Ati Radeon VE met RTCW geen OpenGL????
  • 46 views sinds 30-01-2008
  • tsjech@
  • Laatst online: 21-08 14:53
Ik heb nog een extra systeem staan:
-Duron 1 GHz
-15inch Neovo TFT
-Ati Radeon VE DDR 64MB (standaard driver die al onder XP zaten, wordt ook meteen herkend)
-256 DDR geheugen
-Windows XP
Nou wil ik er spellen op spelen maar krijg steeds de melding dat OpenGL niet geladen kon worden...
Als voorbeeld zet ik hier de log van RTCW (updated 1.33) neer (let vooral op de laatste regels). Ligt het aan mij of ondersteund deze kaart geen OpenGL?????
Wolf 1.33-MP win-x86 Jun 1 2002
----- FS_Startup -----
Current search path:
D:\RETURN~1\main\mp_pakmaps6.pk3 (81 files)
D:\RETURN~1\main\mp_pakmaps5.pk3 (35 files)
D:\RETURN~1\main\mp_pakmaps4.pk3 (52 files)
D:\RETURN~1\main\mp_pakmaps3.pk3 (83 files)
D:\RETURN~1\main\mp_pakmaps2.pk3 (47 files)
D:\RETURN~1\main\mp_pakmaps1.pk3 (34 files)
D:\RETURN~1\main\mp_pakmaps0.pk3 (21 files)
D:\RETURN~1\main\mp_pak4.pk3 (5 files)
D:\RETURN~1\main\mp_pak3.pk3 (76 files)
D:\RETURN~1\main\mp_pak2.pk3 (3 files)
D:\RETURN~1\main\mp_pak1.pk3 (308 files)
D:\RETURN~1\main\mp_pak0.pk3 (783 files)
D:\RETURN~1\main\mp_bin.pk3 (4 files)
D:\RETURN~1\main\pak0.pk3 (4775 files)
D:\RETURN~1/main
6307 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec wolfconfig_mp.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
Loaded 714 translation strings from scripts/translation.cfg
Loaded 97 translation strings from translations/rocket.cfg
Loaded 86 translation strings from translations/dam.cfg
Loaded 114 translation strings from translations/tram.cfg
Loaded 57 translation strings from translations/chateau.cfg
Loaded 54 translation strings from translations/keep.cfg
Loaded 73 translation strings from translations/icelab.cfg
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
PS. Ik kan dus ook niet een spel in veilige modus opstarten zoals RTCW heeft.
  • Robin
[search=could not load OpenGL subsystem]
  • tsjech@
ooopssss sorry, had al gezocht in radeon topics, maar kon niks vinden... THANX:)
  • nAFutro
  • Laatst online: 17-04-2020
nAFutro
hmm
standaard driver is niet helemaal meer lekker, gewoon update halen van de site
Zie de post van Robin Vreuls :)
