Ik wilde wat code (een forum profilen). Onder WinXP lukte dit al niet, onder Win98 wel. Maar de debug versie is in de profiler sneller dan de release versie. Hoe komt dit?
Wat ik ook niet snap is een regel als: 0,047 0,0 0,080 0,0 22 std::money_get<char,class std::istreambuf_iterator<char,struct std::char_traits<char> > >::`scalar deleting destructor'(unsigned int) (locale.obj)
Deze komt in de debug log helemaal niet voor.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
| Profile: Function timing, sorted by time
Date: Fri Jun 07 23:05:05 2002
Program Statistics
Command line at 2002 Jun 07 23:05: "E:\xhp\cgi-bin\forum"
Total time: 599,745 millisecond
Time outside of functions: 0,975 millisecond
Call depth: 63
Total functions: 1083
Total hits: 387896
Function coverage: 52,7%
Overhead Calculated 3
Overhead Average 3
Module Statistics for forum.exe
Time in module: 598,771 millisecond
Percent of time in module: 100,0%
Functions in module: 1083
Hits in module: 387896
Module function coverage: 52,7%
Func Func+Child Hit
Time % Time % Count Function
118,886 19,9 118,886 19,9 165644 std::basic_filebuf<char,struct std::char_traits<char> >::uflow(void) (file31.obj)
114,731 19,2 231,900 38,7 4637 std::basic_streambuf<char,struct std::char_traits<char> >::xsgetn(char *,int) (file31.obj)
34,767 5,8 399,580 66,7 1 read_topics(void) (forum.obj)
34,376 5,7 34,376 5,7 39017 operator delete(void *) (delop.obj)
32,071 5,4 57,208 9,6 9185 get_thread_newest_msg(int) (forum.obj)
16,145 2,7 16,217 2,7 4 get_time_offset(void) (forum.obj)
15,788 2,6 20,743 3,5 4631 std::_Tree<int,struct std::pair<int const ,struct t_topic>,struct std::map<int,struct t_topic,struct std::greater<int>,class std::allocator<struct t_topic> >::_Kfn,struct std::greater<int>,class std::allocator<struct t_topic> >::_Erase(struct std::_Tree<int,struct std::pair<int const ,struct t_topic>,struct std::map<int,struct t_topic,struct std::greater<int>,class std::allocator<struct t_topic> >::_Kfn,struct std::greater<int>,class std::allocator<struct t_topic> >::_Node *) (forum.obj)
14,622 2,4 18,734 3,1 8019 std::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::_Erase(struct std::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::_Node *) (forum.obj)
12,833 2,1 20,699 3,5 9262 std::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::~_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >(void) (forum.obj)
12,723 2,1 49,487 8,3 3388 std::_Tree<int,struct std::pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > >,struct std::map<int,class std::set<int,struct std::less<int>,class std::allocator<int> >,struct std::less<int>,class std::allocator<class std::set<int,struct std::less<int>,class std::allocator<int> > > >::_Kfn,struct std::less<int>,class std::allocator<class std::set<int,struct std::less<int>,class std::allocator<int> > > >::_Erase(struct std::_Tree<int,struct std::pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > >,struct std::map<int,class std::set<int,struct std::less<int>,class std::allocator<int> >,struct std::less<int>,class std::allocator<class std::set<int,struct std::less<int>,class std::allocator<int> > > >::_Kfn,struct std::less<int>,class std::allocator<class std::set<int,struct std::less<int>,class std::allocator<int> > > >::_Node *) (forum.obj)
9,939 1,7 9,939 1,7 9201 std::_Tree<int,struct std::pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > >,struct std::map<int,class std::set<int,struct std::less<int>,class std::allocator<int> >,struct std::less<int>,class std::allocator<class std::set<int,struct std::less<int>,class std::allocator<int> > > >::_Kfn,struct std::less<int>,class std::allocator<class std::set<int,struct std::less<int>,class std::allocator<int> > > >::find(int const &) (forum.obj)
9,749 1,6 33,777 5,6 3387 std::pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > >::~pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > >(void) (forum.obj)
9,727 1,6 12,944 2,2 4630 std::_Tree<int,struct std::pair<int const ,struct t_topic>,struct std::map<int,struct t_topic,struct std::greater<int>,class std::allocator<struct t_topic> >::_Kfn,struct std::greater<int>,class std::allocator<struct t_topic> >::_Insert(struct std::_Tree<int,struct std::pair<int const ,struct t_topic>,struct std::map<int,struct t_topic,struct std::greater<int>,class std::allocator<struct t_topic> >::_Kfn,struct std::greater<int>,class std::allocator<struct t_topic> >::_Node *,struct std::_Tree<int,struct std::pair<int const ,struct t_topic>,struct std::map<int,struct t_topic,struct std::greater<int>,class std::allocator<struct t_topic> >::_Kfn,struct std::greater<int>,class std::allocator<struct t_topic> >::_Node *,struct std::pair<int const ,struct t_topic> const &) (forum.obj)
9,362 1,6 244,387 40,8 4637 std::basic_istream<char,struct std::char_traits<char> >::read(char *,int) (cgi.obj)
9,087 1,5 12,833 2,1 4631 std::pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > >::pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > >(int const &,class pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > >::set<int,struct std::less<int>,class std::allocator<int> > const &) (forum.obj)
9,019 1,5 9,019 1,5 8641 std::_Tree<int,struct std::pair<int const ,struct t_topic>,struct std::map<int,struct t_topic,struct std::greater<int>,class std::allocator<struct t_topic> >::_Kfn,struct std::greater<int>,class std::allocator<struct t_topic> >::lower_bound(int const &) (forum.obj)
8,362 1,4 26,974 4,5 4631 std::map<int,class std::set<int,struct std::less<int>,class std::allocator<int> >,struct std::less<int>,class std::allocator<class std::set<int,struct std::less<int>,class std::allocator<int> > > >::insert(struct std::pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > > const &) (forum.obj)
8,259 1,4 12,293 2,1 4630 std::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::_Init(void) (forum.obj)
7,913 1,3 11,035 1,8 4631 std::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::_Insert(struct std::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::_Node *,struct std::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::_Node *,int const &) (forum.obj)
7,834 1,3 20,778 3,5 4630 std::_Tree<int,struct std::pair<int const ,struct t_topic>,struct std::map<int,struct t_topic,struct std::greater<int>,class std::allocator<struct t_topic> >::_Kfn,struct std::greater<int>,class std::allocator<struct t_topic> >::insert(struct std::pair<int const ,struct t_topic> const &) (forum.obj)
7,255 1,2 16,775 2,8 3387 std::_Tree<int,struct std::pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > >,struct std::map<int,class std::set<int,struct std::less<int>,class std::allocator<int> >,struct std::less<int>,class std::allocator<class std::set<int,struct std::less<int>,class std::allocator<int> > > >::_Kfn,struct std::less<int>,class std::allocator<class std::set<int,struct std::less<int>,class std::allocator<int> > > >::_Insert(struct std::_Tree<int,struct std::pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > >,struct std::map<int,class std::set<int,struct std::less<int>,class std::allocator<int> >,struct std::less<int>,class std::allocator<class std::set<int,struct std::less<int>,class std::allocator<int> > > >::_Kfn,struct std::less<int>,class std::allocator<class std::set<int,struct std::less<int>,class std::allocator<int> > > >::_Node *,struct std::_Tree<int,struct std::pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > >,struct std::map<int,class std::set<int,struct std::less<int>,class std::allocator<int> >,struct std::less<int>,class std::allocator<class std::set<int,struct std::less<int>,class std::allocator<int> > > >::_Kfn,struct std::less<int>,class std::allocator<class std::set<int,struct std::less<int>,class std::allocator<int> > > >::_Node *,struct std::pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > > const &) (forum.obj)
6,784 1,1 9,520 1,6 3387 std::_Construct(struct std::pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > > *,struct std::pair<int const ,class std::set<int,struct std::less<int>,class std::allocator<int> > > const &) (forum.obj)
6,639 1,1 6,639 1,1 9228 std::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::const_iterator::_Inc(void) (forum.obj)
6,464 1,1 17,499 2,9 4631 std::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::insert(int const &) (forum.obj)
6,249 1,0 18,542 3,1 4630 std::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >(struct _Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::less<int> const &,bool,class _Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::allocator<int> const &) (forum.obj)
4,655 0,8 4,655 0,8 2 std::__Fiopen(char const *,int) (fiopen.obj)
3,217 0,5 3,217 0,5 4630 std::_Construct(struct std::pair<int const ,struct t_topic> *,struct std::pair<int const ,struct t_topic> const &) (forum.obj)
3,143 0,5 3,143 0,5 4661 std::basic_istream<char,struct std::char_traits<char> >::ipfx(bool) (cgi.obj)
3,122 0,5 3,122 0,5 4631 std::_Construct(int *,int const &) (forum.obj)
3,095 0,5 3,095 0,5 4642 std::pair<class std::_Tree<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,struct std::pair<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const ,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,struct std::map<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,struct std::less<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,class std::allocator<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > > >::_Kfn,struct std::less<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,class std::allocator<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > > >::iterator,bool>::pair<class std::_Tree<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,struct std::pair<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const ,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,struct std::map<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,struct std::less<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,class std::allocator<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > > >::_Kfn,struct std::less<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,class std::allocator<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > > >::iterator,bool>(class pair<class std::_Tree<class std::basic_string<char,stru
t
std::char_traits<char>,class std::allocator<char> >,struct std::pair<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const ,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,struct std::map<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,struct std::less<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,class std::allocator<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > > >::_Kfn,struct std::less<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,class std::allocator<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > > >::iterator,bool>::_Tree<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,struct std::pair<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const ,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,struct std::map<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,struct std::less<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,class std::allocator<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > > >::_Kfn,struct std::less<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,class std::allocator<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > > >::iterator const &,bool const &) (cookie.obj)
3,095 0,5 3,095 0,5 4642 std::pair<class std::_Tree<int,struct std::pair<int const ,struct t_topic>,struct std::map<int,struct t_topic,struct std::greater<int>,class std::allocator<struct t_topic> >::_Kfn,struct std::greater<int>,class std::allocator<struct t_topic> >::iterator,bool>::pair<class std::_Tree<int,struct std::pair<int const ,struct t_topic>,struct std::map<int,struct t_topic,struct std::greater<int>,class std::allocator<struct t_topic> >::_Kfn,struct std::greater<int>,class std::allocator<struct t_topic> >::iterator,bool>(class pair<class std::_Tree<int,struct std::pair<int const ,struct t_topic>,struct std::map<int,struct t_topic,struct std::greater<int>,class std::allocator<struct t_topic> >::_Kfn,struct std::greater<int>,class std::allocator<struct t_topic> >::iterator,bool>::_Tree<int,struct std::pair<int const ,struct t_topic>,struct std::map<int,struct t_topic,struct std::greater<int>,class std::allocator<struct t_topic> >::_Kfn,struct std::greater<int>,class std::allocator<struct t_topic> >::iterator const &,bool const &) (cookie.obj)
2,394 0,4 9,989 1,7 24 std::getline(class std::basic_istream<char,struct std::char_traits<char> > &,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > &,char) (forum.obj)
2,358 0,4 4,005 0,7 1170 std::basic_streambuf<char,struct std::char_traits<char> >::sgetc(void) (cgi.obj)
2,348 0,4 60,078 10,0 570 get_thread_date(int) (forum.obj) |
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
Date: Fri Jun 07 23:08:39 2002
Program Statistics
Command line at 2002 Jun 07 23:08: "E:\VC\xhp\cgi-bin\forum\Debug\forum"
Total time: 11,277 millisecond
Time outside of functions: 1,362 millisecond
Call depth: 15
Total functions: 2352
Total hits: 3502
Function coverage: 20,8%
Overhead Average 3
Time in module: 9,916 millisecond
Functions in module: 2352
Hits in module: 3502
Module function coverage: 20,8%
Func Func+Child Hit
1,830 18,5 1,908 19,2 113 std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::max_size(void) (cgi.obj)
0,525 5,3 0,678 6,8 6 std::basic_ios<char,struct std::char_traits<char> >::init(class std::basic_streambuf<char,struct std::char_traits<char> > *,bool) (file31.obj)
0,374 3,8 2,910 29,3 61 std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::_Grow(unsigned int,bool) (cgi.obj)
0,320 3,2 0,562 5,7 266 std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::_Tidy(bool) (cgi.obj)
0,255 2,6 0,380 3,8 5 std::_Tree<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,struct std::pair<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const ,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,struct std::map<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,struct std::less<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,class std::allocator<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > > >::_Kfn,struct std::less<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > >,class std::allocator<class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > > >::_Init(void) (cgi.obj)
0,246 2,5 0,246 2,5 2 std::__Fiopen(char const *,int) (fiopen.obj)
0,207 2,1 0,685 6,9 52 std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::_Copy(unsigned int) (cgi.obj)
0,165 1,7 0,165 1,7 197 std::_Lockit::_Lockit(void) (cgi.obj)
0,164 1,7 3,134 31,6 56 std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::assign(char const *,unsigned int) (cgi.obj)
0,147 1,5 0,147 1,5 72 operator delete(void *) (delop.obj)
0,145 1,5 0,742 7,5 34 std::locale::locale(void) (file31.obj)
0,141 1,4 0,220 2,2 105 std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::_Eos(unsigned int) (cgi.obj)
0,130 1,3 0,130 1,3 68 std::_Allocate(int,char *) (cgi.obj)
0,130 1,3 0,130 1,3 197 std::_Lockit::~_Lockit(void) (cgi.obj)
0,125 1,3 0,125 1,3 176 std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::_Refcnt(char const *) (cgi.obj)
0,112 1,1 3,350 33,8 56 std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::assign(char const *) (cgi.obj)
0,109 1,1 1,379 13,9 3 std::ios_base::Init::Init(void) (iostream.obj)
0,108 1,1 0,234 2,4 15 std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::assign(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,unsigned int,unsigned int) (cgi.obj)
0,106 1,1 0,437 4,4 34 std::locale::_Init(void) (locale0.obj)
0,104 1,0 0,104 1,0 56 std::char_traits<char>::length(char const *) (cgi.obj)
0,097 1,0 0,463 4,7 72 std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::~basic_string<char,struct std::char_traits<char>,class std::allocator<char> >(void) (cgi.obj)
0,096 1,0 4,090 41,2 1 read_config(void) (forum.obj)
0,082 0,8 0,126 1,3 56 std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >(class basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::allocator<char> const &) (cgi.obj)
0,081 0,8 0,129 1,3 37 std::locale::facet::_Incref(void) (cgi.obj)
0,079 0,8 0,079 0,8 105 std::char_traits<char>::assign(char &,char const &) (cgi.obj)
0,078 0,8 0,078 0,8 113 std::allocator<char>::max_size(void) (cgi.obj)
0,075 0,8 0,129 1,3 38 std::locale::facet::_Decref(void) (cgi.obj)
0,074 0,7 0,170 1,7 52 std::allocator<char>::allocate(unsigned int,void const *) (cgi.obj)
0,070 0,7 0,176 1,8 47 std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::`default constructor closure'(void) (forum.obj)
0,070 0,7 3,197 32,2 51 std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::operator=(char const *) (cgi.obj)
0,066 0,7 0,181 1,8 52 std::allocator<char>::deallocate(void *,unsigned int) (cgi.obj)
0,065 0,7 0,375 3,8 1 forum(void) (forum.obj)
0,061 0,6 0,129 1,3 2 std::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::_Buynode(struct std::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::_Node *,enum std::_Tree<int,int,struct std::set<int,struct std::less<int>,class std::allocator<int> >::_Kfn,struct std::less<int>,class std::allocator<int> >::_Redbl) (forum.obj)
0,060 0,6 0,236 2,4 1 _$E47 (forum.obj)
0,059 0,6 0,189 1,9 10 std::ios_base::_Init(void) (ios.obj)
0,058 0,6 0,302 3,0 1 std::set<int,struct std::less<int>,class std::allocator<int> >::set<int,struct std::less<int>,class std::allocator<int> >(struct set<int,struct std::less<int>,class std::allocator<int> >::less<int> const &,class set<int,struct std::less<int>,class std::allocator<int> >::allocator<int> const &) (forum.obj)
0,055 0,6 0,055 0,6 33 operator new(unsigned int,void *) (cgi.obj)
0,055 0,6 0,122 1,2 1 std::_Locinfo::_Locinfo(char const *) (locale.obj)
0,055 0,6 0,179 1,8 36 std::locale::~locale(void) (cgi.obj)
0,052 0,5 0,052 0,5 56 std::char_traits<char>::copy(char *,char const *,unsigned int) (cgi.obj)
0,051 0,5 4,578 46,2 1 _main (forum.obj) |
