Fout 629 en geen kiestoon
  • TiG
  • Laatst online: 29-06 14:19
Hoi, ik moest net naar een vriendin van mij om daar de computer te maken. Internet deed het niet, ze krijgen de 629 fout. Dus ik kijk in de logfile van de modem (ISDN) staat er dit:
29
30
31
32
33
34
35
36
37
38
06-24-2002 16:38:23.59 - smartvox  Standaard internet modem in use.
06-24-2002 16:38:23.59 - Modem type: smartvox  Standaard internet modem
06-24-2002 16:38:23.59 - Modem inf path: MDMKPNST.INF
06-24-2002 16:38:23.59 - Modem inf section: Modem1
06-24-2002 16:38:23.83 - 115200,N,8,1
06-24-2002 16:38:23.83 - Initializing modem.
06-24-2002 16:38:23.83 - Send: AT<cr>
06-24-2002 16:38:23.83 - Recv: AT<cr>
06-24-2002 16:38:24.03 - Recv: <cr><lf>OK<cr><lf>
06-24-2002 16:38:24.03 - Interpreted response: Ok
06-24-2002 16:38:24.03 - Send: AT &F<cr>
06-24-2002 16:38:24.03 - Recv: AT &F<cr>
06-24-2002 16:38:24.24 - Recv: <cr><lf>OK<cr><lf>
06-24-2002 16:38:24.24 - Interpreted response: Ok
06-24-2002 16:38:24.24 - Send: AT V1 \V1 X2 &D2<cr>
06-24-2002 16:38:24.24 - Recv: AT V1 \V1 X2 &D2<cr>
06-24-2002 16:38:24.44 - Recv: <cr><lf>OK<cr><lf>
06-24-2002 16:38:24.44 - Interpreted response: Ok
06-24-2002 16:38:24.44 - Send: ATS7=60S30=0M1&B49%C1\Q3<cr>
06-24-2002 16:38:24.45 - Recv: ATS7=60S30=0M1&B49%C1\Q3<cr>
06-24-2002 16:38:24.65 - Recv: <cr><lf>OK<cr><lf>
06-24-2002 16:38:24.65 - Interpreted response: Ok
06-24-2002 16:38:24.65 - Send: AT&B54\P1<cr>
06-24-2002 16:38:24.65 - Recv: AT&B54\P1<cr>
06-24-2002 16:38:24.86 - Recv: <cr><lf>OK<cr><lf>
06-24-2002 16:38:24.86 - Interpreted response: Ok
06-24-2002 16:38:24.86 - Dailing.
06-24-2002 16:38:24.86 - Send: ATD#,##########<cr>
06-24-2002 16:38:24.86 - Recv: ATD0,0676002505<cr>
06-24-2002 16:38:32.08 - Recv: <cr><lf>NO DAIL TONE<cr><lf>
06-24-2002 16:38:32.08 - WARNING: Unrecognized response. Retrying...
06-24-2002 16:38:32.09 - Hanging up the modem.
06-24-2002 16:38:32.10 - Session Statistics:
06-24-2002 16:38:32.10 -            Reads : 123 bytes
06-24-2002 16:38:32.10 -            Writes: 77 bytes
06-24-2002 16:38:32.10 - smartvox  Standaard internet modem closed.
De modem heeft dus gewoon geen kiestoon dus. Lijkt me geen softwarematige fout. Toen ben ik alle kabels af gegaan maar alles zat er goed in. Toen nog spanning op de kabel gemeten, die was 40 volt. Dus dat is ook goed. Ik kwam dus tot de conclusie dat de modem gewoon kapot is.
Wat denken jullie?
U gaat door voor de retorische vraag...
  • veldmuis
  • Registratie: Mei 2001
heb je een telefoon die je kan aansluiten op die lijn :? ff testen enzo :)
verder kan je proberen om dat wachten op kiestoon ff uit te zetten :)
als het nog niet lukt..probeer een frisse install om te kijken of het toch niet stiekem aan de software ligt
frisse install op die hd zal niet op prijs gesteld worden, dus ff een ander hdtje aankoppelen enzo :)
normaal gesproken gaat zo een ding niet echt kapot namelijk :)
Aller eerst foutmeldingen in windows kloppen bijna nooit :)
Isdn gebruikt namelijk geen kiestoon.
En het lijkt mij raar dat zoeen smartvox kapot gaat (dat komt zelden tot nooit voor namelijk).
Dus dan blijft de enigste conclusie een software fout.
Probeer even dat ding compleet te uninstallen, dus ook handmatig de dingen uit het register weg te halen. Kijk daarna ff op kpn.com voor de nieuwste drivers voor het betreffende besturings systeem.
Mocht dat allemaal niet werken, dan kan je het op een andere locatie proberen.
  • TiG
Op maandag 24 juni 2002 18:27 schreef [Airwolf] het volgende:
Ik heb wel is met een ISDN toestel gebeld (heb er zelf geen dus kan de lijn zo niet testen) maar toen ik de horen oppakte had ik wel degelijk een kiestoon. Dus het lijkt me niet dat deze uitspraak waar is. Iemand die hier uitsluitsel over kan geven?
isdn heeft volgens mij wel een kiestoon, in ieder geval geeft windows fout 629 aan.
korte oplossing hiervoor if not win nt 2x xp
netwerk in control panel leeg gooien.
reboot
heeft nu als het goed is de isdn gevonden, deze opnieuw installeren.
dun-> dial up networking
de dun vervangen, alles in vakje telnr, niks in netnr (eventueel o voor buitenlijn, ja kan ook met isdn, hangt van de centrale af)
vinkje weg netnr kieseigenschappen gebruiken. nu moet ie werken.
je kan ook je mob nr invullen en kijken oftie overgaat..
meer info www.modemhelp.net :::
Does it ask for the UN/PASS more than once? if so, verify UN/PASS.
2. Check the dialer settings, if ipx/spx is checked and not tcp/ip this would be the cause. In any case the only two things that should be checked are Enable Software Compression and TCP/IP. Also enable DNS. Logon to Network being checked can very well be the culprit.
3. Make sure that the Microsoft VPN Adapter is not selected under connect using.
4. Recreate the dialer.
5. Windows NT? In the Security Tab in Phonebook, make sure that "accept any authentication including clear text" is checked.
6. Check the Network Control Panel settings.
7. Reboot the machine.
8. Modem issue? Use this page for driver updates/init strings..
9. Try disconnecting any phones, caller ID boxes, answering machines, line splitters from line. Plug modem directly into the line. Try using a different phone cord between modem and phone socket. Check for line noise.
More info on Error 629 can be found here:
http://members.tripod.com/paltech/error629.htm
and here:
http://support.microsoft.com/support/kb/articles/q190/5/54.asp
"knpinfo"
Denkt u dat uw toestel kapot is? toets 1
Denkt u dat uw Luidspreker kapot is toet's 2
Denkt u dat uw Toetsjes kapot zijn? toets 3
Maak nu uw keuze :)
