Hoe maak je een image met nero?
  • 191 views sinds 30-01-2008
  • STIMPPYYY
  • Laatst online: 21:29
Hoe maak ik een image met nero ik weet wel dat je dit moet doen
recorders> recorder kiezen > image recorder
en wat moet ik dan doen ? daarna?
ik wil een image maken van de 2e cd van gta 3
  • DizzyWeb
  • Laatst online: 22-09 13:36
DizzyWeb
Ondertiteld
Recorder > Save Track :)
  • blackd
Gewoon net doen alsof je een CD gaat branden toch?
Druk ook eens op F1...
Processing of an image file consists of two independent steps.
1.In the first step, the image file is created and saved as a file instead of being written immediately onto a CD.
2.In the second step, this image file is written onto a CD.
1.Select Image Recorder from the CD-RECORDER> Choose Recorder menu and confirm your selection by clicking on OK.
2.Create, for example, a CD-ROM (ISO) or an Audio-CD compilation.
3.Open the Write dialog. The easiest way to do this is to click on the Write CD icon in the toolbar You will then go to the Write CD dialog box, which will undoubtedly look familiar to you: it is the same box which you saw for the creation of a new compilation, only now the Burn property sheet is shown on the top. You will see several boxes, some of which are already selected. Determine maximum speed and Simulate are already selected. In the case of an image file, however, it is enough to only select the Write box. You can deactivate the other steps by clicking on them.
4.You may now check over all of the settings on this and the other property sheets and make any necessary changes.
5.You may now confirm your selections by clicking on the Write button. The Save Image File dialog box opens. Here, you can enter a file name for the image file. The files of your compilation will be written into this file. In other words, you need as much space for the image file as the total size of the files of the compilation.
9000Wp o/w SolarEdge SE6K - Panasonic 5kW bi-bloc - gasloos sinds 17-7-2023
  • DeX
  • Laatst online: 13-01 09:52
DeX
http://gathering.tweakers.net/forum/find
Staat genoeg voor je in..
Het branden van een Image via Nero gaat als volgt.
1. Start Nero Op
2. Sluit de Wizard Af
3. Image Selecteren
4. Druk op File
5. Burn Image
Klaar is kees over het creeren zelf van een image heb ik geen kaas gegeten.
Uit het menu: CHOOSE RECORDERD
Kies daar IMAGE RECORDER.
Daarna gewoon FILE--> COPY CD
That's all.
Als je weer normale cd's wilt branden dan kies je ipv de IMAGE RECORDER je eigen cd-r/rw.
  • blackd
Op dinsdag 04 juni 2002 16:31 schreef DeX het volgende:
Zou je, als je naar de search verwijst, ook nuttige topics eruit kunnen vissen? Zie ook [topic=396113]. Thx :)
  • STIMPPYYY
er is geen topic hier over heb al gesearched
  • blackd
Op dinsdag 04 juni 2002 16:35 schreef STIMPPYYY het volgende:
O jawel hoor:
[search=nero image]
[topic=208877/1/100]
[topic=24090/1/100]
  • dude123
  • Laatst online: 13-05-2022
dude123
Linux addict
Op dinsdag 04 juni 2002 16:33 schreef Sensation16 het volgende:
1. Start Nero Op
3. Image Selecteren
4. Druk op File
5. Burn Image
het ging hier erom om een image te maken en niet te branden
Meneer 1000 has spoken......
  • STIMPPYYY
ok ik heb een image ook iets opgeslagen van image
en hij ging een cd branden
maar hoe gebruik ik nou zon image? :D
  • blackd
Op dinsdag 04 juni 2002 16:57 schreef STIMPPYYY het volgende:
Dat staat hierboven dus.
Nogmaals: druk ook eens op F1 (=Help), dat scheelt ;)
  • STIMPPYYY
ik snap het niet :D:P
ik heb een image file genaamd image ni mijn games directory staan
maar als ik het spel opstart vraagt hij nog steeds naar de cd
  • Han
Han
Ja, kappen nou :(
