Operation Flashpoint Upgrade?? (corrupt)
  • Zware Unit
  • Laatst online: 07-09 17:52
Beste Tweakers,
Tijdens het installeren van de Update Patch 1.2 voor Operation Flashpoint kreeg ik een vreemde foutmelding.
De melding is:
Operation Flashpoint is not isntalled on your computer or installation is corrupted.
Ik heb de orginele cd`s en patch 1.1 geinstalleerd. Voordat ik de nieuwste patches kan installeren moet ik eerst 1.2 en 1.3 installen.
Ik heb de verificatietool gebruikt, maar deze geeft de zelfde melding (ftp://www.flashpoint1985.com/fp/CheckOFP_1_20.zip)
Aan de helpfile heb ik niets (zoals je hier beneden duidelijk kan zien!)
What is CheckOFP
CheckOFP is an utility that will check if your instalation of Operation
Flashpoint is good. We created this utility because neither the European
version CD disc nor 1.10 patch does not perform any such verification.
If you are encountering strange behaviour (random crashes, strange error
messages) with your OFP instalation, please use this utility to check if
the game is installed properly.
Supported OFP versions:
1.00 (European, European Win2K fix)
1.10 (European)
1.20 (US + European)
Supported addons:
Kozlice
Vulcan
Trabant
Su25
AH64 (Apache)
CH47D (Chinook)
HMMWV
What to do is some files are corrupted?
(1) Backup your 'Users' directory to some safe place on your hard disc.
(2) Uninstall OFP.
(3) Delete Operation Flashpoint directory.
(4) Install OFP from CD disc.
(5) Run OFPCheck. If no files are corrupted, follow step 9.
(6) Copy files that are reported as corrupted from your CD disc.
(7) Run OFPCheck.
(8) If some file are still corrupted, follow step 6.
(9) Restore your 'Users' directory. Now you have OFP version 1.00
that is verified and contains no error.
(10) Copy your Operation Flashpoint directory somewhere. You will need it
in case some patch installation will fail.
(11) Install any patches / addons you want.
(12) If patch failed to install (CRC error), follow 14.
(12) Run OFPCheck.
(13) If you do not see any corrupted file now, you are done.
(14) You see some corrupted files. Your patch (or some addon) is probably
corrupted. Try to obtain it on CD from reliable source or download from
reliable location.
(15) Restore verified version 1.00 (copy files you stored in step 10 to
your OFP directory).
(16) Follow step 11.
If you have any problems with this utility, please check our forums at
http://www.flashpoint1985.com .
Version specific notes:
US version, European 1.20 version
While this utility does support OFP version 1.20, this version already
contains file verification, so there is normally no need to use OFPCheck.
The only case when it makes sense to use it for 1.20 version is if you
want to make sure OFP files did not get corrupted or overwritten while
stored on your hard drive, which is very rare.
Czech version
This utility does not work with Czech version of the game.
al vast bedankt voor de hulp!
... all gonna wonder how you ever thought you could live so large and leave so little for the rest of us...
  • b-gone
  • Laatst online: 16-07 15:24
Wel raar, ja. Kan je niet eerst 1.1 erop zetten? Of heb je die niet (meer)? Is niet verplicht, I know, maar ik heb laatst ook wat gemekker met herinst gehad toen ik van 1.0 ->1.20>1.30>1.46 wilde. Ik heb toen die Win2K fix erop gezet em toen 1.1 en toen ging het
ps: is die patch-file niet toevallig RO (read-only)?
  • Zware Unit
Bij alle patches (dus ook 1.1) geeft hij de zelfde foutmelding. Lijkt er net op of hij een key uit het register mist of zo?
Weet je misschien waarop (of welk bestand) hij controleerd.
Begrijp het niet... Werkte bij mijn vorige systeem probleemloos...
  • b-gone
Vorige systeem: was dat andere hardware of ander O/S? Of beide?
Misschien wat specs erbij
Hij mist idd iets in het register...ik kan het spel ook nooit meer spelen als ik format C: gedaan (als OPF op d: staat) Moet je hem ff opnieuw installeren
  • Zware Unit
Heb hem al opnieuw geinstalleerd (3x nu al) en bij patch 1.2 blijft hij deze fout herhalen (en kan ik dus 1.3 en 1.46 niet installen :()
Specs:
Celeron 1@1.4 ghz
Asus Tusl2-c (latest bios)
256 pc 133 basics
Asus 8170 Geforce 4 mx 440 (330 - 491 stable)
Ibm 60xgp 40 gb disk
Antec 830 + 3 x papst
W2K sp2 IE 5.5 (alle patches)
Lg Burner 8x4x32 + Noname 50 x cd-rom
Voor de rest, het systeem loopt als een trein. DirectX geeft geen foutmeldingen, 3d mark 2001se komt boven de 5000 en in de W2K logs komen geen fouten voor!
Heb twee schijven (c+d). c draait op ntfs en d op fat32.
Heb het spel geinstalleerd onder de administrator en speel hem op een user account (ook onder administrator geeft hij dezelfde foutmelding!)
  • Kwistnix
  • Laatst online: 19:39
Op vrijdag 14 juni 2002 12:53 schreef Richard95 het volgende:
Erm, da's meestal als je het windows register wegpleurt en je heb applicaties op een nadere partitie staan die het register gebruiken, die regkeys zijn er niet voor niets :)
  • Zware Unit
Is iemand dit probleem tegen gekomen... Kan er namelijk niets over terug vinden op de website van Operation Flashpoint. Wel CD-problemen enz. maar niets over dit probleem. Versie 1.00 sucks namelijk bigtime en tevens is mp onmogelijk geworden omdat iedere server minimaal 1.3 gebruikt tegenwoordig.
Help me, het is namelijk zo`n verschrikkelijk coole game! :7
moet je eens een mailtje naar die gasten sturen van dat flashpoint gebeuren...
Misschien moet je ook eens die Gold upgrade kopen en die proberen te installeren. Maarja zonder die upgrade zou die ook gewoon die update moeten installeren
  • b-gone
Op google deze link gevonden
http://www.flashpoint1985.com/cgi-bin/ikonboard/topic.cgi?forum=4&topic=1935
Anders inderdaad contact met support Codemasters
  • Loev
  • Laatst online: 09-10 11:58
Idd heel erg raar.
Kan nergens lezen of je Operation Flahpoint officeel hebt, heb je hem wel officeel? :)
Oh ja Red Hammer kopen heeft ook geen zin want dan moet je eerst 1.30 installeren.
  • Zware Unit
Tuurlijk heb ik de orginele cd`s!
Dit spel was het duidelijk waard na het spelen van de demo..
Het probleem zit in W2K (bij mij tenminste)
Ergens een fout in het register, ik heb namelijk het register doorgelopen en kwam 0 (nul) maal het woord flashpoint tegen :(
  • b-gone
Dat van de registry is een goeie....Heb je misschien de max grootte van je registry (te) laag gezet? Het kan dan zijn dat e.e.a. niet geregistreerd kan worden....heb ik althans al eens gehad
Ik heb de cd niet hier (ben op mu werk) maar staan niet de .reg bestanden los op de cd? Dan zou je die eens kunnen dbl klikken. Verder zou ik die Win2000 patch erop zetten (is voor het opstart-probleem, I know, maar wie weet lost dat het wel op).
