het werkt nu dus, maar verschrikkelijk langzaam...het schommelt ook enigszins...dan weer snel..dan weer een paar time outs... dit is mijn config:----- cat /etc/system.cfg -----
# [System]
ROUTER=ethernet# 0.dialup/leased/ethernet/bridge
HOSTNAME=router#711.Router name
DOMAIN=inet#712.(Local) domain name
ENAMSQ=y # 11.Enable NAT and firewall
ENABRG=n # 12.Enable bridging mode? DONT TOUCH!!!
BIGMEM=n # 13.If 16+MB RAM start ppp bsd compression
SAVERS=0,0 # 14.Savers - screen(min),hdd(x5 sec) 0 -off
SWPSIZE=16# 15.Swap size in Kb on boot device. 0 - off
LOGSIZE=50000,5000# 16.System_log,logins_log sizes (bytes)
DEFISP=# 6.Default dialup ISP
# [Services] # y - worldwide/s - local/n - disable
ENADNS=n #411.Enable caching DNS server
LOGDNS=n#412.Enable debug info
ENADHCP=s #421.Enable DHCP server
WINSADDR=#422.WINS address (for DHCP server)
LIZTIME=604800,604800#423.default-lease-time,max-lease-time
ENAWWW=s #431.Enable Public HTTP Server
WWWPORT=80 #432.on port
ENAWWA=s #441.Enable Time Server and control via HTTP
WWAPORT=82 #442.on port
TIMADDR=www.clock.org#443.Host timeserver address, empty - disable
TIMZONE=+0400#444.Offset to UTC (-1200 -:- +1200)
ENALPD=n #451.Enable Print Server
LPPORT1=515#452.on port
LPDEV1=lp1#453.on output device
LPPORT2=516#454.Second lp server on port, empty - disable
LPDEV2=lp2#455.on output device
ENATEL=s# 46.Enable telnet server
# [Security]
TRUSTLN=p #211.Trust local nets y/n/p{artual}
TRUSTMD=y#212.Modem links have access to local networks
RINGS=2,7#220.Rings before answer at login,nologin time
MonTIM=""#221.Nologin times for modem users
TueTIM=""#222
WedTIM=""#223
ThuTIM=""#224
FriTIM=""#225
SatTIM=""#226
SunTIM=""#227
# [Modems]
MODEM0= # 51.1st modem
MSPEED0=# 52.port's speed
MINIT0=""# 53.init string
MTU0=#541.Maximum Transmit Unit
MRU0=#542.Maximum Receive Unit
MADDR0=192.168.168.2# 55.ppp link remote addr (for dialin purpose)
MODEM1= # 61
MSPEED1=# 62
MINIT1=""# 63
MTU1=#641
MRU1=#642
MADDR1=192.168.168.3# 65.I said for dialin purpose.
# [leased line router]
ADRTYPE=dynamic #921.if ISP supplies us with dynamic IP, then:
LOCAL=127.0.0.2 #922.fake local side ppp IP addr
REMOTE=127.0.0.3 #923.fake remote addr
# [ethernet/leased/printer/ras router]
GATEWAY=#911.Default gateway, if exist.
DNSADDR=213.73.255.254#912.Primary DNS address for ethernet connection
DNSADDR1=80.242.224.6#913.Secondary DNS address for ethernet connection
PROXY=""#914.HTTP proxy addr[:port]
# [Hardware]
IO0=0x300#811.1st ethernet card I/O address
IRQ0=10#812.IRQ line
IO1=0#821
IRQ1=0#822
IO2=0#831
IRQ2=0#832
# [Networks]
USEDHCP0=y#720.Use DHCP client to config this interface
INTNAME0=eth0#721.Interface name (eth0|arc0e|arc0)
DHCPLOG=y#722.Enable DHCP client messages in the log
DHCPDNS=n#723 Enable auto configuration of DNS via DHCP
IPADDR0=192.168.0.1#724.IP adress of this interface
NETMASK0=255.255.255.0 #725.Network mask
NETWORK0=192.168.0.0# Network address
BRDCAST0=192.168.0.255# Broadcast address
#726.IP pool, empty disables DHCP on this interface
IPRANGE0=""
INTNAME1=eth1#731.Interface name (eth1|eth0:1|arc0e|arc0 etc)
IPADDR1=192.168.0.1#732. Second network
NETMASK1=255.255.255.0
NETWORK1=192.168.0.0
BRDCAST1=192.168.0.255
IPRANGE1="192.168.0.101 192.168.0.110"
INTNAME2=#74x. Third network
IPADDR2=
NETMASK2=
NETWORK2=
BRDCAST2=
IPRANGE2=""
----- ifconfig -----
lo Link encap:Local Loopback
inet addr:127.0.0.1 Bcast:127.255.255.255 Mask:255.0.0.0
UP BROADCAST LOOPBACK RUNNING MTU:3584 Metric:1
RX packets:12 errors:0 dropped:0 overruns:0
TX packets:12 errors:0 dropped:0 overruns:0
eth0 Link encap:10Mbps Ethernet HWaddr 00:10:A7:09:B6:6B
inet addr:213.73.153.xxx Bcast:213.73.153.255 Mask:255.255.255.0
UP BROADCAST NOTRAILERS RUNNING MTU:1500 Metric:1
RX packets:45846 errors:582 dropped:0 overruns:0
TX packets:2028 errors:0 dropped:0 overruns:0
Interrupt:9 Base address:0x6000
eth1 Link encap:10Mbps Ethernet HWaddr 00:10:A7:03:15:CE
inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2069 errors:0 dropped:0 overruns:0
TX packets:1782 errors:0 dropped:0 overruns:0
Interrupt:11 Base address:0x6100
iemand enig idee
