Iemand die dit programma ooit gebruikt ?
klinkt leuk .. zou het iets zijn ? of kent iemand soortgelijke programma's ?
| An easy to use fully featured e-commerce web site builder designed for those who need full control over every design aspect. With its powerful adjustable templates ShopFactory Developer makes it possible to create virtually any design you can imagine. If you need to take that extra step and require full control over every design aspect of your shop, the Developer version is for you Pre designed Shop Themes mean you have highly professional shops up and running in no time. These themes are also a great starting point for further customization according to your needs, and demonstrate the extreme design flexibility of ShopFactory Developer. The included Developer Tutorial explains how the templates work, and how you can modify them to achieve the look you need - for example to create a new shop which matches the look of an existing website. |
