[Debian] Apt-get broken packages
  • Rempage0611
  • Laatst online: 23-09-2025
Rempage0611
9405 WP @ 2x SMA Sunny Boy
Ik probeer dus Xwindows te installen maar ik krijg de volgende errors:
Athlon:/etc/apt# apt-get install task-x-window-system \
>      task-x-window-system-core task-gnome-apps \
> task-gnome-desktop task-gnome-games \
> task-gnome-net
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
Sorry, but the following packages have unmet dependencies:
  task-gnome-apps: Depends: gnome-utils but it is not going to be installed
             Depends: gnotes but it is not going to be installed
  task-gnome-desktop: Depends: gnome-session but it is not going to be installed
                Depends: gnome-panel but it is not going to be installed
  task-gnome-games: Depends: gnome-games but it is not going to be installed
              Depends: gnomehack but it is not going to be installed
  task-gnome-net: Depends: xchat-gnome but it is not going to be installed
  task-x-window-system: Depends: xserver-vga16 but it is not going to be installed
                Depends: rstart but it is not going to be installed
                Depends: rstartd but it is not going to be installed
                Depends: xlib6g-dev but it is not going to be installed
E: Sorry, broken packages
Athlon:/etc/apt#
De sources.list die ik gebruik werkt wel op m`n server die potato draait, maar niet op m`n workstation die woody draait.
Waar kan dit aan liggen? thnx.
de tasks zijn verwijderd sinds woody, probeer eens apt-get install gnome
  • Rempage0611
Rempage0611
Athlon:/etc/apt# apt-get install gnome
E: Couldn't find package gnome
Athlon:/etc/apt#
  • odysseus
  • Laatst online: 21:46
odysseus
Debian GNU/Linux Sid
'apt-get install gnome-core' of 'apt-get install gnome-bin' zou wel eens meer resultaat kunnen geven. Je kunt met 'apt-cache search iets zoeken naar bepaalde packages.
Leven is het meervoud van lef | In order to make an apple pie from scratch, you must first create the universe.
  • Rempage0611
Rempage0611
Uiteindelijk heb ik Xwindows aan de praat maar als ik opstart blijft ie een tijd bij 'starting gnome window manager' hangen en vervolgens krijg ik een wel erg kale xwindows...
Wat kan da nou weer zijn?
Edit: Deze melding hoort er bij:
"You are not running a GNOME compliant window manager. Gnome support by the window manager is strongly recommended for proper desk guide operation"
Edit2: ... sawfish....
  • deadinspace
  • Laatst online: 16:08
deadinspace
The what goes where now?
Op zondag 19 mei 2002 00:01 schreef Rempage0611 het volgende:
Het is 'The X Window(ing) System', of kortweg 'X', niet 'Xwindows' oid :)
Gnome is een desktop manager; die regelt oa. taakbalk, achtergrondje, icons, startmenutje, enz. Maar het zorgen van een border om windows heen, het resizen en verplaatsen van windows e.d. is niet de taak van Gnome; dat is de taak van een windowmanager (de naam zegt het al).
Je hebt naast Gnome dus nog een windowmanager nodig, het liefst eentje die goed samenwerkt met Gnome. Voor Gnome is sawfish zeer geschikt en veel gebruikt, dus:
apt-get install sawfish
  • Rempage0611
Rempage0611
Op zondag 19 mei 2002 02:21 schreef deadinspace het volgende:
Ok, sorry, ik zal het niet meer vergeten :P
En idd, zie me edit2, had ff gesearched naar een topic van net zo`n n00b als ik en het daar gevonden :) dat vergeten we niet meer
