Ricoh 4x4x20x en alle merken gebaseerd op deze brander (o.a. Aopen) kunnen op 6x4x24x mbv een firmware upgrade.
Beter nieuws, <BLOCKQUOTE><font size=1 face=Verdana, Arial, Helvetica>quote:</font><HR>
Ricoh MP7040A/MP7060A supports DAO RAW mode!(?)
Many Ricoh MP7040 users were disappointed cause their drive doesn’t support DAO RAW mode. However it appears to be a new firmware from Delta, which adds DAO RAW mode. Please notice that all following info comes from alt.comp.periphs.cdr newsgroup (Thanks ChaosWolf for sending it).
Please note that we don't take any responsibility about the following info. Do it at YOUR OWN RISK! Email back us however if you do it and report results
Delta drives are in fact OEM Ricoh models. For example the OEM versions of MP7040A are:
Actima ARW4420
Aopen CRW9420
Delta OME-W141
Freecom CD-RW-4420
Imation CD-R 4x4x20
JCCom JCD-2044RW
Mitsubishi CD-RW 4x4x20
Delta has released v1.50 for their Delta OME-W141 which enables DAO RAW. Delta's new firmware could be used in Ricoh's 7040 (and 7060) series models. Just read the following steps:
- For Ricoh MP7040
1) Get v1.50 Delta firmware and renem the bin file to M00a140.bin.
1) Get offical v1.40
2) Extract all files
3) Start Rflash
4) Select the M00a140.bin, press next. You will be asked to push start.
5) Replace the file with the Delta v1.50 firmware that you renamed to M00a140.bin.
6) Press start. After firmware update completes shut down pc and reboot. Your CDR-W now will have new ID (Delta OME-W141). Get CloneCD and enjoy DAO RAW mode!
You should see:
Manufacturer:
Product: OME-W141
Revision: 1.50
Device Capabilities:
Note: This information is provided by the unit, it might be inaccurate.
CloneCD does not use this information!
Can write CD-R Discs: Yes
Can write CD-RW Discs: Yes
Compatible with CloneCD RAW-DAO: Yes
Compatible with CloneCD RAW-DAO Write Simulation: Yes
Supports writing of CD+G RAW-DAO: Yes
Compatible with CloneCD RAW-SAO: Yes
Compatible with CloneCD RAW-SAO Write Simulation: Yes
Supports Burn Proof: No
Same process goes for MP7060a (get v1.70 and rename Delta v1.50 original bin file to m10a170.bin). Notice however that your drive will be downgraded to 4x writing if you decide to get DAO RAW mode..[/quote]
http://www.cdrinfo.com/#newsitem970804800,12182,
