[RH 7.3] SSH inlog probleem
  • radicalEMT
  • Laatst online: 11-08 15:06
Ik kan niet meer een SSH connectie opzetten met een server.
Dit is de output:
Permission denied (publickey,keyboard-interactive)
Dit is de volledige debug output:
[gebruiker]$ ssh -v -v -v -i /home/gebruiker/identity telnet.students.cs.uu.nl
OpenSSH_3.1p1, SSH protocols 1.5/2.0, OpenSSL 0x0090602f
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
debug1: Rhosts Authentication disabled, originating port will not be trusted.
debug1: restore_uid
debug1: ssh_connect: getuid 500 geteuid 0 anon 1
debug1: Connecting to telnet.students.cs.uu.nl [131.211.82.40] port 22.
debug1: temporarily_use_uid: 500/500 (e=0)
debug1: restore_uid
debug1: restore_uid
debug1: Connection established.
debug1: read PEM private key done: type DSA
debug1: read PEM private key done: type RSA
debug1: identity file /home/gebruiker/identity type 0
debug1: Remote protocol version 1.99, remote software version OpenSSH_3.3
debug1: match: OpenSSH_3.3 pat OpenSSH*
Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_3.1p1
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,arcfour,aes192-cbc,aes256-cbc
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,arcfour,aes192-cbc,aes256-cbc,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: none,zlib
debug2: mac_init: found hmac-md5
debug1: kex: server->client aes128-cbc hmac-md5 none
debug1: kex: client->server aes128-cbc hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug1: dh_gen_key: priv key bits set: 130/256
debug1: bits set: 1594/3191
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug3: check_host_in_hostfile: filename /home/gebruiker/.ssh/known_hosts
debug2: key_type_from_name: unknown key type '1024'
debug3: key_read: no key found
debug3: check_host_in_hostfile: match line 4
debug1: Host 'telnet.students.cs.uu.nl' is known and matches the RSA host key.
debug1: Found key in /home/gebruiker/.ssh/known_hosts:4
debug1: bits set: 1596/3191
debug1: ssh_rsa_verify: signature correct
debug1: kex_derive_keys
debug1: newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: waiting for SSH2_MSG_NEWKEYS
debug1: newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: done: ssh_kex2.
debug1: send SSH2_MSG_SERVICE_REQUEST
debug1: service_accept: ssh-userauth
debug1: got SSH2_MSG_SERVICE_ACCEPT
debug1: authentications that can continue: publickey,keyboard-interactive
debug3: start over, passed a different list publickey,keyboard-interactive
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: next auth method to try is publickey
debug2: we did not send a packet, disable method
debug3: authmethod_lookup keyboard-interactive
debug3: remaining preferred: password
debug3: authmethod_is_enabled keyboard-interactive
debug1: next auth method to try is keyboard-interactive
debug2: userauth_kbdint
debug2: we sent a keyboard-interactive packet, wait for reply
debug3: userauth_kbdint: disable: no info_req_seen
debug1: no more auth methods to try
Permission denied (publickey,keyboard-interactive).
debug1: Calling cleanup 0x80634c0(0x0)
Erg vreemd want voorheen werkte het altijd prima en zonder iets te veranderen werkt het nu ineens niet meer. Vanaf andere clients kan ik wel gewoon met SSH connecten.
Iemand een idee?
ja geen ssh support meer daar
hij kent de handshake protocol niet probeer het eens zonder telnet.
