ASUS L3800S Notebook
  • 66 views sinds 30-01-2008
Ik denk erover om een notebook te kopen.
Nu zag ik laatst het volgende notebook op de mycom site (http://www.mycom.nl) --> Asus L3800S >:) voor EUR 2674
Op zich wel een mooi noteboekje dacht ik zo.. :9s
Hieronder nog ff de specs van de 'L3000S Series' notebooks (volgens de asus website), ik denk dat het aardig overeen komt met de specs van de L3800S:
-- SPECS VAN ASUS L3000S SERIES NOTEBOOKS (volgens ASUS) --
Processor & Cache Intel® Pentium® 4-D Processor
FC-PGA2 Package
Pentium® 4-D 1.6G/1.8G/2.0GHz
BIOS AWARD BIOS code
256K Flash EPROM
PMU, Plug & Play
Chipset Intel® 845MP chipset
Main Memory Two SO-DIMM socket for expansion up to 1024 MB
Onboard 256MB DDR SDRAM
Display 14.1"/15.0" active matrix color TFT
XGA/SXGA+/UXGA 256K hi-color (6 bit interface)
Dual Channel LVDS I/F
Graphics & Video ATI® Mobility Radeon 7500
Integrated 32MB DDR SDRAM
RADEON graphics technology
Two 3D pipelines, 3 texture per pipeline
Support PowerPlay
0.15m process
CRT Display Modes VGA 640 x 480, 256/32K/64K/16.7M colors
SVGA 800 x 600 256/32K/64K/16.7M colors
XGA 1024 x 768 256/32K/64K/16.7M colors
SXGA 1280 x 1024 256/32K/64K colors
UXGA 1600x1200 256/32K/64K colors
PC Cards Ricoh R5C552 card bus controller
PCMCIA 2.1 compliant
Two Type II card or One Type III
Non-ZV port
Hard Disk Drive 2.5" 9.5 mm IDE HDD with Ultra DMA100 supported
20GB, 30GB and supports capacity up to 40GB
Fixed type, easy for BTO
Floppy Disk Drive 3.5" 1.44MB floppy disk drive
3 Mode supported
Fixed Type
IrDA IrDA 1.1 compliance
Integrated sided-lens
FIR-4Mbps/SIR-115.2Kbps provided
Modem/Fax & LAN MDC MODEM and LAN on board
Worldwide regulation, CTR21, JATE, FCC...etc passed
CD-ROM/ DVD-ROM/ CD-RW 5.25" 12.7mm height ATAPI 8X (max.) DVD-ROM drive (Fixed Type)
5.25" 12.7mm high ATAPI DVD 8X & CD-RW 8/4/24X (max.) combo drive
System Status Indicator Power-on/Suspend
Batt. Charging/full/low
Storage device access
Cap. Lock
Scroll Lock
Num Lock
E-mail in box
Mute LED indicator
On-Screen Display Brightness
Display selection LCD/Ext. Monitor/Dual
Display selection LCD/TVout
LCD on/off
AC adapter plug in/ Battery in use
Interface/Port One 16550 UART compatible Serial port/D-sub 9-pin
One EPP/ECP Parallel port/D-sub 25-pin
One PS/2 Keyboard/Mouse port
One Infrared port support IrDA V1.1
One S/PDIF/ Headphone-out jack (Stereo)
One Microphone-in jack (Mono)
One VGA port/Mini D-sub 15-pin for external DDC monitor
One Video Connector which including S-Signal and Composite video signal
One RJ11 Modem jack for phone line
One RJ45 LAN Jack for LAN insert
Two USB ports
Two IEEE 1394 ports
One Port-Bar II support
Keyboard 19 mm full size 88key with MS-Windows function keys
3mm travel
Display selection LCD/CRT switch
LCD Brightness control
Num keypad enable
Hot Keys AC 97 S/W audio
SoundBlaster® Pro Compatible
Build-in stereo two one watt speakers with chamber and one microphone
Digital VR volume control with mute switch
Hot Keys Instant launch Keys
4 buttons
Email, Internet, programmable App1, Power4Gear
Function Keys
Fn+F1 Suspend switch
Fn+F2 Wireless switch
Fn+F5 Brightness up
Fn+F6 Brightness down
Fn+F7 LCD only
Fn+F8 LCD/CRT/TV-out switch display
Fn+F10 Volume on/mute
Fn+F11 Volume down
Fn+F12 Volume up
Power Management Full feature SMI power management, supports Stand-by, Suspend to Disk, and Suspend to RAM
ACPI 1.0 supported
Battery Pack Li-Ion 18650 8 cells, 2000mAh, 59Whrs (Typical)
Run-Down life, 2 hrs with one battery pack
Smart battery charger, charging time, 4hrs/2.5 hrs (System On/ Off) to 95%
AC Adapter Output: 19V DC, 3.64A, 65W
Input: 100~240V AC, 50/60Hz universal
Pointing Device Built-in touch pad pointing device
2 click buttons and 2 scroll bottons
Thermal Solution ADTD(Developed by Asus)to handle 35W CPU thermal envelope
55x55x11 low-power, low-noise cooling fan with FAN speed sensor
Support OS Microsoft® Windows XP Pro
Microsoft® Windows ME
Microsoft® Windows 2000
Security Pre-OS Authentication by programmable key code
BIOS Booting User Password Protection
HDD User Password Protection and Security Lock
Kensington Lock hole provided
Dimensions 326 x 267 x 37-42mm (W x D x H, typical)
Weight 3.2kg (w/ 15" LCD, 9.5mm HDD,8 x DVD-ROM and 8 cells Li-Ion battery pack)
Optional Item:
IEEE 802.11b Wireless LAN (Factory option) MiniPCI I/F.
Built-in antenna
IEEE 802.11b compliant
11Mb/s data transfer rate
----------------- END -------------------------------------
Dit zijn de specs van de ASUS L3800S (volgens MyCOM) <-- Het notebook dat ik overweeg te gaan kopen, ik denk dat we aan de hand van de specs van de ASUS L3000S SERIES (zie hierboven) wel kunnen nagaan welke merken / snelheden etc. er precies inzitten... :
-- SPECS VAN DE ASUS L3800S NOTEBOOK (mycom) --
Intel Pentium 4 2,0 ghz
15,1 " TFT
32 MB ATI
256 MB geheugen
40 GB HDD
1,44 MB FDD , 3,5"
Li-ion batterij
56kbs Fax/Modem
10/100 mbit LAN
2x FireWire 1394
2x USB
Externe VGA
Combo CD-RW/DVD
Luxe tas :P
2 jr. garantie
----- END --------
Hoe denken de mensen op dit forum over deze notebook?
(evt. plus/min punten/ervaringen zijn ALTIJD welkom)
En ehh... wel of niet kopen? (of toch de medion van de aldi?)
  • Ferdo
  • Laatst online: 17-01 17:24
Ferdo
Dido Armstrong :9~
[topic=218256/1/500] ;)
Audioscrobbler profile
Begin de dag met een dansje, begin de dag met een lach,
want wie vrolijk kijkt in de morgen, die lacht de hele dag,
jaaa, die lacht de hele dag!
Een merkenoorlog is wel 't laatste wat ik wil :)
  • LopeZ
  • Laatst online: 21:19
LopeZ
Too much is never enough
