welk mobo heb jij????
  • 46 views sinds 30-01-2008
ik heb de asus:
http://www.asus.com.tw/mb/comimages/p4t533-c.jpg
The ASUS P4T533-C incorporates the Intel 850E chipset with high-bandwidth 1066MHz RDRAM support to deliver the best performance for latest 533MHz FSB Pentium 4 processors. A maximum 2GB of RDRAM is supported with a peak bandwidth reaching up to 4.2GB/s. Play the most advanced 3D games without a glitch, and get the best performance out of today's memory intensive applications. The ASUS P4T533-C and Pentium 4 combine to provide an ideal scalable, high performance platform for desktops and workstations.
533MHz FSB Support
Featuring the Intel® 850E chipset to support latest 533MHz front side bus Pentium 4 CPU and RDRAM memory.
1066 MHz Rambus memory support
Dual channel 1066 MHz Rambus architecture provide 4.2GB/s bandwidth. The maximum memory capacity is 2GB.
4 USB 2.0 ports
USB 2.0 is the latest connectivity standard for next generation components and peripherals. Backwards compatible with current USB 1.1 peripherals, USB 2.0 delivers transfer speeds up to 40 times faster at 480Mb/s, for easy connectivity and ultra-fast data transfers.
ASUS® EZ Flash
With ASUS EZ Flash, you can update BIOS before entering operating system. No more DOS-based flash utility and bootable diskette required.
6-Channel Audio (optional)
You can enjoy high-quality 6-channel audio without having to buy advanced sound cards.
ASUS® Post Reporter
An unique onboard speech IC chip and ASUS POST Reporter provides clear explanations of system errors for quick and easy optimization. The P4T533-C also includes Winbond Voice Editor allowing users to add customized system voice warnings and multi-language support.
Extreme Overclocking
ASUS P4T533-C offers robust overclocking options to maximize your system performance.
Easy DIP Switch or Jumperfree overclocking from BIOS.
Flexible CPU Core Voltage Adjustments in 0.025V increments over defaults
Rock-solid stability
S/PDIF out interface (on audio model only)
Enjoy complete 5.1 audio with the free bundled S/PDIF out module for easy connectivity between your motherboard and Home Theater system.
ASUS® EZ Plug
The ASUS EZ Plug power connector lets you use your existing power supply and eliminates the need to buy a special ATX 12V power supply to support your Pentium 4 CPU.
AGP Warning LED
ASUS has designed into this motherboard an AGP Warning LED. The AGP Warning LED automatically stops you from turning on your system with incompatible voltage AGP (3.3V) cards, and protects from permanently damaging your motherboard.
ASUS Reliability
All ASUS motherboards are designed and tested to meet the highest quality standards. Responsive customer support and frequent BIOS and driver updates ensure that you're getting the fastest, most reliable performance - all the time. All ASUS motherboards are also backed by a 3-year limited warranty.
Comprehensive Software Bundle
All ASUS motherboards include a valuable software bundle of popular third party programs that enable you to enjoy the full capabilities of your ASUS product:
Trend® Micro PC-cillin 2002 anti-virus program
ASUS® PC Probe for system monitoring
Cyberlink® PowerPlayer SE, Video Live Mail
  • Abbadon
  • Laatst online: 12:19
Eh, waar ben jij nu mee bezig? Het is niet de bedoeling dat je gelijk maar weer een topic opent nadat ik zo-even eenzelfde heb dichtgegooid. Lees de FAQ!
