[Coldfusion MX] vage foutmelding bij startup
  • whitehouse
  • Laatst online: 25-08 22:31
ik start voor de 1e keer Coldfusion (administrator button) , heb IIS geinstalleerd ,
en krijg de volgende foutmelding ..
Please Try The Following:
Check the CFML Reference Manual to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0)
Remote Address 127.0.0.1
Referer
Date/Time 01-jan-00 07:36 PM
Stack Trace (click to expand)
java.lang.NoClassDefFoundError
at javax.crypto.Cipher.getInstance([DashoPro-V1.2-120198])
at coldfusion.compiler.TemplateReader.decrypt(Unknown Source)
at coldfusion.compiler.TemplateReader.(Unknown Source)
at coldfusion.compiler.NeoTranslationContext.getPageReader(Unknown Source)
at coldfusion.compiler.NeoTranslator.translateJava(Unknown Source)
at coldfusion.runtime.TemplateClassLoader$1.fetch(Unknown Source)
at coldfusion.util.LruCache.get(Unknown Source)
at coldfusion.runtime.TemplateClassLoader$TemplateCache.fetchSerial(Unknown Source)
at coldfusion.util.AbstractCache.fetch(Unknown Source)
at coldfusion.util.SoftCache.get(Unknown Source)
at coldfusion.runtime.TemplateClassLoader.findClass(Unknown Source)
at coldfusion.filter.PathFilter.invoke(Unknown Source)
at coldfusion.filter.ExceptionFilter.invoke(Unknown Source)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(Unknown Source)
at coldfusion.filter.BrowserFilter.invoke(Unknown Source)
at coldfusion.filter.GlobalsFilter.invoke(Unknown Source)
at coldfusion.filter.DatasourceFilter.invoke(Unknown Source)
at coldfusion.CfmServlet.service(Unknown Source)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:241)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:527)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:198)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:348)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:451)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:294)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
wat heb ik hier niet juist gedaan ? ik heb dus geen app geprogrammeerd ofzow.. ik start na het installeren van CF MX gewoon de admin op .. tenminste .. dat probeer ik ..
gegevens :
Win2000 Pro
IIS
I.E. 6.0
ColdFusion MX draait samen met een Jrun core. Mijn eerste idee, is... iets niet goed gegaan tijdens de installatie. Probeer het eens opnieuw die installatie?
  • D2k
  • Laatst online: 31-08 10:19
D2k
P&W -> SA
Doet iets met Cloud (MS/IBM)
  • whitehouse
ehm.. kan deze post niet beter bij Programming ? (daar zitten meer Codfusion kenners) ..
daarnaast heb ik zojuist CF eraf gegooid en opnieuw een install gedaan..dezelfde foutmelding .. erg vaag
zit in mijn CF pack ook de CF-server ? (dat was bij 5.0 toch zo, dat je een speciale CF-server moest installen ?)
  • ACM
ACM
Software Architect
Werkt hier
Voor deze keer dan maar: [topic=511993/1]
SA -> P&W
  • mulder
  • Laatst online: 06-09 22:14
mulder
ik spuug op het trottoir
Op zaterdag 01 juni 2002 20:20 schreef whitehouse het volgende:
Staat wel in de handleiding dacht ik zo. Misschien even contact met support opnemen. Niet echt P&W. Ja toch?
oogjes open, snaveltjes dicht
Wat zijn exact de opties die je tijdens de installatie hebt gekozen? Wat voor Win2K versie draai je? En wat voor CFMX type heb je? Pro, Ent?
  • whitehouse
ik heb de "standaard" opties gekozen ..
ik draai win2k Pro,
De versie is CF MX Windows English Version
Dat is alles wat op de website staat .. geen versie (Ent op Pro ofzow) ..
  • whitehouse
ah..niemand .. heeft iemand toevallig Coldfusion MX uitgeprobeerd ??
  • D2k
D2k
Hoi,
[topic=392390/1/25]
Policy mbt het omhoogschoppen van threads. Wacht minstens 24 uur voor je je topic omhoog schopt. Doe dit dan ook alleen met een zinnige opmerking en dus niet met "Waarom antwoord er nou niemand" nadat je 5 minuten geen antwoord hebt gehad. Sommigen van ons hebben een leven :+
  • MisterData
  • Laatst online: 04-09 23:45
Een NoClassDefFound fout geeft aan dat er iets nietg evonden kan worden. In dit geval gaat het om javax.crypto zooi, dus je zult waarschijnlijk even de nieuwste java-versie moeten installen :)
  • whitehouse
ik heb bij deze de nieuwste Java VM van Microsoft.com gedownload , geinstalleerd, maar nog steeds dezelfde foutmelding..wordt er een beetje moe van :(
maar ik heb nog steeds geen antwoord op de volgende vraag :
heeft de MX - versie geen cf-server meer nodig ?
Op maandag 03 juni 2002 09:46 schreef whitehouse het volgende:
Ik kan geen advies geven adhv deze foutmelding helaas. ColdFusion MX, is de eerste versie welke draait op een Jrun engine, daarvoor draaiden alle versies op een C coded engine. :{
