Mijn idee was om m'n samsung sw-208B te upgraden van BS01 naar BS04. Nu is mijn vraag: hoe kan ik eventueel BS01 terugzetten als het upgraden naar BS04 niet gelukt is, of niet bevalt? De tekst van de handleiding van het upgraden is als volgt:
En is het verstandig om te upgraden als het goed werkt?
Ik draai XP en wil het dus onder dos gaan doen? Goed idee?[rw]the latest firmware sw-208b_bso4
This is a firmware for the SW-208B RW-ROM DRIVE clone cd.
There're sfdnwin.exe.(using in windows), sfdndos.exe(using in dos) , bs05.bin.(firmware file), and there're fwupsm.bat, fwupss.bat which help that be recognized automatically.
Usually you can use the file for windows.
Where, you have to upgrade in dos mode if your os is window2000.
Model: SW-208B RW-ROM DRIVE
How to upgrade in dos mode
First, check if rom drive is master or slave.
using-master :fwupsm.bat
slavef :wupss.bat
1. download the firmware sw-208b_bso4.zip to your computer.
2. unzip the zip file.
3. rebooting using the booting disc.
4. In the unzipped directory, you check the master or slave ,
and practice the batch file which fits them.
5.When the FIRMWARE DOWNLOAD is finished, please power off your
omputer perfectly. Boot up your computer again.
How to upgrade in Windows.
1. This program is able to use in Windows.
Practice the SFDNWIN.EXE file on windows.
2. When there's pop-up menu, you choose SYSTEM.
Push the OPEN, and take the file what you want to down.
3.If you push the FLASH, Download is started.
4. When the FIRMWARE DOWNLOAD is finished, please power off your computer perfectly.
Used to be Down Under... Foto gallery
