Meerdere attachments met Visual Basic
Weet iemand hoe je meerdere attachments met Visual Basic kan versturen ?
Ik maak gebruik van mapi.
MAPIMessages1.AttachmentType = ATTACHTYPE_DATA
MAPIMessages1.AttachmentName = "Test.txt" MAPIMessages1.AttachmentPathName = App.Path + "\test.txt
Ik weet zeker dat het kan met MAPI omdat je ook een function attachmentcount hebt.. dus...
Heeft iemand wel eens meerdere attachments verstuurd met VB ? Vertel A.U.B. hoe je dat gedaan hebt!
Alvast bedankt
Op donderdag 30 mei 2002 15:11 schreef G_IJ_S het volgende:
Alvast bedankt
KommaŽs(?)
Nee... Al geprobeerd...
Dat kan je volgens mij doen met de AttachmentIndex property.
Uit de o zo handige VB-help (:)):
Specifies an index number to identify a particular message attachment. The index number in this property determines the values in the AttachmentName, AttachmentPathName, AttachmentPosition, and AttachmentType properties. The attachment identified by the AttachmentIndex property is called the currently indexed attachment. The value of AttachmentIndex can range from 0 (the default) to AttachmentCount -1.
To add a new attachment, set the AttachmentIndex to a value greater than or equal to the current attachment count while in the compose buffer (MsgIndex = -1). The AttachmentCount property is updated automatically to reflect the implied new number of attachments.
For example, if the current AttachmentCount property has the value 3, setting the AttachmentIndex property to 4 adds 2 new attachments and increases the AttachmentCount property to 5.
To delete an existing attachment, specify the Delete method with the value parameter set to 2. Attachments can be added or deleted only when the MsgIndex property is set to -1.
  • Ronald_stage
  • Laatst online: 07:45
Ronald_stage
wat kan je hier nog zeggen
eeh, ik gebruik gewoon
attachment.add = dir1.path & "\" & File1.filename & dir2.path & "\" & file2.filename
suc6
