DVD- RW / DVD ram..???
Wat is nou het verschil tussen DVD-RW of DVD-Ram..??
Welke zijn op dit moment de standaard..?
En hoeveel capaciteit kan ik kwijt op een DVD-...
En welk File system heeft DVD, kan dit ook NTFS zijn
  • TERW_DAN
TERW_DAN
Met een hamer past alles.
een filesystem zal CDFS zijn.
NTFS of FAT bestaat niet op cds.
enne, dit mag in OM.
  • Bulldog
Op vrijdag 24 mei 2002 12:02 schreef Terw_Dan het volgende:
Iemand die mij nog wat info kan geven...???
  • Taurec
  • Laatst online: 09-04 10:56
Op vrijdag 24 mei 2002 13:55 schreef CoolBlue het volgende:
http://www.anandtech.com/guides/viewfaq.html?i=118
DVD-RAM
DVD-RAM is a format primarily used as a data solution, although the type of data stored can include many types of data including video. Early version 1 recorders used 2.6 GB discs (or double-sided 5.2 GB discs), but current version 2 drives can handle 4.7 GB discs (or double-sided 9.4 GB discs). These discs are traditionally housed within a cartridge which cannot be opened, so that the media is well-protected. Newer Type 2 cartridges can be opened however, which is important for some people who wish to read these discs in drives or standalone DVD-Video players/recorders which do not use the DVD-RAM cartridge loading mechanism.
DVD-RAM is a sanctioned format of the DVD Forum, a consortium of companies involved in the development of DVD standards. DVD-RAM is a very robust data storage solution, theoretically allowing greater than 100000 rewrites per disc. In addition, similar to a hard drive, it allows full random read/write access and has defect management. An additional benefit of DVD-RAM is that, having been around for several years, it is a tried and true technology which has native support in Windows XP and Mac OS X. The discs are usually formatted with the UDF format, but can be formatted to such formats as FAT32 in Windows and HFS+ for Mac, or others. The main drawback of DVD-RAM is its very limited read compatibility in DVD-ROM drives and standalone DVD-Video players. DVD-RAM read support in these machines is increasing however.
DVD-R and DVD-RW
DVD-R and DVD-RW are both also supported formats of the DVD Forum. Both formats generally use 4.7 GB discs (generally without cartridges), although some DVD-R drives used 3.95 GB discs.
DVD-R is a write-once recordable format which allows excellent compatibility with both standalone DVD-video players and DVD-ROM drives. There are two main types of 4.7 GB DVD-R discs: DVD-R for General Use and DVD-R for Authoring. Most consumer drives use the former cheaper General Use discs, while many higher end professional drives use Authoring discs. The correct media type appropriate for the drive must be used when burning. However, once burned, the discs should be able to be read in either drive type. (General Use DVD-Rs are designed to prevent backup of encrypted commercial DVDs.)
DVD-RW uses rewritable discs which are rated at more than 1000 rewrites in ideal situations. Unfortunately, DVD-RW does not enjoy the same excellent compatibility with DVD-ROM drives and standalone DVD-Video players that DVD-R enjoys. Another drawback is that unlike DVD-RAM, one must generally erase a DVD-RW disc before reuse.
Most DVD-RW drives should also be able to record to DVD-R. However, the reverse is not true. Many older and some current DVD-R drives are not capable of writing to DVD-RW discs (but may be able to read burned DVD-RW discs). Some drives can also record to CD-R and CD-RW.
Currently DVD-RW and DVD-R have heavy penetration into the multimedia market as well as the general consumer market. For instance the Apple SuperDrive, found in higher end Mac computers used in multimedia creation, is simply a DVD-R/DVD-RW (and CD-R/CD-RW) capable drive.
  • Angels2
  • Laatst online: 15-03-2025
We mogen wel DVD+RW niet uit het oog verliezen dat door een heleboel groten (Ricoh, HP, Dell, Philips,..) op de markt gezet wordt. Ook Microsoft gaat +RW meeintegreren in een volgend OS. +RW is een ontwikkeling van Philips en Ricoh.
Meer info op:
Officieel:
http://www.dvdrw.com/
Niet officieel:
http://www.dvdplusrw.org/
