MOHAA : Start niet : OpenGL prob
  • 120 views sinds 30-01-2008
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Dec 6 2001
----- FS_Startup -----
Current search path:
D:\mohaa\main\Pak5.pk3 (259 files)
D:\mohaa\main\Pak4.pk3 (593 files)
D:\mohaa\main\Pak3.pk3 (669 files)
D:\mohaa\main\Pak2.pk3 (4722 files)
D:\mohaa\main\Pak1.pk3 (772 files)
D:\mohaa\main\Pak0.pk3 (11175 files)
D:\mohaa/main
18190 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found AMD w/ 3DNow!
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 102
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINNT\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...GLW_ChoosePFD failed
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...calling LoadLibrary( 'C:\WINNT\System32\3dfxvgl.dll' ): succeeded
...calling CDS: ok
...23 PFDs found
...23 PFDs found
GLW_StartOpenGL() - could not load OpenGL subsystem
dat geeft mijn lieve AMD 550 mhz met een Nvidia Riva TNT2 Model 64 Pro weer als ik Medal of Honor : Allied Assault wil opstarten op een windows xp machine... en opeens issie niet meer zo lief.
ik heb zojuist de laatste Detonator XP Drivers voor die kaart gedownload (versie 29.42) ...
wat zie ik over het hoofd waardoor hij niet draait???
  • kNarf_
  • Laatst online: 04-09-2024
Probeer eens wat andere/oudere drivers.. de nieuwste detonators lijken me sowieso niet zo geschikt voor een TNT2 M64..
  • SPOXER
  • Laatst online: 30-06 13:01
misschien een patch erop. Ik weet niet welke versie je hebt. Nederlands engels.
  • M@NIC
  • Laatst online: 23-09 09:24
[topic=381551/1/25]
Als het daar niet staat, staat het hier:
[search=mohaa opengl]
Volgende keer zoeken dus! :)
Zie post M@NIC :)
Is een zoekvraag ;)
