wat is LPR ??
  • 96 views sinds 30-01-2008
wat houd nu LPR printing ofzoiets precies in..??
ja oke, maar wat kan ik er dan precies mee??
  • F_J_K
F_J_K
Moderator CSA/PB
Front verplichte underscores
Google gaf dit:
Definition of LPR/LPD
LPR/LPD is a platform-independent printing protocol that runs over TCP/IP. Originally implemented for BSD unix, its use has spread into the desktop world and is a de facto industry standard. The specification for LPR is defined in Request for Comment (RFC) 1179.
Terminology
LPR - Line Printer Remote. Refers to the process that sends jobs to the printer or print queue. This is analogous to the print client software and is often called the 'LPR client'.
Apple has included an LPR client starting with LaserWriter 8.5.1, which shipped with Mac OS 8.1. It is also available separately. This software enables you to send print jobs to any LPD printer or print server.
LPD - Line Printer Daemon. Refers to the process that accepts print job from the line printer daemon client (ie: LPR client). This is analogous to the printer or the print server software and is often called the 'LPD server'.
The print server waits for the client to send it jobs. A print server may be capable of handling multiple printers and print queues at once. Since it (usually) only has a single IP address, the queue name must be used to specify the intended print queue.
http://www.graphicpower.com/techarticles/asip62tutorial/Pages/RelTopicLPR.html
Edit: dit valt trouwens heel snel te vinden door te googlen op 'lpr definition'. Je zou dat de volgende keer even kunnen doen voor je je vraag stelt ;)
Geef dan de volgende keer ook aan dat je de FAQ en het policy hebt gelezen door even je OS in de toppictitel te zettten, in dit geval dus ALG van algemeen: [ALG] Wat is LPR
Dat scheelt je weer gezeur :)
  • Han
Han
[topic=471457]
Doe de volgende keer eerst wat meer moeite voordat je een topic aanmaakt. Zie ook de Policy.
