[ArcserveIT 6.6]Not a valid job queue
  • DGTL_Magician
  • Laatst online: 28-10 16:43
DGTL_Magician
Kijkt regelmatig vooruit
Ik wil op het werk Groupwise gaan backuppen, en wil daar ArcserveIT 6.6 voor gebruiken. Dit draait ook op andere servers, dus het werkt in ieder geval.
Maar nu krijgen we een vreemd probleem te verwerken.
De server is een HP Netserver LC2000 u3 met een HP Surestore DAT 40 tape drive.
Hier is de inhoud van het logfile:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
May-24 12:10:32    Using configuration file SYS:\ARCSERVE.6\ASCONFIG.INI.
May-24 12:10:35
May-24 12:10:35    Loading SYS:\ARCSERVE.6\NLM\PFC.NLM /NC /PFASCONFIG.INI /M
             /FSYS:\ARCSERVE.6\NLMINFO.LOG
May-24 12:10:36    CA Pre Flight Check (Build  111.237 12/16/99)
May-24 12:10:37    Version 6.60  December 16, 1999
May-24 12:10:37    Option [IncludeNCFFiles] is DISABLED
May-24 12:10:37    PFC: Checking only NLM information
May-24 12:10:53    PFC: Information is saved to file
May-24 12:10:53    PFC: NLMs found meet the requirement
May-24 12:10:56
May-24 12:10:57    Loading SYS:\SYSTEM\TLI.NLM
May-24 12:10:57    [TLI.NLM] is ALREADY loaded.
May-24 12:10:58
May-24 12:10:59    Loading SYS:\SYSTEM\BTRIEVE.NLM -p=4096 -f=30 -h=60 -l=20
             -t=15 -u=0 -s=30 -m=512
May-24 12:10:59    [BTRIEVE.NLM] is ALREADY loaded.
May-24 12:11:00
May-24 12:11:00    Loading SYS:\ARCSERVE.6\NLM\CSDBAPIB.NLM
May-24 12:11:01    ARCserveIT Database API (Build  111.235 08/18/99)
May-24 12:11:01    ARCserveIT Database API is loaded
May-24 12:11:01    Version 6.60  August 18, 1999
May-24 12:11:05
May-24 12:11:05    Loading SYS:\SYSTEM\DSAPI.NLM
May-24 12:11:06    [DSAPI.NLM] is ALREADY loaded.
May-24 12:11:06
May-24 12:11:07
May-24 12:11:07
May-24 12:11:08    Loading SYS:\ARCSERVE.6\NLM\ASPIBD.NLM HOST=2 NAME=BOARD0
May-24 12:11:09    A total of 3 ASPI Adapters Found
May-24 12:11:09    ASPIBD.NLM for ASPI Manager.
May-24 12:11:09    Initializing SCSI board, Please Standby...
May-24 12:11:10   CA Board Name : BOARD0
May-24 12:11:10   Board       : SYM53C1010:10007
May-24 12:11:11   Host number     : 2
May-24 12:11:11   SCSIID         : 7
May-24 12:11:11   Memory above 16MB  : Not Supported
May-24 12:11:12    ASPIBD.NLM for Host 2 loaded successfully
May-24 12:11:12    ARCserveIT 6.6 SCSI Board Driver (Build  111.239
             01/10/00)
May-24 12:11:13    Version 6.60  January 10, 2000
May-24 12:11:17    SCSI Board Driver is ready
May-24 12:11:21
May-24 12:11:21    Loading SYS:\ARCSERVE.6\NLM\PFC.NLM /NC /PFASCONFIG.INI
May-24 12:11:22    CA Pre Flight Check (Build  111.237 12/16/99)
May-24 12:11:22    Version 6.60  December 16, 1999
May-24 12:11:23    Option [IncludeNCFFiles] is DISABLED
May-24 12:11:23    Checking server configuration, Please wait ...
May-24 12:11:24    1 host adapter(s) found
May-24 12:11:42    E21029 server does not have valid job queue or queue user
             for product ARCserveIT - [-14]
May-24 12:11:43    E21111 No backup device found on host Adapter [BOARD0]
May-24 12:12:12    PFC: E21104 Check the SCSI hardware
May-24 12:12:12    PFC: Job queue needs to be fixed
May-24 12:12:12    PFC: Information is saved to file
             SYS:\ARCSERVE.6\NLM\PFC.ERR
May-24 12:12:13    PFC.NLM reported a critical error.  No more modules will
             be loaded.
May-24 12:12:13
Wat ik het vreemde vindt is dat hij eerst de tape drive wel schijnt te vinden, maar na de eerste fout geeft hij ook aan dat hij geen backup device kan vinden.
Iemand dit al eens tegen gekomen?
Ik heb ook al een herinstallatie van Arcserve gedaan nadat ik de SMDR bestanden, de NDS objecten en de Arcserve6 directory verwijderd heb.
Blog | aaZoo - (Wireless) Networking, Security, DDoS Mitigatie, Virtualisatie en Storage
Het lijkt er op of je NDS objecten weg/corrupt zijn. Maak deze opnieuw aan met as6util die bij ArcServe geleverd is.
Wat is dit....??
May-24 12:12:12 E21111 No backup device found on host Adapter [BOARD0] PFC: E21104 Check the SCSI hardware
Kijk daar ook maar eens naar
  • DGTL_Magician
DGTL_Magician
Dat heb ik dus al gedaan zoals ik al zei. Ik vraag me af of het wat te maken kan hebben met eDirectory 8.6.1, na die tijd hebben we namelijk geen Arcserve installaties meer uitgevoerd.
  • DGTL_Magician
DGTL_Magician
Op vrijdag 24 mei 2002 13:21 schreef Toetie het volgende:
Wat is dit....??
Heb ik dus ook gedaan. Maar de configuratie is exact gelijk aan een identieke server die we hebben staan. En het werkt ook. Hij ziet de devices in MONITOR namelijk.
Er wordt een SCSI-driver geladen voor de SCSI-kaart. Ik zie echter geen SCSI-device (oftewel de tape-unit) voorbij komen in je LOG-file. Is het apparaat wel goed aangesloten?
Verder moet je AS6UTIL.EXE (staat in de UTILITY-directory) gebruiken om de NDS-objecten weer goed aan te maken.
NB: Zo te zien gebruik je nu een ASPI-driver (NWASPI ofzo).
Wanneer je het laatste service-pack van Arcserve installeert, kun je CA's eigen driver gebruiken: CANWPA.CDM. Deze werkt beter (vind ik) en geeft duidelijkere meldingen in je LOG over het vinden van adapters en devices.
  • DGTL_Magician
DGTL_Magician
Op vrijdag 24 mei 2002 13:26 schreef Humulus het volgende:
De Hardware moet in orde zijn. Ik heb de laatste SP van Arcserve er al op. Hoe gebruik ik die CANWPA.CDM ? Gewoon NWASPI unloaden en CANWPA starten?
Eerst arcserve gewoon starten, daarna kun je met de devicemanager je configuratie aanpassen. :)
Aangezien arcserve echter niet gewoon wil starten bij je, zal je handmatig een bestandje moeten aanpassen.
In de arcserve-directory staat ASCONFIG.INI. In de sectie [loader] moet voor de PFC (PreFlightCheck) de driver geladen worden met CANWPABD CLEAR
Hieronder volgt de [loader]-sectie van mijn configuratie. Bij CSNLM6 staat de CANWPA. Let ook op de regel met ORDER, hierin staat in welke volgorde de NLMs geladen worden:
[loader]
CSNLM1=SYS:\ARCSERVE.6\NLM\PFC /NC /PFASCONFIG.INI /M /FSYS:\ARCSERVE.6\NLMINFO.LOG
NLM2=SYS:\SYSTEM\TLI
NLM3=BTRIEVE -p=4096 -f=30 -h=60 -l=20 -t=15 -u=0 -s=30 -m=512
CSNLM4=SYS:\ARCSERVE.6\NLM\CSDBAPIB
NLM5=SYS:\SYSTEM\DSAPI
CSNLM100=RESERVED
CSNLM101=RESERVED
CSNLM6=SYS:\ARCSERVE.6\NLM\CANWPABD CLEAR
Adapter0=Board0,COMPAQ Integrated 32-Bit Fast SCSI-2 (ASPI)
CSNLM7=SYS:\ARCSERVE.6\NLM\PFC /NC /PFASCONFIG.INI
CSNLM8=SYS:\ARCSERVE.6\NLM\ASDB
CSNLM9=SYS:\ARCSERVE.6\NLM\ARCSERVE -i
CSNLM10=SYS:\ARCSERVE.6\NLM\TAPESVR
CSNLM11=SYS:\ARCSERVE.6\NLM\TAPEALRT
CSNLM12=SYS:\ARCSERVE.6\NLM\CLIENTS
ORDER=CSNLM1 NLM2 NLM3 CSNLM4 NLM5 CSNLM100 CSNLM101 CSNLM6 CSNLM7 CSNLM8
ORDER1=CSNLM9 CSNLM10 CSNLM11
PauseBeforeEachNLM=NO
AppendToLog=NO
SecureConsole=NO
DisableAutoUnload=NO
CheckIfNLMIsLoaded=ARCSERVE.NLM
<edit>
Oja, NWASPI kun je dan inderdaad ontladen ja. Of je moet nog iets hebben draaien wat dat nodig heeft.
</edit>
  • DGTL_Magician
DGTL_Magician
Het helpt dus niet, dezelfde fout als eerst komt weer op het beeldscherm. Bij het opstarten ziet hij de Tape drive wel, dus het heeft volgens mij iets te maken met de Directory. Hier komt iig het volgende logfile uit:
CANWPABD.TXT
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
Reseting Config File.
Reading Tapesvr.cfg file.
Getting Adapter Info for Adapter : [0]
Building Device List for This Adapter.
Getting MM_Return_Object_Generic_Info for ID[1]
Getting MM_Return_Object_Generic_Info for ID[3]
Getting MM_Return_Object_Generic_Info for ID[c]
Getting Lun ID from CDM.
The Lun ID is : 0
Getting SCSI ID from CDM.
The SCSI ID is : 2
Getting HOST ID from CDM.
Getting Chey CDM Handle.
Getting CDM Handle Passed, handle is : 0
Getting Below16MegFlag from CDM.
Getting PORT from CDM.
The PORT ID is : 9216
Getting SLOT from CDM.
The SLOT ID is : 10008
Saving Adapter info in config file
REGISTERING CONTROLLER [BOARD0]
Packaging data for boardsvr.
BOARDNAME = [BOARD0]
device=[1]
scsiDeviceList (adapterObjectID) : 11
scsiDeviceList (HostNumber) : 11
scsiDeviceList (lunID)       : 0
scsiDeviceList (deviceObjectID)  : 12
scsiDeviceList (scsiID)     : 2
scsiDeviceList (cdmhandle)   : 0
scsiDeviceList (slot)       : 10008
scsiDeviceList (port)       : 9216
CSLOADER.TXT
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
May-24 14:13:26    Using configuration file SYS:\ARCSERVE.6\ASCONFIG.INI.
May-24 14:13:28
May-24 14:13:28    Loading SYS:\ARCSERVE.6\NLM\PFC.NLM /NC /PFASCONFIG.INI /M
May-24 14:13:29    CA Pre Flight Check (Build  111.237 12/16/99)
May-24 14:13:30    Version 6.60  December 16, 1999
May-24 14:13:30    Option [IncludeNCFFiles] is DISABLED
May-24 14:13:30    PFC: Checking only NLM information
May-24 14:13:46    PFC: Information is saved to file
May-24 14:13:47    PFC: NLMs found meet the requirement
May-24 14:13:50
May-24 14:13:50    Loading SYS:\SYSTEM\TLI.NLM
May-24 14:13:51    [TLI.NLM] is ALREADY loaded.
May-24 14:13:51
May-24 14:13:52    Loading SYS:\SYSTEM\BTRIEVE.NLM -p=4096 -f=30 -h=60 -l=20
May-24 14:13:53    [BTRIEVE.NLM] is ALREADY loaded.
May-24 14:13:53
May-24 14:13:54    Loading SYS:\ARCSERVE.6\NLM\CSDBAPIB.NLM
May-24 14:13:54    ARCserveIT Database API (Build  111.235 08/18/99)
May-24 14:13:54    ARCserveIT Database API is loaded
May-24 14:13:55    Version 6.60  August 18, 1999
May-24 14:13:58
May-24 14:13:59    Loading SYS:\SYSTEM\DSAPI.NLM
May-24 14:13:59    [DSAPI.NLM] is ALREADY loaded.
May-24 14:14:00
May-24 14:14:00
May-24 14:14:01
May-24 14:14:01    Loading SYS:\ARCSERVE.6\NLM\CANWPABD.NLM CLEAR
May-24 14:14:02    The [NWPA] section of the Configuration File has been
             cleared.
May-24 14:14:02    Searching for valid Adapters, Please wait.
May-24 14:14:03    ********************************************************
May-24 14:14:03    BINDING : ADAPTER [MEGA4_XX.HAM]  /  [1] DEVICES
May-24 14:14:03    DEVICE[0] : +[V370-A0-D0:0] MegaRAID  LD01 RAID5 rev:H
             Not Registered
May-24 14:14:04    ********************************************************
May-24 14:14:04    Searching for valid Adapters, Please wait.
May-24 14:14:08    ********************************************************
May-24 14:14:08    BINDING : ADAPTER [IDEATA.HAM]  /  [1] DEVICES
May-24 14:14:09    DEVICE[0] : )[V025-A1-D0:0] LITEON CD-ROM LTN486S YKS4 Not
             Registered
May-24 14:14:09    ********************************************************
May-24 14:14:10    Searching for valid Adapters, Please wait.
May-24 14:14:15    Searching for valid Adapters, Please wait.
May-24 14:14:20    Searching for valid Adapters, Please wait.
May-24 14:14:25    Searching for valid Adapters, Please wait.
May-24 14:14:31    Searching for valid Adapters, Please wait.
May-24 14:14:36    Searching for valid Adapters, Please wait.
May-24 14:14:41    Searching for valid Adapters, Please wait.
May-24 14:14:46    ********************************************************
May-24 14:14:47    BINDING : ADAPTER [LSI_U3NW.HAM]  /  [1] DEVICES
May-24 14:14:47    DEVICE[0] : *[V355-A3-D2:0] HP   C5683A      C00 Is
             Registered
May-24 14:14:48    ********************************************************
May-24 14:14:48    Searching for valid Adapters, Please wait.
May-24 14:14:49    ARCserveIT 6.6 SCSI Board Driver (Build  111.239
             01/10/00)
May-24 14:14:49    Version 6.60  January 10, 2000
May-24 14:14:53    SCSI Board Driver is ready
May-24 14:14:57
May-24 14:14:57    Loading SYS:\ARCSERVE.6\NLM\PFC.NLM /NC /PFASCONFIG.INI
May-24 14:14:58    CA Pre Flight Check (Build  111.237 12/16/99)
May-24 14:14:58    Version 6.60  December 16, 1999
May-24 14:14:59    Option [IncludeNCFFiles] is DISABLED
May-24 14:14:59    Checking server configuration, Please wait ...
May-24 14:15:00    1 host adapter(s) found
May-24 14:15:15    E21029 server does not have valid job queue or queue user
             for product ARCserveIT - [-18]
May-24 14:15:16    E21111 No backup device found on host Adapter [BOARD0]
May-24 14:15:45    PFC: E21104 Check the SCSI hardware
May-24 14:15:45    PFC: Job queue needs to be fixed
May-24 14:15:46    PFC: Information is saved to file
May-24 14:15:46    PFC.NLM reported a critical error.  No more modules will
             be loaded.
May-24 14:15:47
Ik heb eens even voor je gekeken bij support.ca.com, misschien is dit de oplossing:
PROBLEM: E21111 No Backup Device Found,error occurs after applying service pak
Checking the csloader.log file the following was found :
Loading SYS:\ARCSERV6.6\NLM\ASPIBD.NLM HOST=0 NAME=BOARD0
Dec-14 15:39:14 A total of 1 ASPI Adapters Found
Dec-14 15:39:15 ASPIBD.NLM for ASPI Manager.
Dec-14 15:39:16 Initializing SCSI board, Please Standby...
Dec-14 15:39:16 CA Board Name : BOARD0
Dec-14 15:39:17 Board : ADAPTEC AHA-152x
Dec-14 15:39:17 Host number : 0
Dec-14 15:39:17 SCSIID : 7
Dec-14 15:39:17 Memory above 16MB : Not Supported
The line above is telling you the scsi card is not being see as a 32 Bit Contoller
RESOLUTION: If the tape drive is attached to a 32 Bit Controller add the line USEABOVE16 to the load line for ASPIBD. If the client is using a 16 Bit Controller, advise them to replace the controller with an appropriate 32 Bit Controller. Adding the USEABOVE16 Line to ASPIBD will cause the server to ABEND if the client tries to use this with a 16 Bit Controller. The USEABOVE16 command can also be used with the CANWPABD driver. IMPORTANT NOTE: DLT, AIT, DDS3, or any other drives that use a 64k blocksize are no longer supported when used with a 16 bit controller board.
  • DGTL_Magician
DGTL_Magician
Op vrijdag 24 mei 2002 14:32 schreef Humulus het volgende:
Nope, dit werkt ook niet. Ik had zelf ook al op support.ca.com gekeken. Een echt behulpzame site vindt ik het niet, maar ja. De oude Novell site werkte nog steeds het beste.
De leverancier weet ook niet waar het aan kan liggen, ik vindt het heel vreemd allemaal. Mijn gok zit nog steeds op eDirectory.
  • DGTL_Magician
DGTL_Magician
Kleine update.
Als ik nu een AS6UTIL start en de Queue en de Queue server aanmaak, dan krijg ik bij het aanmaken van de Queue een -672 error. "The queue may be in unstable state"
Dus daar zit de fout dus. ff kijken wat er gebeurt als ik met de hand een queue aanmaak in de NDS.
Misschien eens een DSrepair uitvoeren?
  • DGTL_Magician
DGTL_Magician
Dat doe ik iedere morgen als standaard op alle replica dragende servers. Ik was al bezig met een DSRepair trouwens. Great minds think alike. ;)
We hebben overigens net een nieuw netwerk. Sinds 2 weken uit de testomgeving. Werkt lekker snel. Weinig fouten. Nu dus weer 0 fouten.
ok, weer een update:
Ik heb nu de queue weer succesvol kunnen aanmaken.
Ik ga Astart6 weer draaien, en anders heb ik nog een TID gevonden:
Title: E21029 Server does not have valid job queue or queue user-14
Date: 01/28/99
Product: ASNW
Build: 111.xxx
PROBLEM:  E21029 Server does not have valid job Queue or Queue user for
product ARCserve-14. When using the command line as6util that ships with 6.6 to
 verify the Server a nd Queue we get error -219.
RESOLUTION: By updating to the latest service pac level for ARCserveIT 6.6
 for Netware (at this time of documenting lo70914.zip) then running the As6util.nlm
 and choose the option Select This to Modify User. Once this is
accomplished restart ARCserveIT.
En weer een update: het werkt nog niet.
  • DGTL_Magician
DGTL_Magician
Ik ben 1 fout kwijt, nu de E21111 nog oplossen.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
May-24 15:08:28    Using configuration file SYS:\ARCSERVE.6\ASCONFIG.INI.
May-24 15:08:30
May-24 15:08:31    Loading SYS:\ARCSERVE.6\NLM\PFC.NLM /NC /PFASCONFIG.INI /M
May-24 15:08:32    CA Pre Flight Check (Build  111.237 12/16/99)
May-24 15:08:32    Version 6.60  December 16, 1999
May-24 15:08:32    Option [IncludeNCFFiles] is DISABLED
May-24 15:08:33    PFC: Checking only NLM information
May-24 15:08:48    PFC: Information is saved to file
May-24 15:08:49    PFC: NLMs found meet the requirement
May-24 15:08:52
May-24 15:08:52    Loading SYS:\SYSTEM\TLI.NLM
May-24 15:08:53    [TLI.NLM] is ALREADY loaded.
May-24 15:08:53
May-24 15:08:54    Loading SYS:\SYSTEM\BTRIEVE.NLM -p=4096 -f=30 -h=60 -l=20
May-24 15:08:55    [BTRIEVE.NLM] is ALREADY loaded.
May-24 15:08:55
May-24 15:08:56    Loading SYS:\ARCSERVE.6\NLM\CSDBAPIB.NLM
May-24 15:08:56    ARCserveIT Database API (Build  111.235 08/18/99)
May-24 15:08:57    ARCserveIT Database API is loaded
May-24 15:08:57    Version 6.60  August 18, 1999
May-24 15:09:00
May-24 15:09:01    Loading SYS:\SYSTEM\DSAPI.NLM
May-24 15:09:01    [DSAPI.NLM] is ALREADY loaded.
May-24 15:09:02
May-24 15:09:02
May-24 15:09:03
May-24 15:09:03    Loading SYS:\ARCSERVE.6\NLM\ASPIBD.NLM HOST=2 NAME=BOARD0
             USEABOVE16
May-24 15:09:04    A total of 3 ASPI Adapters Found
May-24 15:09:05    ASPIBD.NLM for ASPI Manager.
May-24 15:09:05    Initializing SCSI board, Please Standby...
May-24 15:09:05   CA Board Name : BOARD0
May-24 15:09:06   Board       : SYM53C1010:10007
May-24 15:09:06   Host number     : 2
May-24 15:09:06   SCSIID         : 7
May-24 15:09:07   Memory above 16MB  : Supported
May-24 15:09:07    ASPIBD.NLM for Host 2 loaded successfully
May-24 15:09:08    ARCserveIT 6.6 SCSI Board Driver (Build  111.239
             01/10/00)
May-24 15:09:08    Version 6.60  January 10, 2000
May-24 15:09:13    SCSI Board Driver is ready
May-24 15:09:16
May-24 15:09:17    Loading SYS:\ARCSERVE.6\NLM\PFC.NLM /NC /PFASCONFIG.INI
May-24 15:09:17    CA Pre Flight Check (Build  111.237 12/16/99)
May-24 15:09:18    Version 6.60  December 16, 1999
May-24 15:09:18    Option [IncludeNCFFiles] is DISABLED
May-24 15:09:19    Checking server configuration, Please wait ...
May-24 15:09:19    1 host adapter(s) found
May-24 15:09:35    ARCserveIT server has valid job queue and queue user
May-24 15:09:35    E21111 No backup device found on host Adapter [BOARD0]
May-24 15:10:04    PFC: E21104 Check the SCSI hardware
May-24 15:10:05    PFC: Information is saved to file
May-24 15:10:05    PFC.NLM reported a critical error.  No more modules will
             be loaded.
May-24 15:10:06
Die TID hierboven hielp inderdaad tegen de fout E21029
Tsja, Als ik CA mag geloven is het toch echt een hardware fout.
vreemd, want de CANWPA ziet hem wel:
Registered
Misschien de server en de tape-unit een koude start geven?
  • DGTL_Magician
DGTL_Magician
Op vrijdag 24 mei 2002 15:21 schreef Humulus het volgende:
Registered
Een koude start is nog een idee. Ik probeer het iig nog eens met de CANWPA.
Succes, ik ga weekend houden :P
  • DGTL_Magician
DGTL_Magician
Op vrijdag 24 mei 2002 16:20 schreef Humulus het volgende:
Prettig weekend. Ik ben er nu ook achter trouwens. Het blijkt dat in ASCONFIG.INI 2x een load command voor de Pre Flight Check staat. En in de order direct na het laden van de board start de PFC dus nogmaals. Ik heb het ertussenweg gehaald, en inderdaad het werkt!
Als de PFC voor de 2e keer start ziet ie namelijk de al geregistreerde boards niet, en abort hij het hele proces!
Ik ben er toch weer de hele middag mee bezig geweest!
