Kan iemand mij vertellen wat er allemaal in de doos zat van de A40 bij aankoop?? Ik sta op hjet punt er 1 aan te schaffen, maar ik wil wel weten wat er allemaal bij zit(zoals tasje, flashcard?? MB enz).
Bedankt
ISO (Film Speed) Auto, 50, 100, 200, 400
(Auto automatically sets camera to between ISO50 150 equiv.)
Image Compression Still image: JPEG
Movie files: AVI [Image data: Motion JPEG, Audio data: WAVE (monaural)]
Compression Levels Super-Fine, Fine, Normal
Continuous Shooting Yes, approx. 2.5 images/sec. (Large/Fine with LCD OFF)
Image Storage Capacity Still:
Large/Super Fine: 7 images [Approx.]
Large/Fine: 11 images [Approx.]
Large/Normal: 24 images [Approx.]
Middle/Super Fine: 16 images [Approx.]
Middle/Fine: 24 images [Approx.]
Middle/Normal: 46 images [Approx.]
Small/Super Fine: 35 images [Approx.]
Small/Fine: 50 images [Approx.]
Small/Normal : 87 images [Approx.]
Movie:
Large: 18 sec (max. length per movie is 10 sec)
Small: 48 sec. (max. length per movie is 30 sec)
[Movies are shot at approx. 20 frames / sec and times shown are displayed as if the movies were shot continuously]
*Storage capacity varies depending on the scene or subjects The data is estimated from Canons standard shooting conditions
Interface USB I/F
Audio/Video out
Storage Media CompactFlash (CF) card Type I
Lens Focal Length (optical): 5.4 (W) 16.2 (T) mm (35mm film equivalent: 35 105mm)
Maximum Aperture: F2.8 (W) / F4.8 (T)
Construction: 9 elements in 7 groups
Digital Zoom 2.5x [Max. 7.5x zoom combined with optical zoom]
Focus Range Normal: 76cm - ¥
Macro: 16cm(W)/26cm(T) 76cm
Snapshot: 1.5m 2.5m
Infinity: 5m - ¥
Viewfinder Optical & LCD
LCD Monitor Language 1.5" Low-temperature Polycrystalline Silicon TFT Colour LCD(100% coverage)
Shutter Speeds 15 1/1,500 sec.
(Noise reduction is used on shutter speeds of more than 1.3 sec)
Power Source Camera : Size-AA batteries: Alkaline*, NiMH**, Compact power adapter**
Date/Clock backup : CR2016
* 4 x Alkaline batteries supplied
** Optional
Exposure Control Programme Auto Exposure (TTL) / Manual
Exposure Compensation +/- 2.0EV [1/3 step increments]
White Balance Auto, 5 presets [Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent High]
Flash Mode Flash ON/OFF, Auto, Red eye reduction on, Red eye reduction auto, Slow sync
Flash Range Wide Angle: 0.76 4.2m [at ISO 100 equivalent]
Telephoto: 0.76 2.5m [at ISO 100 equivalent]
Dimensions 110.3 x 71 x 37.6 mm [excluding protruding parts]
Weight Approx. 250g [excluding battery and CF card]
CCD Size: 1/2.7 inch
Effective number of Pixels: Approx. 2M Pixel
Total Number of Pixels: Approx. 2.1M Pixel
Filter Array: Primary-colour filter
Recording Pixels Still Images:
Large: 1,600 x 1,200 pixels
Middle: 1,024 x 768 pixels
Small: 640 x 480 pixels
Movie files:
Large: 320 x 240 pixels
Small: 160 x 120 pixels
Light Metering Method Evaluative (linked to focusing point) / Spot
File Format Exif 2.2 compliant
Print Order Format Digital Print Order Format [DPOF v1.1]
Other Features Self-timer: 2 or 10 seconds (selectable)
Signal Sound: Camera Status and Warnings
Stitch Assist: Integrates with the PhotoStitch software to create panoramas
Other Operations Camera Shooting modes: Auto / Program / Manual / Stitch Assist / Movie
Photo Effects: Vivid / Neutral / Low sharpening / Sepia / Black & White
Playback Operations: Single, Multi, Movie, Slide Show, Magnify (2x to 10x)
File Operations: Single Erase, All Erase, Protect, DPOF Marking, Transfer Order Marking, CF Card Formatting
Direct Printing: CP-10, CP-100
Camera Settings: Date/Clock, LCD Menu Languages [English, French, German, Italian, Spanish, Dutch, Swedish, Norwegian, Danish, Finnish, Japanese]
Supported Operating Systems PC: Win 98 (SE), 2000, Me, XP
Mac: OS 8.6 to 9.2
Operating Environment Temperature: 0 40 °C
Humidity: 10 90 %
www.canon.nl
  • GeJe
  • Laatst online: 02-08 21:14
GeJe
Je...
Kijk is op de site van canon, of een retailer zoals dixons. Dan krijg je vast je antwoord wel.
www.dixons.nl
www.canon.nl
Suc6
Vandaag is het feest en morgen ook.
  • Ralph Smeets
  • Laatst online: 29-06 09:03
Ralph Smeets
sinds 10-7-2009
Op maandag 27 mei 2002 09:13 schreef _Nomis_ het volgende:
Bedankt
Ik weet niet hoe het in Nederland zit, maar hier in Frankrijk kun je de A40 in twee versies kopen:
<ol><li>het normale paket:
  • <li>Canon PowerShot A40 <li>4 Alkaline baterijen <li>8MB CompactFlash kaart <li>USB kabel <li>AV kabel <li>Een strapon
<li>In het Plus packet komt daar nog bij:
<ul><li>Acculader
<li>4x NiMH 1800Mah batterijen
<ul></ol>
</nl>
Mestreechs volksleed:
Jao diech höbs us aon 't hart gelege, Mestreech door alle ieuwe heer
Veer bleve diech altied genege, En deilde dreufheid en plezeer....etc.
  • juanp
  • Laatst online: 27-05 20:43
bij mij zat nummer 1 erin van de bovengenoemde post.
  • Frits Flits
  • Laatst online: 06-08 20:38
Frits Flits
SOUND! Designer
- camera (lijkt me logisch ;))
- 4 alkaline batterijen
- 8mb CF kaart
- USB kaart
- 2 cdroms met drivers en programma's
- koortje
- kabel voor camera -> tv
specs
Op maandag 27 mei 2002 11:53 schreef Frits Flits het volgende:
- 8mb CF kaart
- USB kaart
- koortje
usb kabel lijkt me dat ipv kaart
voor de rest, same here :)
Op maandag 27 mei 2002 09:16 schreef questa.unigame een compleet nutteloos verhaal:
Het ging erom wat er in de doos zit! |:(
  • BlackMage
  • Laatst online: 05-07 23:16
Ik heb em vandaag ook gekocht.
Supermooi dingetje.
Maar ik zit met een probleem:
Elke keer als ik hem er in doe start die klotege wizzard scanner en camera op EN nog eens photoshop. Iemand enig idee wat er mis is ?
  • kmf
kmf
