Weet iemand hoe ik MSN Messenger met Wine kan draaien, met alles erop en eraan?
Telkens geeft ie foutmeldingen:
Is er iets mis met m'n config of zo? Wine heeft de Windows XP directory gevonden om /dev/hda1 (/mnt/Windows)
Trillian heb ik aan het werk gekregen, alsook mIRC, ICQ, Half-Life, MS Office (ongeveer > geen schrijfrecht op NTFS).
Iemand enig idee?
| [jcapraro@pikachu Messenger]$ wine msmsgs.exe fixme:cdrom:CDROM_GetIdeInterface major 11 not supported When you are running with a native NT directory specify 'Profile=<profiledirectory>' or disable loading of Windows registry (LoadWindowsRegistryFiles=N) Wine cannot find the FreeType font library. To enable Wine to use TrueType fonts please install a version of FreeType greater than or equal to 2.0.5. http://www.freetype.org Loading required GL library /usr/X11R6/lib/libGL.so.1.2 fixme:keyboard:X11DRV_KEYBOARD_DetectLayout Your keyboard layout was not found! Using closest match instead (Belgian keyboard layout) for scancode mapping. Please define your layout in windows/x11drv/keyboard.c and submit them to us for inclusion into future Wine releases. See the Wine User Guide, chapter "Keyboard" for more information. fixme:reg:RegFlushKey (50): stub fixme:reg:RegFlushKey (48): stub fixme:ole:CoMarshalInterface Failed to Marshal the interface, 80070057? fixme:ole:_LocalServerThread CoMarshalInterface failed, 80070057! [jcapraro@pikachu Messenger]$ |
Iemand enig idee?
