Ik probeer konqueror te installeren ivm het slechte laden van afbeeldingen op het net. Helaas lukt dit niet... ik heb verschillende rpm's geprobeerd. RH 7.3
Qt: 3.0.3
KDE: 3.0.0-10
Konqueror: 3.0.0-12
Dit is de foutmelding die ik krijg:
Qt: 3.0.3
KDE: 3.0.0-10
Konqueror: 3.0.0-12
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
| (no debugging symbols found)...(no debugging symbols found)... (no debugging symbols found)...(no debugging symbols found)... (no debugging symbols found)...(no debugging symbols found)... (no debugging symbols found)...(no debugging symbols found)...[New Thread 1024 (LWP 31264)] 0x420b4769 in wait4 () from /lib/i686/libc.so.6 #0 0x420b4769 in wait4 () from /lib/i686/libc.so.6 #1 0x4213030c in __DTOR_END__ () from /lib/i686/libc.so.6 #2 0x40f52ca3 in waitpid () from /lib/i686/libpthread.so.0 #3 0x4062b8d2 in KCrash::defaultCrashHandler () from /usr/lib/libkdecore-gcc2.96.so.4 #4 0x40f50f75 in pthread_sighandler () from /lib/i686/libpthread.so.0 #5 <signal handler called> #6 0x42080b1b in strlen () from /lib/i686/libc.so.6 #7 0x42051e4d in vfprintf () from /lib/i686/libc.so.6 #8 0x420551d8 in buffered_vfprintf () from /lib/i686/libc.so.6 #9 0x42050347 in vfprintf () from /lib/i686/libc.so.6 #10 0x4205a197 in fprintf () from /lib/i686/libc.so.6 #11 0x080a29d5 in KprintDepProblems () #12 0x080a1b8f in doInstal () #13 0x08092e5a in RPM::doinst () #14 0x080925f7 in RPM::install () #15 0x080741f0 in pkgOptionsI::doPackages () #16 0x08073c41 in pkgOptions::pkginstallButtonClicked () #17 0x080744cd in pkgOptions::qt_invoke () #18 0x40938ec7 in QObject::activate_signal () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #19 0x40938e28 in QObject::activate_signal () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #20 0x40c39a58 in QButton::clicked () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #21 0x409cda57 in QButton::mouseReleaseEvent () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #22 0x40969000 in QWidget::event () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #23 0x408d8ff3 in QApplication::internalNotify () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #24 0x408d8723 in QApplication::notify () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #25 0x40590f1b in KApplication::notify () from /usr/lib/libkdecore-gcc2.96.so.4 #26 0x40881871 in QETWidget::translateMouseEvent () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #27 0x4087ea80 in QApplication::x11ProcessEvent () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #28 0x4087d6ce in QApplication::processNextEvent () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #29 0x408da4bc in QApplication::enter_loop () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #30 0x40a96ade in QDialog::exec () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #31 0x08062c94 in KPACKAGE::openNetFiles () #32 0x08063170 in KPACKAGE::openNetFile () #33 0x08061f4c in KPACKAGE::fileOpen () #34 0x08064339 in KPACKAGE::qt_invoke () #35 0x40938ec7 in QObject::activate_signal () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #36 0x40938e28 in QObject::activate_signal () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #37 0x403c6fe5 in KAction::activated () from /usr/lib/libkdeui-gcc2.96.so.4 #38 0x403b7adb in KAction::slotActivated () from /usr/lib/libkdeui-gcc2.96.so.4 #39 0x403c7203 in KAction::qt_invoke () from /usr/lib/libkdeui-gcc2.96.so.4 #40 0x40938f33 in QObject::activate_signal () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #41 0x40938e28 in QObject::activate_signal () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #42 0x40c39a58 in QButton::clicked () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #43 0x409cda57 in QButton::mouseReleaseEvent () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #44 0x40969000 in QWidget::event () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #45 0x408d8ff3 in QApplication::internalNotify () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #46 0x408d8723 in QApplication::notify () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #47 0x40590f1b in KApplication::notify () from /usr/lib/libkdecore-gcc2.96.so.4 #48 0x40881871 in QETWidget::translateMouseEvent () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #49 0x4087ea80 in QApplication::x11ProcessEvent () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #50 0x4087d6ce in QApplication::processNextEvent () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #51 0x408da4bc in QApplication::enter_loop () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #52 0x4087d637 in QApplication::exec () from /usr/lib/qt3-gcc2.96/lib/libqt-mt.so.3 #53 0x0807a05d in main () #54 0x42017499 in __libc_start_main () from /lib/i686/libc.so.6 |
"The trouble with quotes from the Internet is that you can never know if they are genuine." - Elvis Presley | Niet met me eens ? DM ME
