Cannot get FULL screen TV mode, and have black border around TV picture in this mode:
For the most part the WinTV will display at a maximum image dimension of 640x480 in any resolution. If your VGA card supports Overlay mode, you should be able to see full screen in resolutions up to 1024 x 768. To set the WinTV to run in Overlay mode, click on Start - Programs - Hauppauge WinTV - Primary program. In here choose the Allow Overlay option and close the program.
If your VGA card does not support overlay mode, this would be a hardware limitation of that VGA chipset. In this case, running in a higher resolution than 640 x 480, will not allow a true full screen TV picture. A work around for this is provided in the WIN/TV program. Click on DISPLAY- Preferences, and set the TV Mode size for 640 x 480 (800 x 600 for the PAL Video format). This will default the VGA display to 640 x 480 resolution when going to full screen mode - allowing a true full screen.
In WinTV2000, click on the PREF button. Then click on the TV Mode option and select the "Allow Resolution Change" (for non-overlay cards).
In WINTV32, this option would be under Configure-TV mode. You can set it for either "Allow Res Change" (for non-overlay cards), or "No Res Change" (for Overlay cards)
NOTE: Windows NT 4.0 , Windows 2000, and XP users will not be able to scale past 640 X 480, even when set to "Allow Overlay" mode, however full screen is still achievable with the "allow resolution change" option.
Maar dit werkt niet.
Als hij de resolutie veranderd.
Veranderd hij hem naar 800x600 en niet naar 640x480.
