Bestanden renamen
  • 83 views sinds 30-01-2008
  • The Dud3
  • Laatst online: 25-08 19:46
Hoe kan ik een map die vol met JPGs zit, alle bestanden erin renamen?
bijv:
moet worden:
Ik ben er zeker van dat dit in Linux gaat, maar ik ben een lnx n00b :Z
Ik kan wel met DOS omgaan :) , betstaat hier geen command/prog voor?
The opinions stated in the above post are purely those of the author,
and do not represent intelligent life of any form.
  • WFvN
  • Laatst online: 30-08 15:56
WFvN
Gosens Koeling en Warmte
[search=bestanden hernoemen]
tip: infranview
  • 2xit
  • Laatst online: 07-08 15:02
2xit
Q+M by P+E
Mischien heb je hier wat aan:
Microsoft
When you download photos from your digital camera, they often have unrecognizable names. You can rename several similar files at once with the following procedure. This also works for renaming other types of files.
To rename a series of files
Open the My Pictures folder. (Click Start, and then click My Pictures.) Or open another folder containing files that you want to rename.
Select the files you want to rename. If the files you want are not adjacent in the file list, press and hold CTRL, and then click each item to select it.
On the File menu, click Rename.
Type the new name, and then press ENTER.
All of the files in the series will be named in sequence using the new name you type. For example, if you type Birthday, the first will be named Birthday and subsequent files in the series will be named Birthday (1), Birthday (2), and so on. To specify the starting number for the series, type the starting number in parentheses after the new file name. The files in the series will be numbered in sequence starting with the number you type. For example, if you type Birthday (10), the other files will be named Birthday (11), Birthday (12), and so on.
The factory of the future will have only two employees, a man and a dog. The man will be there to feed the dog. The dog will be there to keep the man from touching the equipment.
Always be 2excite(d)
  • The Dud3
thnx 2xit, perfect, net wat ik wou :D
  • OProg
  • Laatst online: 06-01-2022
OProg
Molletje
Dit was best wel op te zoeken :)
