[OC] MSI 745 Ultra Vcore mod
  • Speedy-J
  • Laatst online: 27-08 07:36
Speedy-J
AMD Enthusiast
Hey tweakers ,ik heb dit weekend aan het docteren geweest. over een voltage mod die ik maar niet kon vinden.
Nu heb ik hem dus maar zelf gefixed ,voor degene die intersse hebben in mijn mod ,ken je terecht bij mij of deze thread van mij.
http://forum.ocworkbench.com/ocwbcgi/ultimatebb.cgi?ubb=get_topic&f=21&t=000344
___________________________________________________________
Hi guys .
Some weeks ago i did promise some guys to do some research about the Vcore modification.
I finnaly come with the positive results that i did it again !
How to increase Vcore voltage goes like this.
Locate the IC "L6911D-B99010143"
You can find it here
Afbeeldingslocatie: http://users.bart.nl/~multatul/MOD/mod1.jpg
Locate PIN 10 of the IC ,you can find it here
Afbeeldingslocatie: http://users.bart.nl/~multatul/mod.JPG
Now ,iff you want 0.1Volts more you got to take an 100Kohm resistor.
It will bring the defauld Vcore to 1.94.
If you want 0.2Volts more ,you can take an 50Khom resistor.
I do prefere an variable 50Kohm and 50Kohm fixed.
Solder the resistor to the pin and ground the other side of the resistor.
Usual i do use my case as ground
Be ware this baby has an OVP ,it will trigger at 2.05Volts.
Until now 0.2V is the max you will get from this IC.
Just give me some time to solve this little problem.
A little movie i have made of my BIOS
You can see i have set the voltage to 1.85,and then you see 1.95 in system health
The film is poor quality but you can see it !
http://users.bart.nl/~multatul/bios.avi
Please do understand ,iff you do not have the knowledge of soldering on your motherboard ,just don't do it !!
I am not resposible for any actions you guys do !
It will void warrenty to your motherboard to.
Cheers and happy modding !
sorry voor mijn slechte engels :)
Veel plezier met de mod en wees voorzichtig !
Ryzen 7 5800@4.7GHz|Asus prime X570 pro|16GB G-Skill trident z rgb|Gigabyte rtx 2070 super|Custom WC van EK|chietech dragon|Corsair 750w rm x
Hoe weet je nou welke pootjes je met elkaar moet verbinden?
  • Speedy-J
Speedy-J
AMD Enthusiast
Jo
een beetje knowhow van die IC's en schema's is wel makkelijk NoStra :)
Wel vet dat je zelf een voltmod uitdoktert...zie ik mezelf niet zo snel doen. Ben bang dat ik iets mol ofzo... Heb al vaak genoeg zonder pc gezeten :)
  • Huupke
  • Laatst online: 03-11-2025
Op maandag 17 juni 2002 11:17 schreef NoStra het volgende:
Hij zegt toch dat je een weerstand tussen pin 10 en de ground moet zetten.
i5-13600KF @ 6.0GHz || Domoticz on Pi3+Pi4 || PV: 14940 Wp || WP: 12kW LG
Ja slimmert...maar hoe weet HIJ nou dat je een weerstand tussen pin 10 en ground moet verbinden? Iedere IC is toch anders?
  • Epsilon
  • Laatst online: 17:45
Epsilon
Avatar revival!
Op maandag 17 juni 2002 14:49 schreef NoStra het volgende:
aan het type nr kan je dus zien hoe een ic in elkaar zit (ja, heb ik ook maar gehoord, want dat soort stof krijg ik volgend jaar pas, als ik naar de HTS ga).
Verder zal het niet meer dan meet en rekenwerk zijn.
  • Speedy-J
Speedy-J
AMD Enthusiast
Hehe precies NoStra ,en daar zit het kunstje
bij de weg ik heb ook al een hele stapel mobo's liggen en teergeliefde thundervogels .
Maar dat wist je al he :)
Meest mobo's werken nog , maar de CPU die er op heb gezeten is naar de eeuwige dondervogel velden :)
hmmm misschien ook maar eens ff gaan kijken bij mijn moederbordje, meer voltage is altijd goed :7
Tsss. Elke techneut kan dit maken.
Op woensdag 17 juli 2002 15:04 schreef Michaeltjuh het volgende:
Redelijk loze opmerking....
Maargoed..ik vind het knap dat iemand voor een nieuw bord een voltmod bedenkt..
Niemand eerder had bedacht voor de MSI 745 Ultra...
Maarja..jij bedenkt je eigen volt mods altijd zelf aan je reactie te horen..
  • B_FORCE
Op maandag 17 juni 2002 14:57 schreef Speedy-J het volgende:
nog een paar mobo's, ik kan er wel een gebruiken....
One World Concepts
