Op dinsdag 11 juni 2002 22:31 schreef andre_at_home het volgende:
wie heeft er nog meer tips.....
PS: staat je printerpoort wel aan of op de juiste instelling in het bios... zomaar een vraagje.....
In Windows werkte die en ik heb niks veranderd.
. Verify your version of Ghostscript to see if IJS support is present back to top
Your current Ghostscript may already support HPIJS. You can verify this with the gs -h command. You should see output similar to this:.
***************** Ghostscript Output *****************
GNU Ghostscript 6.53 (2002-02-13)
Copyright (C) 2002 artofcode LLC, Benicia, CA. All rights reserved.
Usage: gs [switches] [file1.ps file2.ps ...]
Most frequently used switches: (you can use # in place of =)
-dNOPAUSE no pause after page | -q `quiet', fewer messages
-gx page size in pixels | -r pixels/inch resolution
-sDEVICE= select device | -dBATCH exit after last file
-sOutputFile= select output file: - for stdout, |command for pipe,
embed %d or %ld for page #
Input formats: PostScript PostScriptLevel1 PostScriptLevel2 PDF
Available devices:
x11 bbox x11alpha x11cmyk x11gray2 x11gray4 x11mono bmpmono bmpgray
bmpsep1 bmpsep8 bmp16 bmp256 bmp16m bmp32b deskjet djet500 laserjet
ljetplus ljet2p ljet3 ljet3d ljet4 ljet4d lj5mono lj5gray cdeskjet
cdjcolor cdjmono cdj550 pj pjxl pjxl300 uniprint ijs hpijs DJ630
DJ6xx DJ6xxP DJ8xx DJ9xx DJ9xxVIP AP21xx bj10e bj200 bjc600
bjc800 faxg3 faxg32d faxg4 pcxmono pcxgray pcx16 pcx256 pcx24b pcxcmyk
pbm pbmraw pgm pgmraw pgnm pgnmraw pnm pnmraw ppm ppmraw pkm pkmraw pksm
pksmraw tiffcrle tiffg3 tiffg32d tiffg4 tifflzw tiffpack tiff12nc
tiff24nc psmono psgray psrgb bit bitrgb bitcmyk png16m pnggray pngmono
png256 png16 jpeg jpeggray pdfwrite pswrite epswrite pxlmono pxlcolor
cljet5 cljet5c nullpage
Search path:
. : /usr/share/ghostscript/6.53/lib : /usr/share/ghostscript/fonts
For more information, see /usr/share/ghostscript/6.53/doc/Use.htm.
Report bugs to bug-gs@ghostscript.com, using the form in Bug-form.htm.
If you don't see any of the highlighted devices your version of Ghostscript does not have built-in support for HPIJS.
Proceed to steps 4 and 5 to update your version of Ghostscript to use the ijs interface.
Als ik kijk naar die HP website en ik type in gs -h dan zie ik ook alleen IJS staan en niet DJ.. etc.
Dus ik heb die nieuwe Ghostscript geinstalleerd maar die geeft warnings aan bij het compilen en na die installatie zie ik nog altijd alleen IJS staan, ik denk dat dat er iets mee te maken heeft.
Ik moet mijn printer werkend krijgen want ik moet over een week dingen uitprinten voor mijn studie, ik zal anders weer naar Windows moeten gaan
Hmm... HP en Ghostscript spreken elkaar ook tegen wat betreft drivers.
van Ghostscript website
cdj550
HP DeskJet 550C (3.53)
HP DeskJet 560C (3.53)
HP DeskJet 600 (5.10) black (1bit/pixel) and colour (32bit/pixel)
HP DeskJet 660C (3.53)
HP DeskJet 660C (5.10)
HP DeskJet 682C (4.01) Use gamma=0.3
HP DeskJet 683C (3.33, 4.03)
HP DeskJet 693C (4.03) 24bit/pixel Is this a CMY or a CMYK printer? Probably CMYK in which case 32bit/pixel can be used.
HP DeskJet 694C (5.03) Works in colour. 690C, 692C, 693C and 694C are all software variations.
HP DeskJet 695C (5.50) Works in colour.
HP DeskJet 850 (3.53) 300dpi CMYK (32bit/pixel) See also cdj850.
HP DeskJet 870Cse (4.03) (16 or 32 bits/pixel) Use ljet4 device for B/W. See also cdj850.
HP DeskJet 895Cxi (5.03, 5.50) Does not work with cdj850.
HP DeskJet 970 (5.50) Some pages contain small black boxes, lines or missing characters.
HP OfficeJet 590 (5.50)
Olivetti jp450 (5.50)
Xerox XJ6C (5.50)
Dus de driver cdj550 moet ik gebruiken.
van HP website
DJ 600C Series Photo: (DJ6xxPhoto | DJ6xxP)
610/612, 640/648, 690/692/693/694/695/697
Hier opeens de DJ6xxxP
Begrijp ik het nou verkeerd of is dit verwarrend?
De de cdj550 heb ik wel staan in gs -h maar die DJ6xxxP niet.
