Het grote (?) GTA3-patch topique
  • 48 views sinds 30-01-2008
  • eGo2K
  • Laatst online: 01-05 20:12
eGo2K
De vraag .. (zie sig)
Yo LADIES!
De nieuwe patch is hier te downloaden:
Log:
Grand Theft Auto III
Patch 1.1
Contents
Zip file "GTA3patch1.1.zip" containing
gta3patch.exe
gta3patch.txt (this file)
Installation
Start gta3patch.exe.
After clicking next twice, browse to your installed Grand Theft Auto III directory (the directory where GTA3.EXE resides) and click next.
The patch will check for the presence of your GTA3.EXE file. If the patch finds an un-modified GTA3.EXE, then this file will be updated to version 1.1, otherwise no patching can occur.
Click start to begin the update process.
After patching click exit.
The only file changed by this patch is GTA3.EXE which is upgraded to version 1.1
Save game and setting files are carried forward with no issues.
Changes-
- Exception error after blue Rockstar load screen fixed.
- Error loading saved games fixed.
- Mouse sensitivity now saved with other settings (no changes made to existing settings).
- Option for user to play audio files directly from hard disk. Copy the contents of the PLAY discs Audio directory into your installed Grand Theft Auto III Audio directory. Grand Theft Auto III still requires the presence of the PLAY disc when started. This may give better performance on some machines (though worse on others).
- All protection checks (apart from needing PLAY disc to start) removed. Grand Theft Auto III still checks for the presence of the PLAY disc when initially started, and plays audio from the PLAY disc if not found on the hard disk (see above).
Heeft iemand 'm al geprobeerd >:)
... die alle andere vragen overbodig maakt: BIERTJUH?!
Het leuke is dat ik alles wat op deze lijst staat al zelf heb gedaan, ook dat met audio en zo. Erg nutteloos dus.
  • PowerSp00n
  • Laatst online: 12-10 11:06
PowerSp00n
There is no spoon
Op vrijdag 28 juni 2002 00:03 schreef 007 het volgende:
Had die "patch" even online gegooid dan. Tss ;P
  • eGo2K
eGo2K
Heheh...
Realiseert Take2 dat er GIGANTISCH veel gekopieerd is?
Hmmm gta3.exe is niet in orde :) lol effe de orginele hebben iemand die de orginale gta3.exe online kan zetten??
  • PowerSp00n
PowerSp00n
There is no spoon
Op vrijdag 28 juni 2002 00:12 schreef narfpower het volgende:
Niet op de hoogte van de sites waar je dit soort dingen kunt vinden? >:)
dicht
zie andere topic...
