RH 7.2 + Shorewall
Na aanleiding van:
[topic=508666/1/500]
en
http://gathering.tweakers.net/forum/list_message/13880626#13880626
ben ik aan het kijken geweest op Shorewall
Nadat ik, zoals vermeld in op pagina's van Shorewall de interfaces, zones, rules en masq files heb aangepast aan mijn setup kan ik niet pingen vanuit mijn client naar het internet.
[b]Set-up:[/b]
eth0 IP: 10.0.0.150 verbonden met ADSL Modem (IP: 10.0.0.138)
eth1 IP: 192.168.1.1 interne Lan (192.168.1.* scope)
interfaces
#ZONE  INTERFACE BROADCAST OPTIONS
net eth0 detect noping
loc eth1 detect routestopped
#LAST LINE -- ADD YOUR ENTRIES BEFORE THIS ONE -- DO NOT REMOVE
zones
#ZONE DISPLAY  COMMENTS
net Net  Internet
loc Local  Local networks
dmz DMZ  Demilitarized zone
#LAST LINE - ADD YOUR ENTRIES ABOVE THIS ONE - DO NOT REMOVE
masq
#INTERFACE     SUBNET  ADDRESS
eth0   192.168.0.0/24
#LAST LINE -- ADD YOUR ENTRIES ABOVE THIS LINE -- DO NOT REMOVE
rules
#ACTION  SOURCE  DEST    PROTO DEST    SOURCE    ORIGINAL
#                      PORT    PORT(S)    DEST
ACCEPT loc net icmp echo-request
  • igmar
  • Laatst online: 29-06 18:56
igmar
ISO20022
Na aanleiding van:
[b]Set-up:[/b]
interfaces
zones
net Net  Internet
masq
eth0   192.168.0.0/24
rules
#                      PORT    PORT(S)    DEST
Je connectie gaat over ppp0, niet over eth0.
Als ik kijk in de example die ook in de interfaces files staan:
#   Example 1:  Suppose you have eth0 connected to a DSL modem and
#           eth1 connected to your local network and that your
#           local subnet is 192.168.1.0/24. The interface gets
#           it's IP address via DHCP from subnet
#           206.191.149.192/27 and you want pings from the internet
#           to be ignored. You interface a DMZ with subnet
#           192.168.2.0/24 using eth2. You want to be able to
#           access the firewall from the local network when the
#           firewall is stopped.
#           Your entries for this setup would look like:
#           net eth0    206.191.149.223 noping,dhcp
#           local   eth1    192.168.1.255   routestopped
#           dmz eth2    192.168.2.255
Dan is dat volgens mij niet zo.
schopje
Iemand een idee?
