kom niet verder met Super mario advance2 :(
  • DrNizeGuy
  • Laatst online: 21:23
ik kom dus niet verder met Super Mario Advance2 (super mario world)
ik ben bij bowser's castle, heb de sterren werelden en de special world, maar ik zit nog lang niet op alle levels.
ik weet dat de levels met een rood knipperend rondje meerdre uitgangen hebben. Ik denk daarom dus dat er nog een uitgang zit bij Chocolate Island 2 en dat er dan een pad verschijnt naar recht (of naar beneden) maar ik t echt niet vinden.
ik kon ook nergens een plattegrond vinden van t hele eiland..
kan iemand mij helpen!?!?
59. CHOCOLATE ISLAND 2 (Difficulty: Medium)
This level is one of those damn "maze" levels which are really
hard to write up on a strategy guide. Oh well. I suggest you try
your best to go for the secret exit, because if you don't make
it, you'll still get the regular exit. If you do, then you'll be
able to bypass the rest of the level.
(The following comes from Sailor Bacon:
-To get to the secret key exit, you don't need to worry about
collecting coins or anything like that. Just go through the
second pipe (no matter which place the first pipe takes you to)
with more than 250 seconds remaining on the timer and you'll get
to the area with the key.
-In Area * D* (Mushrooms in Bubbles), I got several mushrooms and
still got taken to area *F*. I'm not sure how this area works but
it doesn't seem to be either 0 mushrooms or any mushrooms like in
the FAQ.
-If you take the path *E*->*D *->*F* or *E*->* D*->*G*, you will
get the five Yoshi coins, not just the first one.
If anyone can confirm this or find out more concrete info on this
level, it will be much appreciated. Thanks Sailor Bacon!)
(!!) Secret exit can be found here!
This level branches based on how many coins you get. Or how fast
you do everything. The first room features those dinosaurs. Avoid
them and get a nice Yoshi here.
(Y1) Easy to spot at the top of the level.
(Y2) Towards the right of the level, before the pipe.
Now, if you want to get the Dragon Coins or the secret exit,
you'll have to get as many coins as you can in this section. The
secret is this: next to the spring, jump up and an invisible ?
block will be hit. Jump on top of it and then move Mario to the
left so that you're half on it. Then, your head should be able to
hit the ? block above you. Hit it like a madman and you should
get enough coins.
You'll end up in one of three areas: *A* if you got enough coins
or *B* if you got very little or *E* if you got an average
amount. *A* will start off with one of the red triangles that
make you run on walls and *B* will start off with a series of
sloped platforms and *E* will send you to an area with dinos.
*A* If you got enough coins, you'll be in a flying stage. Once
again, this one involves how many coins you get. If you want the
Dragon Coins, don't get too many; but if you want the secret
exit, then you'll have to be the master of flying. Fly at an
altitude that lets you get all the coins. It's hard, but
possible. If you get pretty much all the coins, you'll go to the
secret area with the key or you'll go on with the level.
(Y3) On a platform in the middle. Don't land-- but continue to
fly with your cape to get this coin.
You'll end up in one of two areas: *C* if you got enough coins
or * D* if you didn't. *C* will start off with Chargin' Chucks
throwing baseballs and * D* will start with mushrooms in bubbles.
*B* If you didn't get that many coins, you'll end up at an area
with many sloped hills. Jump from platform to platform, avoiding
the flying Koopas. My advice is to always keep on jumping, so you
won't fall down off the slopes. You don't have to jump anywhere,
just jump in place if you have to. Enter the pipe at the end.
You'll end up in one of two areas: *C* if you went insanely fast
*C* This is the way to the secret exit. If you have the switches,
then all you have to do is jump on to the top platforms and avoid
all the Chucks. If you don't, then all you have to do is grab the
blue blocks and kick them at the Chucks. Either way, you'll get
to the key and go on.
Go to: 61. Chocolate Secret
* D* Mushrooms in bubbles. There are no enemies. However, if you
want the Dragon Coins, then you'll have to not get ANY of the
mushrooms. This is very difficult. Be quick and don't be afraid
to take daring jumps.
(Y4) In the water.
You'll end up in one of two areas: *F* if you didn't get any
mushrooms or *G* if you did. *F* starts off with a POW and *G*
starts off with a yellow ground.
*E* This is a simple platforming level that has many, many dinos.
I'm not exactly sure what the requirements are for this level,
but I think you'll always end up at * D*
(Y3) While you're jumping past the jumping pirahna plants.
Now, go look at * D* when you're done.
*F* There is a POW that you will not need if you have the
switches. If you unlocked all of them, then just run through,
grabbing the coins and
(Y5) This is the only way to get the final Dragon coin,
easily spotted at the end of this segment. For an
overview, this is how you can get here:
*A* -> * D* -> *F* OR *E* -> * D* -> *F*
I personally think the latter is easier.
If you don't have the switches unlocked (why?), then go hit the
left yellow block and another POW will pop out. Hit that one and
grab the next one. Jump from coin bridge to coin bridge and if
you hear the fast music beginning, lay the POW underneath you and
hit it to extend your time limit. Good job.
Go to: 62. Chocolate Island 3
*G* Another simple area with lots of dino-dudes. You can kill
them all, if you wish. And you'll see that there is
(Y4) a Dragon Coin, but you don't have 5!
Go to the exit and you're done!
That should be it with this level! If you see any other sections
or have different strategies, please feel free to e-mail me! Damn
this was hard to write!
http://db.gamefaqs.com/portable/gbadvance/file/super_mario_world_a.txt
edit: Smilies ff weggewerkt.
Pittig level hoor, kan me er helemaal niks meer van herinneren :P
  • DrNizeGuy
:D thnx ik kanw eer verder :D
  • DrNizeGuy
hmmz dat scheelde maar 1 veltje.. maar iig bedankt
  • Digital-DNA
  • Laatst online: 21-06 10:25
Digital-DNA
Gedigitaliseerd tot op het bot
Vergeet niet de starworld levels ook 'gewoon' uit te spelen (dat je dus niet verder gaat). Dit had ik ook toen ik maar 90 levels had. Ik had toen even alle starworldlevels ook even op de gewone manier uitgespeeld, en toen had ik alsnog 92, shibby!
www.nintendocasemods.com
  • DrNizeGuy
starworld en special wolrd heb ik ook al allemaal :)
Ik heb ze allemaal gehaald. Schildpadden veranderen dan in een soort Mario's & Luigi's, vleesetende planten in een soort "halloweenpompoenen" en nog wat vage zooi :P
Weet iemand wat je krijgt als je alle Yoshimunten hebt verzameld?
