Ik krijg de volgende foutmelding zodra ik op een knop druk (swing). Hierdoor worden een aantal commando's verstuurt (aansturing oscilloscoop). Ik gebruik Java 2 JDK 1.3.1 en Comm 2.0 (goed geinstalleerd) op een Windows 2000 Systeem.
Hier is mijn code:
Communicatie.java
Acquisitie.java
Volgens de foutmelding zit de fout bij "Deze regel -->"
Wie weet wat ik fout doe (of juist niet)??
29
30
31
32
33
34
35
36
37
38
39
40
41
| OutputStream write error: java.io.IOException: write error
at com.sun.comm.Win32SerialPort.write(Win32SerialPort.java:677)
at com.sun.comm.Win32SerialPort.write(Win32SerialPort.java:664)
at com.sun.comm.Win32SerialOutputStream.write(Win32SerialOutputStream.ja
va:34)
at Communicatie.Uitvoer(Communicatie.java:167)
at Acquisitie.Verzenden(Acquisitie.java:77)
at Acquisitie$MyActionListener.actionPerformed(Acquisitie.java:105)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:14
45)
at javax.swing.AbstractButton$ForwardActionEvents.actionPerformed(Abstra
ctButton.java:1499)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel
.java:373)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:245
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonL
istener.java:211)
at java.awt.Component.processMouseEvent(Component.java:3710)
at java.awt.Component.processEvent(Component.java:3539)
at java.awt.Container.processEvent(Container.java:1159)
at java.awt.Component.dispatchEventImpl(Component.java:2588)
at java.awt.Container.dispatchEventImpl(Container.java:1208)
at java.awt.Component.dispatchEvent(Component.java:2492)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:2446
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:2211)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:2120)
at java.awt.Container.dispatchEventImpl(Container.java:1195)
at java.awt.Window.dispatchEventImpl(Window.java:921)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:334)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchTh
read.java:126)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThre
ad.java:93)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:88)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:80)
nativeFinalize: Error closing Handle 6 |
Hier is mijn code:
Communicatie.java
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
| import java.io.*;
import java.util.*;
import javax.comm.*;
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
/** Deze class zorgt voor de juiste communicatie met de RS232
* en stuurt de commando naar de SIN10
public class Communicatie implements SerialPortEventListener, CommPortOwnershipListener
private CommPortIdentifier poortID;
private SerialPort serialPort;
private String poortNaam = "COM2";
private InputStream inputStream;
private OutputStream outputStream;
private TextArea txtRes;
private final char LF = 10; // Line Feed
/** Deze constructor initialiseert de RS232 en maakt een connectie met RS232. */
public Communicatie(TextArea txtRes)
this.txtRes = txtRes;
/** Deze functie zorgt voor de juiste afhandeling van de data. */
public void openConnectie()
try
//PoortID kijkt of de gewenste poort aanwezig is.
poortID = CommPortIdentifier.getPortIdentifier(poortNaam);
catch (NoSuchPortException nspe)
System.err.println("Poort is bestaat niet!");
nspe.printStackTrace();
try
// Opent de seriele poort voor de eigenaar "Communicatie" met een vertraging van 2 sec.
serialPort = (SerialPort)poortID.open("Communicatie", 2000);
catch (PortInUseException piue)
try
// Stel de juiste parameters in.
serialPort.setSerialPortParams(9600, SerialPort.DATABITS_8, SerialPort.STOPBITS_1, SerialPort.PARITY_NONE);
//serialPort.setFlowControlMode(SerialPort.FLOWCONTROL_NONE);
catch(UnsupportedCommOperationException ucoe)
try
// Maakt de benodige streams aan.
outputStream = serialPort.getOutputStream();
inputStream = serialPort.getInputStream();
catch(IOException ioe)
System.err.println("Kan de streams niet openen.");
serialPort.close();
ioe.printStackTrace();
try
// Zorgt ervoor dat de RS232 luistert naar events.
serialPort.addEventListener(this);
catch (TooManyListenersException e)
serialPort.notifyOnDataAvailable(true); // De RS232 weet dan wanneer er data beschikbaar is.
serialPort.notifyOnOutputEmpty(true); // De RS232 weet dan wanneer er geen data meer beschikbaar is.
poortID.addPortOwnershipListener(this); // De RS232 weet dan wie de baas is over de RS232.
/** Deze functie zorgt dat alle streams en de RS232 gesloten worden. */
private void sluitConnectie()
if (serialPort != null)
try
outputStream.close();
inputStream.close();
catch (IOException e)
System.err.println(e);
serialPort.close();
poortID.removePortOwnershipListener(this);
* Deze functie zorgt voor de juiste handeling bij de verschillende RS232 events.
public void serialEvent(SerialPortEvent event)
switch(event.getEventType())
case SerialPortEvent.OUTPUT_BUFFER_EMPTY: // Geen data meer beschikbaar
break;
case SerialPortEvent.DATA_AVAILABLE: //Data beschikbaar
* Leest wat er in de RS232 binnenkomt en laat dit zien op het scherm.
StringBuffer readBuffer = new StringBuffer(); // Buffer
int data = 0;
try
data = inputStream.read();
if (data > 0)
readBuffer.append((char)data); // Buffer wordt gevult met karakters.
System.out.print(new String(readBuffer)); // Toon de volledige inhoud van de buffer.
txtRes.append(new String(readBuffer)); // zowel als in het uitvoerscherm (dos-venster), als in de textarea.
break;
* Als er van eigenaar van de RS232 gewisseld wordt.
public void ownershipChange(int type)
if (type == CommPortOwnershipListener.PORT_OWNERSHIP_REQUESTED)
sluitConnectie();
/** Deze functie zorgt ervoor dat de commando op de juiste manier naar de SIN10 worden verzonden. */
public void Uitvoer(String commando)
try
char[] com_kar = commando.toCharArray(); // Zet het commando om in een char array.
for(int i = 0; i < commando.length(); i++)
Deze regel--> outputStream.write((int)com_kar[i]); // Verzendt het commando per karakter naar de SIN10
outputStream.write(LF);
System.err.println("OutputStream write error: " + e);
sluitConnectie();
Acquisitie.java
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
import java.awt.*;
import java.io.*;
public class Acquisitie extends JFrame
// private knoppen, labels enz.
private JLabel jLabel1;
private JLabel jLabel2;
private JButton btnOpnieuw;
private FileOutputStream uitvoer;
private Communicatie connectie;
public Acquisitie()
initComponents();
private void initComponents()
txtRes = new TextArea();
jLabel1 = new JLabel();
jLabel2 = new JLabel();
btnOpnieuw = new JButton();
getContentPane().setLayout(null);
addWindowListener (new WindowAdapter ()
public void windowClosing (WindowEvent evt)
System.exit(0);
getContentPane ().add (txtRes);
txtRes.setBounds (380, 30, 280, 210);
jLabel1.setText ("Ontvangen data:");
getContentPane ().add (jLabel1);
jLabel1.setBounds (270, 30, 92, 17);
btnOpnieuw.setText ("Opnieuw");
getContentPane ().add (btnOpnieuw);
btnOpnieuw.setBounds (40, 90, 95, 27);
btnOpnieuw.addActionListener(new MyActionListener());
pack ();
Dimension screenSize = Toolkit.getDefaultToolkit().getScreenSize();
setSize(new Dimension(700, 300));
setLocation((screenSize.width-800)/2,(screenSize.height-450)/2);
public static void main(String args[])
new Acquisitie ().show ();
/** Functie voor het verzenden van de commando.
* @param commando de commando die men wilt versturen.
public void Verzenden(String commando)
connectie = new Communicatie(txtRes); // voert de constructor uit van de communicatie klasse
connectie.openConnectie(); // Voert de functie openConnectie uit van de communicatie klasse.
Deze regel--> connectie.Uitvoer(commando); // Voert de functie Uitvoer uit van de communicatie klasse.
//Ophalen("OsciData");
private void Ophalen(String bestandsnaam)
byte data[] = txtRes.getText().getBytes();
try
uitvoer = new FileOutputStream(bestandsnaam + ".csv");
uitvoer.write(data);
uitvoer.close();
catch (IOException ioe)
/** MyActionListener handeld de acties af van de knop en de textfield. */
public class MyActionListener implements ActionListener
public void actionPerformed(ActionEvent event)
try
Verzenden("DATA:SOURCE CH1"); // Verzendt wat men invoert.
Thread.sleep(500);
Verzenden("DATA:ENCDG ASCII");
Thread.sleep(500);
Deze regel--> Verzenden("DATA:WIDTH 1");
Thread.sleep(500);
Verzenden("DATA:START 1");
Thread.sleep(500);
Verzenden("DATA:STOP 5000");
Thread.sleep(500);
Verzenden("CURVE?");
catch(Exception e)
