P IV 2,4 (533) ASUS P4B533, 640Mb PC-2100, 80Gb Maxtor 8Mb cache & 60Gb IBM, 2 x 17" IIyama Prolite X436S-S, Plextor PX-708A, Plextor 52/24/52A, Logitech Marble Mouse USB, GeForce 3 Ti200
Toon die oplossing eens die je niet werkend hebt gekregen.
https://fgheysels.github.io/
Komptie:
1. Create the following table:
Table: tblImage
Field Name: ImageID
Data Type: AutoNumber
Indexed: Yes (No Duplicates)
Field Name: txtImageName
Data Type: Text
Table Properties: tblImage
PrimaryKey: ImageID
2.Open the tblImage table in Datasheet view and add the path and name of a bitmap file to each record. The following examples show how the records might look:
3.Create the following new form based on the ImageTable table:
Form: frmImage
Caption: Image Form
RecordSource: tblImage
Image Control
Note that the Picture property of the Image control has been set to the path name for the first image; the Image control must have a valid Picture property in Design view. Also, if you do not want the path to appear in the form, you can set the Visible property of the txtImageName control to False .
4.On the View menu, click Code , and then paste or type the following code:
Function setImagePath()
Dim strImagePath As String
On Error Resume Next
strImagePath = Me.txtImageName
Me.ImageFrame.Picture = strImagePath
End Function
5.Set the OnCurrent and AfterUpdate events to =setImagePath() .
Open the Imageform form in Form view. Note that the form displays the corresponding bitmap for each record
Picture: "C:\Windows\Circles.bmp"
Text box
ControlSource: ImageID
Text box
ControlSource: txtImageName
Dat is 'm. Ik loop dus vast in het caption verhaal (stap 3). Daar staat
Caption: ImageForm
Ik weet niet hoe of wat ik dit realiseer.
Table: tblImage
Field Name: ImageID
Data Type: Text
PrimaryKey: ImageID
Form: frmImage
Caption: Image Form
Image Control
End Function
Text box
Text box
Caption: ImageForm
Caption is een van de eigenschappen ("Properties") van een object (in dit geval het "Form").
Klik met rechts op het formulier en klik op "Eigenschappen"/"Properties" (NL/EN)
Er verschijnt een venstertje waarin dit soort eigenschappen terug te vinden zijn (En ook te wijzigen).
SIZE does matter.
"You're go at throttle up!"
Klopt, die properties en zo die zie ik wel. Maar verder kan ik het niet uitvoeren. D'r is dus blijkbaar niet een 'simpele' manier om foto's aan te roepen van buiten een Dbase?
