC?
No. Not without changing and recompiling the source code. We feel that there would be few legitimate uses of VNC where you would need to conceal its operation. However, there might be occasions where you would not want the user of the server machine to be able to adjust the WinVNC settings, password, etc, so versions later than 3.3.2R3 include a 'restricted' mode where the icon is still visible, but the menu options normally available from it will be disabled. See WinVNC - Advanced Settings in WinVNC docs for the details.
In some situations, particularly on Win95, you may find that the icon is not displayed. This is not a feature, it's a bug which we plan to iron out! See the question above on 'I ran WinVNC don't see an icon in my Taskbar!'.
Move > NT + slot
Braaikamer - Smoke&BBQ
