29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
| 34 in tag: area the following required attributes are missing: alt
34 The value 22,0,103,17 is not valid for the "coords" attribute in HTML32. The value is valid if double quoted.
34 22,0,103,17 is not a valid value for the "coords" attribute in any of the currently active versions. See the above warnings for more details.
35 in tag: area the following required attributes are missing: alt
35 The value 117,0,205,17 is not valid for the "coords" attribute in HTML32. The value is valid if double quoted.
35 117,0,205,17 is not a valid value for the "coords" attribute in any of the currently active versions. See the above warnings for more details.
36 in tag: area the following required attributes are missing: alt
36 The value 219,0,274,17 is not valid for the "coords" attribute in HTML32. The value is valid if double quoted.
36 219,0,274,17 is not a valid value for the "coords" attribute in any of the currently active versions. See the above warnings for more details.
42 The tag: "td" doesn't have an attribute: "background" in currently active versions.
43 The tag: "td" doesn't have an attribute: "background" in currently active versions.
44 The tag: "td" doesn't have an attribute: "background" in currently active versions.
47 The tag: "td" doesn't have an attribute: "background" in currently active versions.
50 The tag:"table" is not allowed within: "span" It is only allowed within: button, del, fieldset, iframe, ins, noframes, noscript, object, td, th.
50 The tag: "table" doesn't have an attribute: "height" in currently active versions.
56 The tag: "br" has an XML style closing syntax for an empty element even though version: "HTML4" is not an XML tag language.
58 The tag: "br" has an XML style closing syntax for an empty element even though version: "HTML4" is not an XML tag language.
60 The tag: "br" has an XML style closing syntax for an empty element even though version: "HTML4" is not an XML tag language.
62 The tag: "br" has an XML style closing syntax for an empty element even though version: "HTML4" is not an XML tag language.
64 The tag: "br" has an XML style closing syntax for an empty element even though version: "HTML4" is not an XML tag language.
71 The tag: "td" doesn't have an attribute: "background" in currently active versions.
74 The tag: "td" doesn't have an attribute: "background" in currently active versions.
75 The tag: "td" doesn't have an attribute: "background" in currently active versions.
76 The tag: "td" doesn't have an attribute: "background" in currently active versions.
82 The tag: "td" doesn't have an attribute: "background" in currently active versions.
83 The tag: "td" doesn't have an attribute: "background" in currently active versions.
84 The tag: "td" doesn't have an attribute: "background" in currently active versions.
87 The tag: "td" doesn't have an attribute: "background" in currently active versions.
90 The tag:"table" is not allowed within: "span" It is only allowed within: button, del, fieldset, iframe, ins, noframes, noscript, object, td, th.
90 The tag: "table" doesn't have an attribute: "height" in currently active versions.
96 The tag: "br" has an XML style closing syntax for an empty element even though version: "HTML4" is not an XML tag language.
98 The tag: "br" has an XML style closing syntax for an empty element even though version: "HTML4" is not an XML tag language.
120 0 is not a valid value for the "width" attribute in HTML32. Valid values for this attribute are: Dynamic expression, positive non zero integer.
180 0 is not a valid value for the "width" attribute in HTML32. Valid values for this attribute are: Dynamic expression, positive non zero integer.
190 0 is not a valid value for the "width" attribute in HTML32. Valid values for this attribute are: Dynamic expression, positive non zero integer.
200 0 is not a valid value for the "width" attribute in HTML32. Valid values for this attribute are: Dynamic expression, positive non zero integer.
210 0 is not a valid value for the "width" attribute in HTML32. Valid values for this attribute are: Dynamic expression, positive non zero integer.
220 0 is not a valid value for the "width" attribute in HTML32. Valid values for this attribute are: Dynamic expression, positive non zero integer.
230 0 is not a valid value for the "width" attribute in HTML32. Valid values for this attribute are: Dynamic expression, positive non zero integer.
240 0 is not a valid value for the "width" attribute in HTML32. Valid values for this attribute are: Dynamic expression, positive non zero integer.
262 The tag: "td" doesn't have an attribute: "background" in currently active versions.
265 The tag: "td" doesn't have an attribute: "background" in currently active versions.
266 The tag: "td" doesn't have an attribute: "background" in currently active versions.
267 The tag: "td" doesn't have an attribute: "background" in currently active versions.
273 The tag: "td" doesn't have an attribute: "background" in currently active versions.
274 The tag: "td" doesn't have an attribute: "background" in currently active versions.
275 The tag: "td" doesn't have an attribute: "background" in currently active versions.
278 The tag: "td" doesn't have an attribute: "background" in currently active versions.
280 The tag: "table" doesn't have an attribute: "height" in currently active versions.
283 The tag: "td" doesn't have an attribute: "background" in currently active versions.
286 The tag: "td" doesn't have an attribute: "background" in currently active versions.
287 The tag: "td" doesn't have an attribute: "background" in currently active versions.
288 The tag: "td" doesn't have an attribute: "background" in currently active versions.
294 The tag: "td" doesn't have an attribute: "background" in currently active versions.
68 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
259 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
281 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
304 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
306 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
308 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
310 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
312 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
314 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
316 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
318 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
320 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
322 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
323 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
371 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
391 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
415 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
529 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
532 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
535 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
538 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
541 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
544 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
547 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
550 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
560 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
563 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
568 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
573 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
583 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
587 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
590 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
593 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
597 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
600 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
603 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
606 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
609 ASCII value greater than 127 found, HTML documents should not contain these values. Consider using instead.
295 The tag: "td" doesn't have an attribute: "background" in currently active versions.
296 The tag: "td" doesn't have an attribute: "background" in currently active versions.
299 The tag: "td" doesn't have an attribute: "background" in currently active versions.
301 The tag: "table" doesn't have an attribute: "height" in currently active versions.
326 The tag: "td" doesn't have an attribute: "background" in currently active versions.
329 The tag: "td" doesn't have an attribute: "background" in currently active versions.
330 The tag: "td" doesn't have an attribute: "background" in currently active versions.
331 The tag: "td" doesn't have an attribute: "background" in currently active versions.
334 In HTML 4.0, CENTER is deprecated.
337 The value _BLANK is not valid for the "target" attribute in HTML4. The value is valid if double quoted.
337 _BLANK is not a valid value for the "target" attribute in any of the currently active versions. See the above warnings for more details.
339 The value _BLANK is not valid for the "target" attribute in HTML4. The value is valid if double quoted.
339 _BLANK is not a valid value for the "target" attribute in any of the currently active versions. See the above warnings for more details.
351 The tag: "td" doesn't have an attribute: "background" in currently active versions.
355 The tag: "td" doesn't have an attribute: "background" in currently active versions.
359 The tag: "td" doesn't have an attribute: "background" in currently active versions.
363 The tag: "td" doesn't have an attribute: "background" in currently active versions.
367 The tag: "td" doesn't have an attribute: "background" in currently active versions.
371 The tag: "td" doesn't have an attribute: "background" in currently active versions.
375 The tag: "td" doesn't have an attribute: "background" in currently active versions.
379 The tag: "td" doesn't have an attribute: "background" in currently active versions.
383 The tag: "td" doesn't have an attribute: "background" in currently active versions.
387 The tag: "td" doesn't have an attribute: "background" in currently active versions.
391 The tag: "td" doesn't have an attribute: "background" in currently active versions.
395 The tag: "td" doesn't have an attribute: "background" in currently active versions.
399 The tag: "td" doesn't have an attribute: "background" in currently active versions.
403 The tag: "td" doesn't have an attribute: "background" in currently active versions.
407 The tag: "td" doesn't have an attribute: "background" in currently active versions.
411 The tag: "td" doesn't have an attribute: "background" in currently active versions.
415 The tag: "td" doesn't have an attribute: "background" in currently active versions.
419 The tag: "td" doesn't have an attribute: "background" in currently active versions.
423 The tag: "td" doesn't have an attribute: "background" in currently active versions.
427 The tag: "td" doesn't have an attribute: "background" in currently active versions.
431 The tag: "td" doesn't have an attribute: "background" in currently active versions.
435 The tag: "td" doesn't have an attribute: "background" in currently active versions.
439 The tag: "td" doesn't have an attribute: "background" in currently active versions.
443 The tag: "td" doesn't have an attribute: "background" in currently active versions.
448 The tag: "td" doesn't have an attribute: "background" in currently active versions.
452 The tag:"form" is not allowed within: "table" It is only allowed within: del, fieldset, iframe, ins, noframes, noscript, object, td, th.
454 The tag:"tr" is not allowed within: "form" It is only allowed within: table, tbody, tfoot, thead.
455 The tag: "td" doesn't have an attribute: "background" in currently active versions.
457 The tag:"table" is not allowed within: "span" It is only allowed within: button, del, fieldset, iframe, ins, noframes, noscript, object, td, th.
457 The tag: "table" doesn't have an attribute: "height" in currently active versions.
466 The value ZOEK_ITEMS is not valid for the "name" attribute in HTML20. The value is valid if double quoted.
466 ZOEK_ITEMS is not a valid value for the "name" attribute in any of the currently active versions. See the above warnings for more details.
467 The value ZOEK_REACTIES is not valid for the "name" attribute in HTML20. The value is valid if double quoted.
467 ZOEK_REACTIES is not a valid value for the "name" attribute in any of the currently active versions. See the above warnings for more details.
472 The tag: "td" doesn't have an attribute: "background" in currently active versions.
478 In HTML 4.0, CENTER is deprecated.
491 The tag: "table" doesn't have an attribute: "height" in currently active versions.
506 The value #TMMAP is not valid for the "usemap" attribute in HTML32. The value is valid if double quoted.
506 #TMMAP is not a valid value for the "usemap" attribute in any of the currently active versions. See the above warnings for more details.
617 The value _BLANK is not valid for the "target" attribute in HTML4. The value is valid if double quoted.
617 _BLANK is not a valid value for the "target" attribute in any of the currently active versions. See the above warnings for more details. |
