[MSSQL] Insert bytes into an IMAGE field
  • 52 views sinds 30-01-2008
Hi all,
I am wondering how to insert about 100,000 zero-bytes into an image field. I've tried WRITETEXT like
this:
WRITETEXT Table1.ColumnA @ptrval REPLICATE(CHAR(0),100000)
But that doesn't work (probably because it expects a literal or variable, not functions?). However,
it makes clear what I want to do:
When I insert a new record into Table1, I want 100,000 bytes (with value 0) to be inserted into Column1.
Please note that the number of bytes to be reserved may be different for each record.
I would really appreciate it if someone could help me out with this problem, because I'm really stuck.
Thanks in advance.
Kind regards,
R. Schuil
  • D2k
  • Laatst online: 31-08 10:19
D2k
in case you didn't notice, this is a dutch board so only questions in Dutch will be answered.
Doet iets met Cloud (MS/IBM)
