Zalman ZM50-HP
Graag meningen e.d.
(hopelijk past ie ook op een ATI Radeon 8500)
Ziet er goed uit !!This is the first product in marketplace that uses heatpipe technology
on a VGA card, developed by ZALMAN Tech Co., Ltd.
ZALMAN's upcoming ZM50-HP does not require a fan, thus it does not need to be powered, and makes no noise or vibration by using the heat pipe technology.
It uses two heat spread, one on the GPU and the other on the other side.
The test result from ZALMAN's lab shows that it can cover geForce4 Ti series
without a problem.
Graag meningen e.d.
