boot-vertraging door autodetectie hda/hdb
Dit:
<4>hda: IRQ probe failed (0xfffffef8)
<4>hda: no response (status = 0x0a), resetting drive
<4>hdb: IRQ probe failed (0xfffffef8)
<4>hdb: no response (status = 0x0a), resetting drive
in mijn log:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
Jun  9 22:23:06 fuego kernel: hdc: command error: status=0x51 { DriveReady SeekComplete Error }
Jun  9 22:23:06 fuego kernel: hdc: command error: error=0x51
Jun  9 22:23:06 fuego kernel: end_request: I/O error, dev 16:00 (hdc), sector 0
Jun  9 22:23:06 fuego kernel: end_request: I/O error, dev 16:00 (hdc), sector 4
Jun  9 22:23:06 fuego kernel: FAT: unable to read boot sector
Jun  9 22:23:18 fuego kernel: hdc: command error: status=0x51 { DriveReady SeekComplete Error }
Jun  9 22:23:18 fuego kernel: hdc: command error: error=0x51
Jun  9 22:23:18 fuego kernel: end_request: I/O error, dev 16:00 (hdc), sector 0
Jun  9 22:23:18 fuego kernel: end_request: I/O error, dev 16:00 (hdc), sector 1
Jun  9 22:23:18 fuego kernel: end_request: I/O error, dev 16:00 (hdc), sector 2
Jun  9 22:23:18 fuego kernel: end_request: I/O error, dev 16:00 (hdc), sector 3
Jun  9 22:23:18 fuego kernel: end_request: I/O error, dev 16:00 (hdc), sector 4
Jun  9 22:23:18 fuego kernel: end_request: I/O error, dev 16:00 (hdc), sector 5
Jun  9 22:23:18 fuego kernel: end_request: I/O error, dev 16:00 (hdc), sector 6
Jun  9 22:23:18 fuego kernel: end_request: I/O error, dev 16:00 (hdc), sector 7
Jun  9 22:23:18 fuego kernel: FAT: unable to read boot sector
Jun  9 22:24:03 fuego kernel: hdc: command error: status=0x51 { DriveReady SeekComplete Error }
Jun  9 22:24:03 fuego kernel: hdc: command error: error=0x51
Jun  9 22:24:03 fuego kernel: end_request: I/O error, dev 16:00 (hdc), sector 0
Jun  9 22:24:03 fuego kernel: end_request: I/O error, dev 16:00 (hdc), sector 4
Jun  9 22:24:03 fuego kernel: FAT: unable to read boot sector
zorgt voor een vertraging van 30 sec. tijdens het booten, kan ik dit nergens uitzetten?
  • capedro
  • Laatst online: 20-05 09:15
Op dinsdag 11 juni 2002 18:22 schreef ru1 het volgende:
Dit:
Mischien met "append=" de zaken hard instellen tijdens het booten!
* capedro moet ff verder zoeken hoe je dat precies moet doen!
My weblog
  • GeeMoney
  • Laatst online: 10:36
Dit:
hier had ik ook last van totdat ik me secondary master ging benutten >:)
hij checked als het ware je Prim. Master en Prim. Slave en Secondary Master voor zover ik weet :) nu ik dara op alle 3 dus apparaten heb is het probleem ook weg, maar ik denk dat jij alleen een cd-rom heb?
mijn hd zit op een promise hd controller voor udma100, op gewone ide heb ik alleen de cdrom :/
[kick]
  • igmar
  • Laatst online: 09-09 19:53
igmar
ISO20022
Dit:
IDE, ATA and ATAPI block devices -> Use multimode by default (CONFIG_IDEDISK_MULTI_MODE) aanzetten, en recompilen.
Is dit toevallig een hpt raid controller? Heb nml hetzelfde probleem gehad. Na een bios update was alles weer in orde.
Die had ik al aanstaan :/...
Ik heb trouwens een Promise controller, de gene die op een Asus A7V zit. Ik heb dat FastTrak van Promise in mijn BIOS gegooid, dat zorgt trouwens ook voor 10 seconden vertraging tijdens het booten bij het autodetecten.
nog maar een kickje, is erg irritant dit... weet echt niemand wat je hier aan kan doen?
ik heb een asus a7v plak met 1 hd aangesloten op de ata100 controller.
bij het booten heeft ie ook een vertraging van 20 seconden ofzo in het bios tijdens de detectie.
  • GeeMoney
Op donderdag 27 juni 2002 22:18 schreef ru1 het volgende:
die vertraging tijdens detectie van Bios komt omdat ie nog zoekt naar de anderee paparaten dit kan je wel uitzetten in je bios, gewoon configgen dat je geen andere hd's of cd-roms hebt.
tijdens het booten van Debian ben ik er ook nog niet uit. ik heb het niet meer omdat ik wat hij checken dus oo kdaadwerkelijk aanwezig is.
Topic is alweer wat ouder, maar ik liep tegen hetzelfde probleem aan -- en vond op GoT verder geen antwoord. De oplossing zit hem in kernel-parameters. In mijn geval loste het toevoegen van de regel
append="hda=noprobe hdb=noprobe"
aan lilo.conf het probleem op.
