Realm?
Kan iemand mij uitleggen wat er bedoelt wordt met een Realm, Deze moet je invoeren in b.v. een aaa radiusserver.
  • ACM
ACM
Software Architect
Werkt hier
Voor dat soort dingen is er toch de manual :?
Ja dat is waar..... en daar staat in:
"in this entry you enter the realm".
Errug helpfull dus...
Nog iemand?
  • Predator
  • Laatst online: 07:32
Predator
Suffers from split brain
realm
A specific group of clients within the overall client base of an Internet service provider (ISP). For example, all the employees of a major corporation that has contracted with an ISP are likely to be implemented as a realm.
:P
Everybody lies | BFD rocks ! | PC-specs
  • paulhekje
  • Laatst online: 23-10 09:19
http://www.dictionary.com/search?q=realm
realm Pronunciation Key (rlm)
n.
A community or territory over which a sovereign rules; a kingdom.
A field, sphere, or province: the realm of science. See Synonyms at field.
[Middle English realme, from Old French, alteration (influenced by Old French reial, royal), of Latin regimen, government
fromregere, to rule. See reg- in Indo-European Roots.]
Source: The American Heritage® Dictionary of the English Language, Fourth Edition
Copyright © 2000 by Houghton Mifflin Company.
Published by Houghton Mifflin Company. All rights reserved.
realm
\Realm\, n. [OE. realme, ream, reaume, OF. reialme, roialme, F. royaume, fr. (assumed) LL. regalimen, from L. regalis royal. See Regal.] 1. A royal jurisdiction or domain; a region which is under the dominion of a king; a kingdom.
The absolute master of realms on which the sun perpetually alone. --Motley.
2. Hence, in general, province; region; country; domain; department; division; as, the realm of fancy.
Source: Webster's Revised Unabridged Dictionary, © 1996, 1998 MICRA, Inc.
realm
n 1: a domain in which something is dominant; "the untroubled kingdom of reason"; "a land of make-believe"; "the rise of the realm of cotton in the south" [syn: kingdom, land] 2: the domain ruled by a king or queen [syn: kingdom] 3: a knowledge domain that you are interested in or are communicating about; "it was a limited domain of discourse"; "here we enter the region of opinion"; "the realm of the occult" [syn: domain, region]
Source: WordNet ® 1.6, © 1997 Princeton University
|=|=|=||=|=|=||=|=|=| http://www.vanwijck.com |=|=|=||=|=|=||=|=|=||=|=|=||=|=|=||=|=|=||=|=|=|
Op maandag 27 mei 2002 13:09 schreef Predator het volgende:
:P
Bedankt ,hier heb ik iets meer aan.
Op maandag 27 mei 2002 13:14 schreef paulhekje het volgende:
*KNIP*
*(Blablabla)*
*zucht*
Wat heb ik hier, in deze toepassing nou aan?
Maar goed, toch bedankt, hoor :P
  • Predator
Predator
Realm names
In general, realm names are used for network routing and authentication. They provide the identification necessary to forward authentication requests to the server that holds the user's credentials. For example, if your corporation has a wholesale-dial partnership with an ISP, your users' user names will have to include realm information so that the authentication requests can be forwarded to the appropriate RADIUS server.
IAS does not use realm names for routing purposes, but if it receives authentication requests from servers that do, it can strip the realms from the user names before authenticating the names against the domain controller, provided the realm-stripping rules are set up correctly.
A realm name can be a prefix (such as electronic/) or suffix (such as @electronic). The realm name includes any separator characters, such as the at sign (@) or the slash (/). You can require the user to include the realm name as part of the user name at logon. Depending on the dialing program used to access the network, you can also have the dialing program automatically append a prefix or suffix. (You can use the Connection Manager Administration Kit to set up Connection Manager to do this. For more information, see Connection Manager Administration Kit)
If your users log on using realm names, IAS must remove the realm information before forwarding the request to the domain controller
Bron:
http://www.microsoft.com/windows2000/en/server/help/sag_ias_realms.htm?id=2349
  • JackBol
JackBol
Security is not an option!
realm = domain
domain <> realm
net zoiets als
koe = dier
dier <> koe
Op maandag 27 mei 2002 13:37 schreef Dirk-Jan het volgende:
realm = domain
domain <> realm
net zoiets als
koe = dier
dier <> koe
Dus als ik het goed begrijp: realm is een "sub"domein?
  • JackBol
JackBol
Op maandag 27 mei 2002 14:26 schreef brooker het volgende:
jah, eigenlijk ook niet...
domain gaat over een groepje gebruikers
realm gaat bijv. over een groepje mbt. security e.d.
Je hebt bijv een realm bij providers die gebruik maken van een netwerk van hun upstream providers.
Je logt dan in met bijv blabla@providernaam.nl
Dit gebeurt op deze manier zodat de upstream provider @providernaam.nl herkent en dan het verzoek naar de radiusserver van die provider doorstuurt.
T is duidelijker geworden, thx all.
