[bios] Nieuw Cheepoman OC bios voor K7S5A uit...
  • 235 views sinds 30-01-2008
  • jhead22
Er is weer een nieuw Cheepoman bios uit voor de ECS K7S5A...
Kweet niet wat er nieuw is etc... (probeer op eigen risico)
http://forum.ocworkbench.com/ocwbcgi/ultimatebb.cgi?ubb=get_topic&f=27&t=005197
http://www.ocworkbench.com/bios/ecs/k7s5a/Chb0429.zip (Non_LAN)
http://www.ocworkbench.com/bios/ecs/k7s5a/Chb0429f.zip (Fast Write enabled)
http://www.ocworkbench.com/bios/ecs/k7s5a/Chb0429l.zip (LAN)
  • Teun
  • Laatst online: 15-10-2025
Teun
Was YoMaN
ff flashen
CheepoBios 1.01 for K7S5A
Based on ECS 020429
chb0429.rom non-lan Version
chb0429l.rom lan version
chb0429f.rom lan version with fastwrites enabled (disable lan in bios Setup to use it on a non-lan board)
Release notes:
- Adjust timing for stability and compatibility ;)
- FSB modes reprogrammed:
"100/100 MHz" changed from 99.6 to 100.9 MHz
"133/133 MHz" changed from 132.77 to 133.9 MHz
No more underclocking by default!
- Several FSB modes added. New list of available modes:
100/100 MHz
100/133 MHz
133/133 MHz -> Default modes
66/66 MHz (H/W Trap)
112/112 MHz
124/124 MHz
138/138 MHz
150/150 MHz
166/166 MHz -> Already present in the "OC" bios
110/110 MHz * (replaces 107/107 from the previous cheepobios)
133/100 MHz
143/143 MHz
147/147 MHz
133/166 MHz
160/120 MHz
200/200 MHz
Please note that the "166 MHz no-boot issue" hasn't been dealt with
in this bios modification. It seems that bios timings need to be adjusted to allow
booting at such speed. This issue could also affect 160/120 and 200/200
settings.
- Extra memory settings:
- RAS Precharge Time=2T
- RAS Active Time=4T, 5T
- Full screen logo can be enabled/disabled via bios menu
- A few hidden bios options have been enabled with amibcp. Please notice that none of these settings have been fixed or reprogrammed at all.
- PCI Latency Timer
- PCI IDE busmaster
- PCI slot #1 to #4 IRQ priority
- IO APIC
The default values for these settings, as well as all other settings, remain the same as in the original bios.
I wish to thank Jinxter, tw.p, Bench400 and Beheerder: deblokker mij, fellow bios modders
at www.ocworkbench.com/ecs for their useful ideas, discussion and testing
Cheepoman 21 May 2002
Poll: does anyone actually read the readme files??? :D
----~----~<{ Join [DPC]Division Brabant!! }>~----~-----
  • Demo
  • Laatst online: 10-09 13:14
Demo
Probleemschietende Tovenaar
Zijn er ook van die BIOSsen voor de Epox 8KHA+?
Unix doesn't prevent a user from doing stupid things, because that would necessarily prevent them from doing brilliant things.
while true ; do echo -n "bla" ; sleep 1 ; done
  • Teun
Teun
Was YoMaN
Op donderdag 23 mei 2002 13:36 schreef Demoniac het volgende:
Ja, ik ben ook te goed B-) , volgende keer ff op de site kijken. Dat wil wel eens helpen.
http://forum.ocworkbench.com/ocwbcgi/ultimatebb.cgi?ubb=forum&f=28
http://forum.ocworkbench.com/ocwbcgi/ultimatebb.cgi?ubb=get_topic&f=28&t=000187 hier staat wat over een bios.
Ook leuk om te weten is de IO APIC. Die schakelt een boel IRQ's vrij. Ca 22-24.
Ga hem testen als ik alles ff gebackuped heb. Moet daarna toch een nieuwe install uitvoeren. :)
Had hem ook voor de meuktracker gesubmit. Moet nog doorsijpelen?
PCI IDE Busmaster is only working in DOS-like environments (where Bios controls Hardware)and may speed-up your System Boot especially if you reboot from Suspend-to-Disk .
Or if you're restoring System backups .
If I remeber correctly IO APIC means Advanced Programmable Interrupt controller .
If enabled you should have more IRQs - up to IRQ 22 or 24).
He he, ik heb net geflashed, mooi nix meer. Dus ben nu ff bezig met een disk te maken die em weer goed kan maken (probeer de nieuwste OC bios)
Ik zal snel weer posten (hopelijk op mijn eigen PC)
  • ModmaN
  • Laatst online: 27-07-2015
ModmaN
Damn i'm good
hmmmmmz, toch nog maar ff w88 met flashen van mijn bios.
die irq-assigning staan mij wel aan, en wat meer instellingen is al een verbeteing op zich van het bios.
maar goed, nog maar ff w88 tot de bugs eruit zijn :P
get rich or die try'in
Ok, met het orginele bios van ECS heb ik het weer goed gekregen (nieuwste versie) Nu nog eens proberen te flashen met de OC bios
Joepie hij werkt perfect! :-) Sta nu op 950 (van Thunderbird 850) dus ik zit goed :-)
  • Stropdas
  • Laatst online: 04-09 16:22
Stropdas
Insert subtitle here
Dit is dus de opvolger van de vorige OCbios van Cheepoman? Die met dat grote logo bij het opstarten? Dat was een modificatie van een oudere BIOS van ECS? De nieuwste BIOS van ECS die was al eerder uit dan die OCbios en die had al standaard geen downclocking meer. K denk niet dat ik deze BIOS zal gaan gebruiken, heb de vorige OCbios van Cheepoman er al op staan na 2 uur modificeren van de instellingen voor het flashen :P
Het is fijn dat er mensen zijn die dit soort dingen doen :) dat waardeer ik, en een paar versies later zal ik misschien weer gaan flashen
Honda VFR800fi '99 | Volvo S60 '04
  • jhead22
Op donderdag 23 mei 2002 17:27 schreef Thorry het volgende:
Leeft je mobo intussen alweer ?
Wat voor cpu gebruik je... Is dat er niet toevallig 1 die op 100fsb standaard draaid ? Dit nieuwe bios heeft namelijk 133/133 als default.. Beetje balen dus voor de mensjes met een 100fsb cputje.
* jhead22 vind t trouwens jammer dat er maar geen biossen uit komen voor de ecs 6A...
Ik hoop namelijk dat ik door een bios update wel hoger kom dan 137 fsb.
(Kep m woensdag ook naar de frontpage gesubt)
Het logo is uit te schakelen, volgens het forumthread.
Jah hoor, zoals ik al postte is me PC weer perfect, ik heb idd een fsb van 100 maar was helemaal geen probleem default is er namelijk niet, kan zelf kijken wat het is dus dat is nooit geen probleem. Het logootje is gewoon bij features geloof ik in te stellen, full screen logo kan je op disabled zetten
  • ModmaN
ModmaN
Damn i'm good
Op vrijdag 24 mei 2002 01:09 schreef Thorry het volgende:
heb jij er eentje met lan onboard :? zo ja, doet die moeilijk met overclocken ???? :?
Neej zonder de Lan, ik heb hier een 100 mbit lan en die onboard was volgens mij maar 10 mbit
Op vrijdag 24 mei 2002 15:57 schreef Thorry het volgende:
10/100 mbit :)
  • Morph666
  • Laatst online: 04-09 11:00
zijn er ook van die biossen voor MSI 6380 ( kt266a pro2 )
iemand?
ben hier zeer benieuwd naar
heb al op msi.com.tw gekeken zonder resultaat
  • Demo
Demo
Op donderdag 23 mei 2002 14:17 schreef Yoman het volgende:
:) Tnx :)
Op vrijdag 24 mei 2002 16:17 schreef Morph666 het volgende:
iemand?
Deze 'hack' BIOSsen zal je op de site van MSI niet vinden...
  • d-super
  • Laatst online: 10-09 22:05
hier is ook en specifiek K7S5A forum met oc biossen,waren eerder als Cheepoman http://pub65.ezboard.com/bk7s5amotherboardforum
Citroën DSuper-bjr 1972-5 bak-108pk-Citroën C4 1.2 Hybrid 136 Max bjr 2024
  • nnk
  • Laatst online: 15:08
nnk
Spreek uit: en en kaa
thx voor het posten ik ga hem gelijk installeren
wel irritant dat 133mhz standaard zou zijn :P
maarjah
ik kon mn pc niet eens op 112fsb draaien... 107 lukte wel
nu is die 107fsb functie dr uit :p
hopelijk kan ie die nieuwe 110mhz functie wel aan :)
  • potatox
  • Laatst online: 06-10-2025
potatox
unz unz unz
waarvoor is die (Fast Write enabled) versie dan?? Ik heb de K7S5A me LAN onboard, kan ik die met fast write dan ook gebruiken?
Kan iemand me een link geven naar een werkend flash-utility? Die op de site is dood, en ik heb een gedowndload van op een vage japanse site, maar die wil niet flashen...
Any help is appreciated.
  • KillerAce_NL
KillerAce_NL
If it ain't broke...
Amiflash kun je ook op ecsusa.com halen.
er is eigenlijk bijna niks aan veranderd wat interessant zou zijn dus die laat ik ff liggen
thanks killerace voor de tip, maar de flashutility die ik daar vond wou ook niet flashen! Zal metteen nog eens verder zoeken.
Ik heb het volgens systeem:
1800+ AMD
ECS K7S5A
512MB DDR (1x Kingston CL2.5 en 1x Apacer CL2.5) (266mhz)
GF4 Ti4200
IBM 40GB
SB Audigy
Wat kan ik het beste geruiken.. de bios update of dat programmatje "setFSB"
Hoever kan ik (redelijk veilig) mijn processor overclock (dmv FSB)
Thanks
  • EmilneM
  • Laatst online: 15-09-2023
Op dinsdag 28 mei 2002 16:20 schreef drax het volgende:
1800+ AMD
ECS K7S5A
GF4 Ti4200
IBM 40GB
SB Audigy
Thanks
dat ligt helemaal aan je totale configuratie en hoe je dit koelt........maar met dit systeem moet fsb van 147 wel te doen zijn, dan herkent ie m als 2000+ als t goed is.....in werkelijkheid is ie dan net iets sneller dan 2000+
  • Gallus
  • Laatst online: 10-09 18:33
Gallus
Cheesy
Met het overclock bios is het gewoon makkelijker. Je stelt het 1 keer in, en je hebt er geen omkijken meer naar.
Ik heb hem net ook geflashed, ben erg blij met de 110/110 instelling.
Duron 1200@1320 B-)
All I want is a warm bed, a kind word and unlimited power.
  • EmilneM
perfect dat oc-bios..........voorheen gebruikte ik dat progje van cheepoman om bios fsb op 150 in te stellen....dit was dus niet echt stabiel.........ja alleen als ik mijn fans voluit zette liep ie door 3dmark 2001 SE heen....nu met fsb 147 wordt mijn 1600+ herkend als 1800+.....en nog stabiel ook! zonder pokkenherrie van fans.....
  • anandus
Euhm... Staat deze Bios nou standaard op 133/133? Of kan je dat omzeilen?
Heb namelijk een Duron, en ben dus bang dattie niet opstart als ik mijn bios flash...
[off topic]
NOOIT meer die klerezooi van een ecs
k heb de K7VZA gehad, twee maand en dat ding fikt gewoon spontaan door!
toen de K7S5A, een bordje dat overal aangeprezen werd voor zogenaamde "stabiliteit"...
stabiliteit my @$$ ja... nu pas was het kapot, kon geen koude boot meer aan. Startte wel op als je power drukte en dan meteen reset...
maar als je zoals mij de resetknop uit je kast hebt geflikkerd en mooi dichtgeplamuurd... is dat best wel een dikke ellende als k elke keer men kast moet open doen
om dan nog maar te zwijgen van de problemen die k had toen k van sd-ram naar ddr-ram overstapte op dat zogenaamde moederbord dat beide ondersteunt...
nee, Gigabyte Ga-7vxrp staat mij momenteel meer aan (mijn xp 1700+ draait lekker stabiel aan 1.53 Ghz, moet em nog unlocken, dan hoger natuurlijk)
[/off topic]
sorry dit moest ik ff kwijt
