Bij Red Hat krijg je bijna alleen security updates. En Red Carpet zorgt bij installeren ook dat de dependencies kloppen. Tevens zit er wat nieuws in enzo. Kijk ook eens in de desktop-reviews bovenin
Ik las dat je met Red Carpet ook Ximian Gnome kunt downloaden.
Kan iemand eens uitleggen wat dit juist is?
En doe ik er goed aan om dit te installeren of wordt de boel daardoor trager?
Q: What is Red Carpet?
A: Red Carpet, delivered as part of Ximian Desktop or downloaded as a stand-alone application from www.ximian.com, is a unique software management solution that simplifies and automates the most challenging tasks of Linux software management such as version control, system updating and package conflict resolution for all the leading Linux distributions. When you add, update or remove applications on your Linux workstation, Red Carpet automatically analyzes and resolves all of the hundreds of potential software dependencies and shared-file conflicts that might affect your system. Red Carpet saves you hours of system administration effort by ensuring that your software is up-to-date and running smoothly.
