PPTP installeren en configueren
Hoi,
Ik wil een server inrichten met W2k, met ADS en PPTP actief, wie weet waar ik informatie betreffende PPTP kan vinden. Hoe moet ik dit installeren en hoe configueren.
Of moet ik misschien meteen L2TP (Layer 2 Tunneling Protocol ) gebruiken.
Greetzzz
Kan iemand mij misschien uitleggen wat nu het wezenlijke verschil is tussen PPTP en L2TP
  • Gardocki
Op woensdag 05 juni 2002 09:38 schreef chopperboy het volgende:
PPTP:
Point-to-Point Tunneling Protocol (PPTP) is a protocol (set of communication rules) that allows corporations to extend their own corporate network through private "tunnels" over the public Internet. Effectively, a corporation uses a wide-area network as a single large local area network. A company no longer needs to lease its own lines for wide-area communication but can securely use the public networks. This kind of interconnection is known as a virtual private network (VPN).
PPTP, a proposed standard sponsored by Microsoft and other companies, and Layer 2 Tunneling Protocol, proposed by Cisco Systems, are among the most likely proposals as the basis for a new Internet Engineering Task Force (IETF) standard. With PPTP, which is an extension of the Internet's Point-to-Point Protocol (PPP), any user of a PC with PPP client support is able to use an independent service provider (ISP) to connect securely to a server elsewhere in the user's company.
L2TP:
Layer Two Tunneling Protocol (L2TP) is an extension of the Point-to-Point Tunneling Protocol (PPTP) used by an Internet service provider (ISP) to enable the operation of a virtual private network (VPN) over the Internet. L2TP merges the best features of two other tunneling protocols: PPTP from Microsoft and L2F from Cisco Systems. The two main components that make up L2TP are the L2TP Access Concentrator (LAC), which is the device that physically terminates a call and the L2TP Network Server (LNS), which is the device that terminates and possibly authenticates the PPP stream.
PPP defines a means of encapsulation to transmit multiprotocol packets over layer two (L2) point-to-point links. Generally, a user connects to a network access server (NAS) through ISDN, ADSL, dialup POTS or other service and runs PPP over that connection. In this configuration, the L2 and PPP session endpoints are both on the same NAS.
L2TP uses packet-switched network connections to make it possible for the endpoints to be located on different machines. The user has an L2 connection to an access concentrator, which then tunnels individual PPP frames to the NAS, so that the packets can be processed separately from the location of the circuit termination. This means that the connection can terminate at a local circuit concentrator, eliminating possible long-distance charges, among other benefits. From the user's point of view, there is no difference in the operation.
bron: whatis.com
They made me do it.
