Printen onder java
  • mrbullet
Weet iemand hoe ik plaatjes kan afdrukken met java. Ik begin dus net met programmeren....
Pana 5j
  • mrbullet
Dat had ik ook gevonden maar ik kom niet helemaal uit. Ik moet een gif plaatje uitprinten en ik kan het zo niet vinden.
Toch bedank voor je reactie.
Pana 5j
  • Baron
  • Laatst online: 21-06 17:02
kijk wat ik vond
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
Example: PrintGIF.java
* Copyright 2001 Sun Microsystems, Inc. All Rights Reserved.
* This software is the proprietary information of Sun Microsystems, Inc.
* Use is subject to license terms.
import java.io.*;
import javax.print.*;
import javax.print.attribute.*;
import javax.print.attribute.standard.*;
*  Use the Java(TM) Print Service API to locate a print service which
*  can print a GIF-encoded image. A GIF image is printed according to
*  a job template specified as a set of printing attributes.
public class PrintGIF {
      public static void main(String args[]) {
            /* Use the pre-defined flavor for a GIF from an InputStream */
            DocFlavor flavor = DocFlavor.INPUT_STREAM.GIF;
            /* Create a set which specifies how the job is to be printed */
            PrintRequestAttributeSet aset = new HashPrintRequestAttributeSet();
            aset.add(MediaSizeName.NA_LETTER);
            aset.add(new Copies(1));
            /* Locate print services which can print a GIF in the manner specified */
            PrintService[] pservices =
                PrintServiceLookup.lookupPrintServices(flavor, aset);
            if (pservices.length > 0) {
                /* Create a Print Job */
                DocPrintJob printJob = pservices[0].createPrintJob();
                /* Create a Doc implementation to pass the print data */
                Doc doc = new InputStreamDoc("java2dlogo.gif", flavor);
                /* Print the doc as specified */
                try {
                      printJob.print(doc, aset);
                } catch (PrintException e) {
                      System.err.println(e);
            } else {
                System.err.println("No suitable printers");
class InputStreamDoc implements Doc {
      private String filename;
      private DocFlavor docFlavor;
      private InputStream stream;
      public InputStreamDoc(String name, DocFlavor flavor) {
            filename = name;
            docFlavor = flavor;
      public DocFlavor getDocFlavor() {
            return docFlavor;
      /* No attributes attached to this Doc - mainly useful for MultiDoc */
      public DocAttributeSet getAttributes() {
            return null;
      /* Since the data is to be supplied as an InputStream delegate to
      * getStreamForBytes().
      public Object getPrintData() throws IOException {
            return getStreamForBytes();
      /* Not possible to return a GIF as text */
      public Reader getReaderForText()
            throws UnsupportedEncodingException, IOException {
         return null;
      /* Return the print data as an InputStream.
      * Always return the same instance.
      public InputStream getStreamForBytes() throws IOException {
            synchronized(this) {
                if (stream == null) {
                      stream = new FileInputStream(filename);
                return stream;
