JavaClient fout tijdens comlileren
  • 45 views sinds 30-01-2008
  • MIT
  • Laatst online: 12-08 09:29
MIT
KerMIT
Mensen, ik kom er niet uit. Zijn er hier slimmerikken die dit wel weten?
// Client.java: The client sends the input to the server and receives
// result back from the server
import java.io.*;
import java.net.*;
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
public class Client {
// Main method
public static void main(String[] args)
try
// Create a socket to connect to the server
Socket connectToServer = new Socket("localhost", 8000);
// Create an input stream to receive data from the server
ObjectInputStream isFromServer = new ObjectInputStream(
connectToServer.getInputStream());
// Create an output stream to send data to the server
ObjectOutputStream osToServer =
new ObjectOutputStream(connectToServer.getOutputStream());
// Continuously send radius and receive area from the server
while (true)
// Read the radius from the keyboard
System.out.print("Please enter a code: ");
String code = MyInput.readObject();
// Send the radius to the server
osToServer.writeObject(code);
osToServer.flush();
// Get area from the server
String terug = isFromServer.readObject();
// Print area on the console
System.out.println("code received from the server is "
+ terug);
catch (IOException ex)
System.err.println(ex);
Fout:
C:\Documents and Settings\Out10\Desktop\Tentamen4Java\ITassesment\Client.java:12: illegal start of expression
C:\Documents and Settings\Out10\Desktop\Tentamen4Java\ITassesment\Client.java:51: ';' expected
C:\Documents and Settings\Out10\Desktop\Tentamen4Java\ITassesment\Client.java:52: '}' expected
3 errors
Tool completed with exit code 1
No Signature
  • Alarmnummer
  • Laatst online: 09-07-2024
Alarmnummer
-= Tja =-
kijk nou eens even heeeeeeeel goed... hint.. het heeft iets te maken met '{'
  • D2k
  • Laatst online: 31-08 10:19
D2k
uhm een beetje debuggen kan geen kwaad
overigens svp de volgende keer [code] tags gebruiken
Doet iets met Cloud (MS/IBM)
