Degene die de topictitel heeft aangepast, dank je, dat was ik vergeten.
Hier is het SQL
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
| ALTER Procedure SP_LoadListDocuments
(@DocumentId VARCHAR(4000),
@NodeStrId VARCHAR(50),
@LanguageId INT)
As
DECLARE @Statement VARCHAR(8000)
SET @Statement = 'SELECT Creator.FirstName + '' '' + Creator.MiddleName + '' '' + Creator.LastName AS CreatorName, Owner.FirstName + '' '' + Owner.MiddleName + '' '' + Owner.LastName AS OwnerName, '
SET @Statement = @Statement + 'TBL_Teams.Name AS OwnerTeamName, TBL_Documents.CreationDate AS CreationDate, TBL_Documents.ExpiryDate AS ExpiryDate, TBL_Documents.CountViews AS CountViews, '
SET @Statement = @Statement + 'TBL_CategoriesLanguages.Name AS CategoryName, LV1.Value AS DocTemplateName, TBL_PropertyValues.PropertyId AS PropertyId, TBL_Properties.PropertyTypeId AS PropertyTypeId, '
SET @Statement = @Statement + 'TBL_PropertyValues.Value AS Value, TBL_DocTemplateProperties.SortOrder, TBL_DocTemplateProperties.IsRequired AS IsRequired, TBL_Teams.StrId AS TeamStrId, TBL_Categories.Id AS CategoryId, '
SET @Statement = @Statement + 'TBL_Documents.LockedByUserId AS LockedByUserId, TBL_Documents.LockTime AS LockTime, Owner.EMail as OwnerMail, Creator.EMail AS CreatorMail, '
SET @Statement = @Statement + 'TBL_DocTemplates.MaxNumberOfAttachMents As MaxAttachments, TBL_LanguageValues.Value AS PropertyName, TBL_DocTemplates.Id AS DocTemplateId, TBL_Documents.ToBeApproved, TBL_Documents.Id AS DocumentId '
SET @Statement = @Statement + 'FROM TBL_Documents '
SET @Statement = @Statement + ' INNER JOIN TBL_PropertyValues '
SET @Statement = @Statement + ' ON TBL_PropertyValues.DocumentId = TBL_Documents.Id '
SET @Statement = @Statement + ' INNER JOIN TBL_DocTemplateProperties '
SET @Statement = @Statement + ' INNER JOIN TBL_Properties '
SET @Statement = @Statement + ' INNER JOIN TBL_LanguageValues'
SET @Statement = @Statement + ' ON TBL_LanguageValues.ItemId = TBL_Properties.Id '
SET @Statement = @Statement + ' ON TBL_Properties.Id = TBL_DocTemplateProperties.PropertyId '
SET @Statement = @Statement + ' ON TBL_DocTemplateProperties.DocTemplateId = TBL_Documents.DocTemplateId '
SET @Statement = @Statement + ' INNER JOIN TBL_Users Creator '
SET @Statement = @Statement + ' ON Creator.Id = TBL_Documents.CreatedByUserId '
SET @Statement = @Statement + ' INNER JOIN TBL_Users Owner '
SET @Statement = @Statement + ' ON Owner.Id = TBL_Documents.OwnerUserId'
SET @Statement = @Statement + ' INNER JOIN TBL_Teams '
SET @Statement = @Statement + ' ON TBL_Teams.StrId = TBL_Documents.OwnerTeamId '
SET @Statement = @Statement + ' INNER JOIN TBL_DocTemplates '
SET @Statement = @Statement + ' INNER JOIN TBL_Categories '
SET @Statement = @Statement + ' INNER JOIN TBL_CategoriesLanguages '
SET @Statement = @Statement + ' ON TBL_CategoriesLanguages.CategoryId = TBL_Categories.Id '
SET @Statement = @Statement + ' ON TBL_Categories.Id = TBL_DocTemplates.CategoryId '
SET @Statement = @Statement + ' INNER JOIN TBL_LanguageValues LV1 '
SET @Statement = @Statement + ' ON LV1.ItemId = TBL_DocTemplates.Id '
SET @Statement = @Statement + ' ON TBL_Documents.DocTemplateId = TBL_DocTemplates.Id '
SET @Statement = @Statement + 'WHERE TBL_Documents.Id IN(' + @DocumentId + ') '
SET @Statement = @Statement + 'AND TBL_DocTemplateProperties.PropertyId = TBL_PropertyValues.PropertyId '
SET @Statement = @Statement + 'AND TBL_CategoriesLanguages.LanguageId = ' + CONVERT(VARCHAR(50), @LanguageId) + ' '
SET @Statement = @Statement + 'AND TBL_LanguageValues.LanguageId = ' + CONVERT(VARCHAR(50), @LanguageId) + ' '
SET @Statement = @Statement + 'AND TBL_LanguageValues.TableName = ''TBL_Properties'' '
SET @Statement = @Statement + 'AND LV1.TableName = ''TBL_DocTemplates'' '
SET @Statement = @Statement + 'AND LV1.LanguageId = ' + CONVERT(VARCHAR(50), @LanguageId) + ' '
SET @Statement = @Statement + 'GROUP BY TBL_Documents.CreationDate, TBL_Documents.ExpiryDate, Creator.FirstName + '' '' + Creator.MiddleName + '' '' + Creator.LastName, '
SET @Statement = @Statement + 'Owner.FirstName + '' '' + Owner.MiddleName + '' '' + Owner.LastName, TBL_Documents.CountViews, TBL_Teams.Name, TBL_CategoriesLanguages.Name, '
SET @Statement = @Statement + 'TBL_PropertyValues.PropertyId, TBL_Properties.PropertyTypeId, TBL_PropertyValues.Value, TBL_DocTemplateProperties.SortOrder, TBL_DocTemplateProperties.IsRequired, '
SET @Statement = @Statement + 'TBL_Teams.StrId, TBL_Categories.Id, TBL_Documents.LockedByUserId, TBL_Documents.LockTime, Owner.EMail, Creator.EMail,TBL_DocTemplates.MaxNumberOfAttachMents, '
SET @Statement = @Statement + 'TBL_LanguageValues.Value, TBL_DocTemplates.Id, LV1.Value, TBL_Documents.ToBeApproved, TBL_Documents.Id '
SET @Statement = @Statement + 'ORDER BY TBL_Documents.Id, TBL_DocTemplateProperties.SortOrder'
EXEC @Statement
return |
Als je dus die laatste EXEC @Statement vervangt door PRINT @Statement, krijg je dus het SQL-Statement naar je scherm geschreven.
Een mogelijke aanroep is:
SP_LoadListDocuments '1030, 1137, 1189', '', 1
SP_LoadListDocuments '1030', 'BAC', 1
Nog even een uitleg van de 3 variabelen die meegegeven kunnen worden
@DocumentId kan zijn: '1,2,3,100, 98, 7' of '10'. Oftewel, een serie van 1 of meer gehele getallen, gescheiden door een komma
@NodeStrId kan elke combinatie van letters zijn. A..Z
@LanguageId is een integer.
Verder werk ik met Windows XP en MS.SQL-Server 2000
