Tony Hawk 2 PSX cheatz
  • 167 views sinds 30-01-2008
Ik heb Tony Hawk 2 op de PSX, en dat spel ROELZ!!! Echt superkokel.
Maar het zou leuker zijn als ik een (werkende) cheat had om alle levels te openen.
Iemand??? ;)
Tony Hawk's Pro Skater 2
Strategy
Unlock Everything (No Joke)
When the main menu pulls up enter this code.
x(3) Sqaure,Triangle,Up,Down, Left, up, square triangle x triangle circle x triangle circle. If you entered it correctly the wheel will spin around.
Here is a list of things that come with this code.
Style C "Mcsqueeb" for Tony Hawk
Spiderman which has styles A,B,C,D
All Skater Videos
Custom Skater Video (He Sucks)
Bails Video
SpiderMan Video (Real)
80's Tony Hawk Video
Officer Dick Video
All Cheats under the options menu:
Some are listed above!
Kid Mode
Wire Frame Mode (Hard)
Smooth Mode (Makes levels smooth) Duh!
Disco Mode (Flashing Colors)
There are some more so go see them for yourself.
Infinite Special
During gameplay, pause the game and Hold L1. With L1 held enter in the following code.
X, TRIANGLE, CIRCLE, CIRCLE, UP, LEFT, TRIANGLE, SQUARE.
This code will allow you to do special after special after special. The special bar will never decrease.
Now With 25% More Speed
During gameplay, pause the game and Hold L1. With L1 held enter in the following code. DOWN, SQUARE, TRIANGLE, RIGHT, UP, CIRCLE, DOWN, SQUARE, TRIANGLE, RIGHT, UP, CIRCLE.
This code will make the game play 25% faster.
Chopper Drop in Hawaii
Earn all 3 gold metals with all the characters
Unlock 80s Tony Hawk Skating Video
Earn three gold medals with with McSqueeb.
Unlock Neversolf Bail Video
Earn 3 gold medals with Officer Dick
Unlock Private Carrera
Execute Every Gap in the non-secret levels of the the game
Unlock Spiderman!?
Beat the game with 100% with your own created skater
Unlock Spiderman Skate Video
Win all 3 gold medals with Spiderman
Unlock the Neversoft Makes Video
Earn all 3 gold medals with Private Carrera
All Stats at 10
During game play, pause the game and HOLD L1,With L1held enter in the following code.x,triangle,o,square,triangle,up,down!
Get Fat Skaters
After pausing the game hold L1 then press X(4 times), Left, X(4 times), Left, X(4 times), Left. Do code again to make fatter
Get Thinner Skaters
After pausing the game hold L1 then press X(4 times), Square, X(4 times), Square, X(4 times), Square. Do code again to make fatter
Get Blood Mode
After pausing the game hold L1 then press Right, Up, Square, Triangle. Do code again to turn off
Neversoft Skaters
From the Main Menu press and hold L1, now enter:
UP, SQUARE, SQUARE, TRIANGLE, RIGHT, UP, CIRCLE, TRIANGLE
You'll notice the wheel spin a little bit and then enter the Create a Skater option. Enter in a name of a person that works at Neversoft. Try these names: Joel Jewett (president of Neversoft), Connor Jewett (Joel's son) and Mick West. I'm pretty sure that there are others so check out the back of your manual and experiment with some names in the credits.
bonus area (demo version)
skate over to the section wherre there are trees and grass in the france level. among the trees is a silver colored pole with a stick holding it up. skate over the stick.it will fall through the nearby fence,and opoen a secret area full of bonuses.note:there is a barely visible rail near the left side of the entrance.if you can grind this you will go through the fence,fall in the little hole and
get stuck
spin faster (demo version)
hold L1 or R1 while in the air to spin faster.
Unlock the Neversoft Bails Video
Earn a medal in every competition using any character
Be Officer Dick
Use career mode to finish the game with all objectives
Get 80's Tony Hawk
Use Tony Hawk to finish all objectives in career mode
Special Moves
Do these when the special meter is flashing
Andrew Reynolds
Nosegrab Tailslide: Press Up, Down, Triangle.
Triple Heelflip: Press Up, Right, Square.
Hardflip Late Flip: Press Up, Down, Square.
Bob Burnquist
Rocket Tailslide: Press Up, Down, Triangle.
One Foot Smith: Press Right, Down, Triangle.
Racket Air: Press Left, Down, Circle.
Bucky Lasek
The Big Hitter: Press Left, Down, Triangle.
One Foot Japan: Press Up, Right, Circle.
Fingerflip Airwalk: Press Left, Right, Circle.
Chad Muska
Mute Backflip: Press Up, Down, Circle.
Hurricane: Press Down, Right, Triangle.
Muska Nose Man: Press Right, Up, Circle.
Elissa Steamer
Madonna Tailslide: Press Up, Left, Triangle.
Hospital Flip: Press Left, Right, Square.
Indy Backflip: Press Up, Down, Circle.
Erik Koston
The Fandangle: Press Right, Down, Triangle.
Indy Frontflip: Press Down, Up, Circle.
Pizza Guy: Press Down, Left, Circle.
Geoff Rowley
Rowley Darkslide: Press Left, Right, Triangle.
Double Hardflip: Press Right, Down, Square.
Half Flip Casper: Press Right, Left, Square.
Jamie Thomas
Beni F-Flip Crooks: Press Down, Up, Triangle.
Laser Flip: Press Down, Right, Square.
One Foot Nose Manual: Press Left, Up, Circle.
Kareem Campbell
Ghetto Bird: Press Down, Up, Square.
Nosegrind to Pivot: Press Down, Up, Triangle.
Casper: Press Left, Down, Circle.
Rodney Mullen
Nollieflip Underflip: Press Down, Left, Square.
Casper to 360 Flip: Press Down, Right, Circle.
Heelflip Darkslide: Press Right, Left, Triangle.
Rune Glifberg
One Foot Bluntslide: Press Left, Up, Triangle.
Kickflip One Foot Tailslide: Press Left, Down, Square.
Christ Air: Press Left, Right, Circle.
Steve Caballero
Hang Ten: Press Right, Up, Triangle.
Triple Kickflip: Press Up, Left, Square.
FS 540: Press Right, Left, Circle.
Tony Hawk
Overturn: Press Down, Left, Triangle.
Sacktap: Press Up, Down, Circle.
The 900: You must get a lot of air and press Right, Down, Circle.
Boneless: Press Up, Up, X
McSqeeb (80's Tony Hawk)
Pogo Air: Press Up, Down, Square.
Layback Grind: Press Up, Down, Triangle.
Officer Dick
Assume the Position: Press Left, Down, Circle.
Lazy A. Grind: Press Down, Up, Triangle.
Salute!!: Press Left, Right, Circle.
Yeeeehaw Front Flip: Press Down, Up, Circle.
Neckbreak Grind: Press Left, Right, Triangle.
Private Carrera
55 Ho Slide: Press Left, Right, Triangle.
Double Splits: Press Right, Left, Circle.
Ho-Ho Handplant: Press Up, Down, Triangle.
The Well Hardflip: Press Right, Left, Square.
Somi Spin: Press Left, Down, Circle.
Spider-Man
Spidey Grind: Press Left, Right, Triangle.
Spidey Flip: Press Up, Down, Circle.
Spidey Varial: Press Right, Down, Square.
Does Whatever a Spider Can: Press Left, Right, Square.
Pro Tips
How you land a trick is as important as how you perform in the air. Sloppy executions are penalized, but perfect landings are rewarded.
~It's harder to do tricks with your stance switched, but you'll earn more points for them.
~Linking several small grinds is a great way to crank your bonus multiplier.
~If you can't plant on a passing car, why not on Mexico's raging bull? You'll get 2000 points for it, too.
~In the game, you can't completely clear a level without finding all of the $20, $50, and $100 bills. Watch the skies, as many hover above the lips of the quarter-pipes.
~For a small bonus, jump through the statue of liberty in New York City.
~When in the half-pipe, quickly do 2 tricks in rapid succession to pump up your combo meter.
~Because you receive cash for the competition levels, it's better to restart and try again than to place a low score for less money.
~If you want to perform alot of big tricks, save your money until after the first competition. However, you'll probably fare better in that contest if you spend your cash on basic stat upgrades instead. Either way, it's a risk-once you've spent cash, you cant get it back.
~Manuals are the keys to big combos. Tap up, down or tap down, up to link tw tricks with a manual.
~Get the HUMPTEY HUMPS bonus in Marseilles by jumping over one bowl and landing on the other.
~You'll obtain a bonus by grinding over the Central Park Dealer gap if you hop from the fence to the snack bar counter.
These are the codes you get when you finish the game
Order /Cheat Unlocked /What it does
1st Officer Dick Lets you be Officer Dick - open up 2 specials for you to buy
2nd Skip to Restart You can choose where you restart in the stage
3rd Kid Mode Makes you a child or a smaller version of an adult
4th 80's Tony A "1980's looking" Style C for Tony Hawk
5th Perfect Balance Never bail from grinds, or manuals
6th Special Always Always have full special
7th Stud Cheat
8th Weight Cheat You can make yourself fatter or slimmer
9th WireFrame Mode Everything is in wireframe mode
10th Slow-NIC When jumping, or grinding, it is in super slo-mo
11th Big Head Mode Big head mode
12th Spider-Man Play as Spider-Man
13th Level Flip Level is rotated clockwise 180 degrees, but you stay the same, like a mirror image
14th Sim Mode You go faster, not as high… Is like the Real Thing
15th Smooth Cheat everything is grey, except for pickups like S-K-A-T-E
16th Moon Physics, Chopper Drop and Skate Heaven - Moon Physics is Low Gravity, and the other 2 are New Stages
17th 80's Tony New Movie Another Tony Hawk video, like home video
18th ?? To get this, i THINK you have to get all the gaps
Bye Bye helicopter
To make the helicopter leave in level 1 do any grind on the long part that makes it fly. You will hear it start up then leave.
Matt Hoffman demo
If you go under OPTIONS on the title screen, you can play a demo version of Matt Hoffman's BMX game!
Open The Gym In School 2
In school 2 when you begin the level go to the Opensezmee Rail before the second bell rins.If you make it put on the brakes. While the second bell is ringing grind down the rail. When you reach the bottom the gym doors should be open.
Life is easy :)
Cheats???? :r Bah bah :r
